    MagicMirror won't start after installing module
    7 Posts 3 Posters 2.4k Views 4 Watching
    • J
      jani.karna
      Hi, I need help. Yesterday I installed MMM-Wunderlist module. In the description it said to use ‘npm install’ in modules directory and I did. After that my MagicMirror starts with black screen and nothing on it. At startup I get a bunch of errors/warnings which I don’t understand. Can anyone help? I wouldn’t want to reinstall the whole MagicMirror from scratch!
      Here is a picture of the MagicMirror shell:
      alt text
      If it doesn’t show, here’s link: https://www.dropbox.com/s/79hkyhehk81hgmh/IMG_0513.jpg?dl=0
      EDIT: I actually first ran the ‘npm install’ accidentally from the modules directory instead of modules/MMM-Wunderlist directory which caused MM to stop working.
      S strawberry 3.141S 2 Replies Last reply Reply Quote 0
        sdetweil @jani.karna
        @jani-karna you accidentally erased a MM file. to fix do
        cd ~/MagicMirror
        git checkout  modules/node_modules/node_helper/index.js
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @jani.karna
          @jani-karna It seems like the install of dependencies in the wrong directory removed a file, try the following in the terminal:
          cd ~/MagicMirror
          After that restart your mirror.
          • J
            jani.karna
            Thank you for your replies. I’ll try that when I get back home.
              sdetweil
              i opened issue 1758 back in August to document this problem
              https://github.com/MichMich/MagicMirror/issues/1758
              • J
                jani.karna
                Thank you so much @sdetweil and @strawberry-3-141 , that got my MM up and running again. However, I still get a bunch of “No helper found for module…” for few of them. I don’t know if this is normal.
                • strawberry 3.141S
                  @jani-karna yes that is normal, if a module doesn’t have the optional file node_helper.js you will see it in the logs
