    a new problem with fhem
    17 Posts 4 Posters 6.0k Views 4 Watching
    • kusselinK Offline
      kusselin @Fozi
      @Fozi said in a new problem with fhem:
      @kusselin You must insert the IP-address of your FHEM in
      host: 'my IP',
      Check also if it is running on port 8083 or on another port.
      If ‘npm install’ is required by the author of the module then it is advisable to do so (at least that is required so in the README.MD on github)
      Just to make sure: This module is not supported anymore (as stated on the github repo).
      Hi fozi, instead of IP NAS I of course wrote my IP 192.168.xxx.xx and the port is also 8083 standard
      • FoziF Offline
        Fozi Project Sponsor @kusselin
        @kusselin Have you deactivated the module like @thedoorsfanatic recommended? Alternatively you can also comment the module in config.js. Just to make sure that there are no other side-effects.
        • kusselinK Offline
          kusselin
          Sorry, i Havent. Give me Time tomorrow please.
          • kusselinK Offline
            kusselin
            @thedoorsfanatic said in a new problem with fhem:
            disabled:true,
            yes than i can see the mirror again and i have the npm install in the fhem directory make.
            but so the mirror is not show again
            • FoziF Offline
              @kusselin said in a new problem with fhem:
              If the mirror is working again after deactivating the module, then remove the module from the /modules directory and re-install it from scratch.
              $ sudo rm -R MMM-FHEM
              $ git clone https://github.com/BenRoe/MMM-FHEM
              $ cd MMM-FHEM
              $ npm install
              • kusselinK Offline
                kusselin
                sudo rm -R MMM-FHEM
                whats that!!
                pi@raspberrypi:~ $  sudo rm -R MMM-FHEM
                rm: das Entfernen von 'MMM-FHEM' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-FHEM
                pi@raspberrypi:~/MagicMirror/modules/MMM-FHEM $ sudo rm -R MMM-FHEM
                thedoorsfanaticT FoziF 2 Replies Last reply Reply Quote 0
                • thedoorsfanaticT Offline
                  thedoorsfanatic @kusselin
                  @kusselin
                  Du kannst den Ordner ja auch händisch über den Dateiexplorer löschen
                  My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
                  • FoziF Offline
                    @kusselin du musst erst in das /modules Verzeichnis gehen (s. meinen Post oben) und dann den Löschbefehl aus führen
                    $ cd MMM-FHEM
                    $ npm install
                    • kusselinK Offline
                      kusselin
                      Hallo Zusammen und Frohe Weihnachten,
                      Hab jetzt nachdem ich eine Ebene zurück bin ins Modulverzeichnis das Fhem Modul löschen können und dann auch wieder per Konsole Installiert…dann nochmal in die Config kopiert und dann gestartet…der Bildschirm ist auch gestartet, aber die Temperaturanzeige wird nicht angezeigt. Habe die Position „upper right“ gewählt. Hier mal ein Bild von meinem jetzigen Mirror.
                      Was könnte jetzt noch der Fehler liegen…durch das, das der Mirror ja angezeigt wird, liegts ja nicht an der Config…oder?
                      Könnte es mit der Position ev zusammenhängen noch?
                      Gruss
                      (Hello everyone and Merry Christmas,
                      Now that I am one level back in the module directory, I can delete the Fhem module and then install it again via the console … then copy it again into the config and then start … the screen is also started, but the temperature display is not displayed. Chose the position “upper right”. Here is a picture of my current mirror.
                      What could be the error now … because the mirror is displayed, it is not because of the config … right?
                      Could it still be related to the position ev?
                      Greeting)
                      https://www.bilder-upload.eu/bild-bf0270-1577274708.jpeg.html
                      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                        @kusselin
                        Es ist die Frage, ob das Modul überhaupt funktioniert. In den Issues scheinen auch andere Probleme damit zu haben und es wird auch nicht mehr gepflegt.
