    a new problem with fhem
    17 Posts 4 Posters 7.2k Views 4 Watching
    • kusselinK
      kusselin
      o.k. thanks all for the good job to me. I will always better in Magic Mirror. Now i have installed the fhem module with:
      cd ~/MagicMirror/modules
      git clone https://github.com/BenRoe/MMM-FHEM
      without npm install
      then i go to the config an i put this into:
          module: 'MMM-FHEM',
          position: 'bottom_bar',
            host: 'my IP',
            port: '8083',
            https: false,
            devices: [
                        { deviceName: 'Temperatur_Feuchte_Speicher',
                          deviceReadings: [
                                            { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                            { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
      this is the device name of my sensor
      but when i restart the mirror, my mirror is black on screen :-(
      FoziF 1 Reply Last reply Reply Quote 0
      • FoziF
        Fozi Project Sponsor @kusselin
        @kusselin You must insert the IP-address of your FHEM in
        host: 'my IP',
        Check also if it is running on port 8083 or on another port.
        If ‘npm install’ is required by the author of the module then it is advisable to do so (at least that is required so in the README.MD on github)
        Just to make sure: This module is not supported anymore (as stated on the github repo).
        kusselinK 1 Reply Last reply Reply Quote 0
        • thedoorsfanaticT
          thedoorsfanatic
          Can’t spot a mistake at first glance. Does the mirror work if you deactivate the module? For example, with disabled: true,
          Kann auf den ersten Blick keinen Fehler entdecken. Funktioniert der Spiegel, wenn du das Modul deaktivierst? Z.B. mit disabled:true,
          My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          • kusselinK
            kusselin @Fozi
            @Fozi said in a new problem with fhem:
            host: 'my IP',
            Hi fozi, instead of IP NAS I of course wrote my IP 192.168.xxx.xx and the port is also 8083 standard
            • FoziF
              @kusselin Have you deactivated the module like @thedoorsfanatic recommended? Alternatively you can also comment the module in config.js. Just to make sure that there are no other side-effects.
              • kusselinK
                kusselin
                Sorry, i Havent. Give me Time tomorrow please.
                • kusselinK
                  kusselin
                  @thedoorsfanatic said in a new problem with fhem:
                  disabled:true,
                  yes than i can see the mirror again and i have the npm install in the fhem directory make.
                  but so the mirror is not show again
                  • FoziF
                    @kusselin said in a new problem with fhem:
                    If the mirror is working again after deactivating the module, then remove the module from the /modules directory and re-install it from scratch.
                    $ sudo rm -R MMM-FHEM
                    $ git clone https://github.com/BenRoe/MMM-FHEM
                    $ cd MMM-FHEM
                    $ npm install
                    • kusselinK
                      kusselin
                      sudo rm -R MMM-FHEM
                      whats that!!
                      pi@raspberrypi:~ $  sudo rm -R MMM-FHEM
                      rm: das Entfernen von 'MMM-FHEM' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-FHEM
                      pi@raspberrypi:~/MagicMirror/modules/MMM-FHEM $ sudo rm -R MMM-FHEM
                      thedoorsfanaticT FoziF 2 Replies Last reply Reply Quote 0
                      • thedoorsfanaticT
                        thedoorsfanatic @kusselin
                        @kusselin
                        Du kannst den Ordner ja auch händisch über den Dateiexplorer löschen
                        • FoziF
                          @kusselin du musst erst in das /modules Verzeichnis gehen (s. meinen Post oben) und dann den Löschbefehl aus führen
                          $ cd MMM-FHEM
                          $ npm install
                          • kusselinK
                            kusselin
                            Hallo Zusammen und Frohe Weihnachten,
                            Hab jetzt nachdem ich eine Ebene zurück bin ins Modulverzeichnis das Fhem Modul löschen können und dann auch wieder per Konsole Installiert…dann nochmal in die Config kopiert und dann gestartet…der Bildschirm ist auch gestartet, aber die Temperaturanzeige wird nicht angezeigt. Habe die Position „upper right“ gewählt. Hier mal ein Bild von meinem jetzigen Mirror.
                            Was könnte jetzt noch der Fehler liegen…durch das, das der Mirror ja angezeigt wird, liegts ja nicht an der Config…oder?
                            Könnte es mit der Position ev zusammenhängen noch?
                            Gruss
                            (Hello everyone and Merry Christmas,
                            Now that I am one level back in the module directory, I can delete the Fhem module and then install it again via the console … then copy it again into the config and then start … the screen is also started, but the temperature display is not displayed. Chose the position “upper right”. Here is a picture of my current mirror.
                            What could be the error now … because the mirror is displayed, it is not because of the config … right?
                            Could it still be related to the position ev?
                            Greeting)
                            https://www.bilder-upload.eu/bild-bf0270-1577274708.jpeg.html
                            thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                            • thedoorsfanaticT
                              @kusselin
                              Es ist die Frage, ob das Modul überhaupt funktioniert. In den Issues scheinen auch andere Probleme damit zu haben und es wird auch nicht mehr gepflegt.
                              • kusselinK
                                kusselin
                                Ok…ich hab ja noch ioBroker aufm Raspi…da gibts ja auch noch ein Modul…
                                Dann probiere ich es mal mit dem Modul:-)
                                Gruss
                                kusselinK 1 Reply Last reply Reply Quote 1
                                • D
                                  DerRheingold
                                  I got FHEM up and running on my installation. Works as intended. However the configuration depends on your (hardware) setup. Some questions that come to my mind are:
                                  • Is FHEM is running on the same device?
                                  • Have you defined the Mirror as an allowed FHEMWEB device?
                                  Here’s my config, maybe it helps:
                                  Within FHEM:
                                  # Spiegel/MagicMirror
                                  define MagicM FHEMWEB 8086 global
                                  attr MagicM allowfrom 192.168.178.14
                                  attr MagicM csrfToken none
                                  attr MagicM room 99_System
                                  Within Magic Mirror:
                                                          module: 'MMM-FHEM',
                                                          position: 'top_right',
        host: '192.168.178.10',
        port: '8086',
        https: false,
        devices: [
        { deviceName: 'Temp_Arbeitszimmer',
        deviceReadings: [
        { deviceName: 'Temp_Wohnzimmer',
        deviceReadings: [
        { deviceName: 'Temp_Draussen',
        deviceReadings: [
                                  • kusselinK
                                    kusselin @kusselin
                                    Gruss
                                    Mit iobroker funzt alles!!
                                    With iobroker all is ok
                                    • kusselinK
                                      kusselin @DerRheingold
                                      @DerRheingold said in a new problem with fhem:
                                      thanks fpr your post.
                                      No…fhem is running on another raspi…
                                      i try it…
                                      thanks
