Unable to install dependencies - chromedriver.js
8 Posts 2 Posters 2.1k Views 2 Watching
    jinhyuck
    I just bought Raspberry PI 4 (it means I’m noob)
    I tried to install MagicMirror with the code below
    bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
    and I countered an error like below
    Installing dependencies ...
    > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
    > node ./download-chromedriver.js
    /home/pi/MagicMirror/node_modules/electron-chromedriver/download-chromedriver.js:30
      if (err != null) throw err
    Error: getaddrinfo EAI_AGAIN github-production-release-asset-2e65be.s3.amazonaws.com github-production-release-asset-2e65be.s3.amazonaws.com:443
        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:57:26)
    npm WARN acorn-jsx@5.1.0 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! electron-chromedriver@1.8.0 install: `node ./download-chromedriver.js`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the electron-chromedriver@1.8.0 install script.
    npm ERR!     /home/pi/.npm/_logs/2019-11-03T20_21_39_172Z-debug.log
    My npm version is V6.12.1 and node version is v10.15.2 and Raspbian image filename was ‘2019-09-26-raspbian-buster-full’.
    I’m sorry to ask this kind of unproductive thing but I really need your help.
    S 1 Reply Last reply Nov 4, 2019, 4:13 PM Reply Quote 0
      sdetweil
      @jinhyuck said in Unable to install dependencies - chromedriver.js:
      there is some networking access problem from your system
      if you do
      cd ~/MagicMirror/node_modules/electron-chromedriver
      then
      you should see the same error
      are you working thru a VPN, or from a docker container? (where the same error has been reported before)
      J 1 Reply Last reply Nov 5, 2019, 3:14 PM Reply Quote 0
        sdetweil @jinhyuck
        @jinhyuck try my updated installer… will be part of next release
        see https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
        you will have to erase the MagicMirror folder
        from /home/pi
        rm -rf MagicMirror
        J 1 Reply Last reply Nov 4, 2019, 4:38 PM Reply Quote 0
          jinhyuck @sdetweil
          @sdetweil Thanks for the answering.
          I tried the new script you offer
          bash -c "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
          Unfortunately, result is the same error. Am I understand you right?
          S 1 Reply Last reply Nov 4, 2019, 4:41 PM Reply Quote 0
            sdetweil @jinhyuck
            @jinhyuck can u show the ~/MagicMirrir/install.log (or email to me if not, same userid as here at gmail)
            try
            npm i -g npm
            then try the install again (remove MagicMirror folder)
            J 1 Reply Last reply Nov 5, 2019, 11:43 AM Reply Quote 0
              jinhyuck @sdetweil
              @sdetweil I’ve done this
              npm i -g npm
              but still same problem happens.
              And I couldn’t find the ‘install.log’ file.
              the link below is npm log file just in case this helps.
              https://drive.google.com/file/d/1J3IMZ6g4bhwmVW-gAH7b8vmJDG_u_vwn/view?usp=sharing
                sdetweil
                if you do
                then
                  jinhyuck @sdetweil
                  @sdetweil Thanks, Sam.
                  It was a kind of network issue.
                  I used hotspot from my cellphone and I could done the installation.
                  I have to find out why my LAN has that kind of problem.
                  Anyway thanks a lot.
                  S 1 Reply Last reply Nov 5, 2019, 3:15 PM Reply Quote 0
                    sdetweil @jinhyuck
                    @jinhyuck cool… glad you were able to continue
