    MMM-Facial-Recognition
    31 Posts 2 Posters 16.3k Views 2 Watching
      Buncie
      Whenever I try loading the magic mirror, it keeps showing a black screen. I’m using a Logitech Camera C270. I did make useUsb = true. Could there be something I missed?
        sdetweil @Buncie
        @Buncie open the developers window ctrl-shift-i, then select the console tab and scroll up to see any errors.
        You can put a word in the filter field to limit messages to a specific module
        Facial for you ( not case sensitive)
          Buncie
          Where would I open the developers window. Im connected to the pi using Mac command line ssh if that helps.
            sdetweil @Buncie
            @Buncie u have to do it on the mirror screen
              Buncie
              [0_1571938086869_AF1QipMMEwZBijpc66gjmdGmou7LnGLnF-qIh0I9nhBU.html](Uploading 100%) It’s giving an error message about the example_module.
                sdetweil @Buncie
                @Buncie sorry, not quite sure I understand. Your image did not display.
                UseUsb??? We don’t have that in MagicMirror, unless it is a module
                Also, example module?
                  Buncie
                  The title, MMM-Facial-Recongnition, is the module I’m having issue with.
                  https://github.com/paviro/MMM-Facial-Recognition![0_1571939212539_675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png](/assets/uploads/files/1571939212802-675ae4b6-638c-4e26-bad1-fcc2aeb98e1a-image.png)
                  https://photos.google.com/share/AF1QipMuv9hNbRVSByJFSfhnhDa2a6Rf_fe7nGFPtInNnsAPE7uQ9CWc07MknObyU_nUqQ?key=WmU4d0VXQmhSLUZ3Z0t2aXVKbzRqeHhrRnlGNmhn
                    sdetweil @Buncie
                    @Buncie ah. The facial module executes a script when it detects a face… sounds like u have more config work to do
                      Buncie
                      Is there anyway to change that. All I want is to make it show the camera and when you step in front of it, a box will appear around your face and it will show your name. Here is the config file for the magic mirror so far.
                      https://photos.google.com/share/AF1QipMBomD6bUWkKLSLd51oXRsYx766DFKdZYNFbn7gHo9iK2OBuMQ1yA2blZ25nfAXIQ?key=OUZ5MkhDVndtMzdPcmdWODBRVlFqX0pNTk5GLUFR
                        sdetweil @Buncie
                        @Buncie sorry, I don’t know anything about the module. Maybe another user or the author will come by and be able to help.
                          Buncie
                          Here is the example_module too.
                          https://photos.google.com/share/AF1QipNGBelqXy6FuDK2WKQjyrvIxPsl0zeMPi5hwGZorQXEywzcP2d-MuxoLl4vwS5XCA?key=VGR6VGsxWEV6M1owTEI0Rlh6QVVQWkl0TXlkRVFn
                            sdetweil @Buncie
                            @Buncie there is no example module. He was just suggesting that using classes u could make a module show or hide
                              Buncie
                              So I should delete the example and everything should be fixed?
                                sdetweil @Buncie
                                @Buncie again, I do not know. First time looking at it. On my phone so hard to read the code
                                  Buncie
                                  Even after the reboot, it still shows a black screen. I did crtl-shift-i and it’s showing no error messages. Have any ideas?
                                    Buncie
                                    I need to leave my classroom, I shall hope to resume this chat tomorrow.
                                      Buncie
                                      I’m back, I’m still getting the same error, did anyone figure it out what I did wrong?
                                        sdetweil @Buncie
                                        @Buncie can u show output of
                                        pm2 logs --lines=100
                                          Buncie
                                          How would I do that?
                                            sdetweil @Buncie
                                            @Buncie via ssh or on screen do the command in a command prompt
