    Missing Club Logos in MMM-Soccer
    14 Posts 4 Posters 5.8k Views 3 Watching
    • T Offline
      tino
      Re: MMM-Soccer - Soccer Standings
      Hi @ all,
      i just start using the MMM-soccer Module after a complete MM new install one day ago.
      Everything looks good, but i miss the club - logos. i become at this point a symbol that symbolizes a missing icon.
          module: 'MMM-soccer',
          position: 'bottom_left',
              api_key: 'hidden api key',
              show: 'GERMANY',
              logos: true,
              colored: false,
              max_teams: 5
      Any idee what the reason for this and how i get this issue fixed?
      THX in advance
      Tino
        broberg Project Sponsor @tino
        @tino
        Have you run the downloader that is mentioned in the modules readme?
        Logos
        As the v2 api doesn't provide logos anymore, I developed a club logo downloader. It supports the five major leagues as above named. To run the downloader you need to execute the following steps.
            Go to the module directory cd ~/MagicMirror/modules/MMM-soccer.
            Execute node scripts/downloader COUNTRYNAME.
            Run this command for all the leagues you want to display on the mirror.
            Don't forget to activate the display of the logos in the config.
        If there isn't every club logo, you can also place them manually in the public directory of the module, the logos need to be in svg format and the name of the file has to match the displayed name.
        • T Offline
          tino
          @broberg said in Missing Club Logos:
          Hi broberg,
          thx for your fast reply. yes, i’ve tried it serveral times to execute your script to get the logos.
          pi@raspberrypi:~/MagicMirror/modules/MMM-soccer $ node scripts/downloader GERMANY
          same result.
          i also placed some manually downloaded logos in SVG format into the public folder
          pi@raspberrypi:~/MagicMirror/modules/MMM-soccer/public $ ls
          25px-1.FC_Union_Berlin_1966-_1990.gif ‘Hertha BSC.svg’
          ‘BV Borussia 09 Dortmund.svg’ SC_Freiburg.svg
          FCSchalke04.svg
          same result.
          To activate the logos i use the “logos: true,” . This should be correct , or?
            sdetweil @tino
            @tino said in Missing Club Logos in MMM-Soccer:
            “logos: true,”
            try
            “logos”: true,
            • T Offline
              tino
              also “logos”: true, will not show the logos.
                sdetweil
                the code does NOT look in the public folder, from the njk file
                /MMM-soccer/{{standing[index].team.name}}.svg
                or
                /MMM-soccer/{{entry.team.name}}.svg
                might want to edit the njk, and change those to
                /MMM-soccer/public/
                also, many of your files are
                this is svg
                FCSchalke04.svg
                but I don’t think ‘FCSchalke04’ is the team name
                • T Offline
                  tino
                  ok, i have now added the /public to the path like this src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
                  The install discription says : “the logos need to be in svg format and the name of the file has to match the displayed name.”
                  I my case f.e. now FC Schalke 04.svg . The displayed name is “FC Schalke 04”
                  ‘BV Borussia 09 Dortmund.svg’ ‘SC Freiburg.svg’
                  ‘FC Schalke 04.svg’ SC_Paderborn_07_Logo.svg
                  ‘Hertha BSC.svg’
                  same result …strange
                    sdetweil @tino
                    @tino if you open the developers window, ctrl-shift-i, and select the tab labeled console, and scroll up,
                    maybe put ‘soccer’ (no quotes) in the filter field to just see messages from one module, you should see the errors from loading some url…
                    • T Offline
                      tino
                      You made my day!!
                      THX for your tip with the Debug console.
                      System could not find the path to the public folder.
                      false: src=“/MMM-soccer/public/{{standing[index].team.name}}.svg”
                      right: src=“/modules/MMM-soccer/public/{{standing[index].team.name}}.svg”
                      now it works perfect …thumbs up
                        sdetweil @tino
                        @tino woohoo!
                        Glad u solved it!
                          ambujsethi @sdetweil
                          @sdetweil I’m having the same issue but I don’t understand what you mean by the developers window here. What is that, exactly?
                          Thanks.
                            sdetweil @ambujsethi
                            @ambujsethi on the mirror screen, press ctrl-shift-i. This will split screen with the developers window on the right side
                            you can also open the developers window with npm start dev (as long as u stopped the pm instance)
                              @sdetweil Thank you! I’ll try it out and hopefully solve the issue. :)
                                @ambujsethi i think we have the resolution… edit the module njk file and fix the paths to the images
                                from
                                /MMM-Soccer
                                to
                                /modules/MMM-Soccer/public
