    a new problem with fhem
    17 Posts 4 Posters 5.4k Views 4 Watching
    • kusselinK Offline
      kusselin
      o.k. thanks all for the good job to me. I will always better in Magic Mirror. Now i have installed the fhem module with:
      cd ~/MagicMirror/modules
      git clone https://github.com/BenRoe/MMM-FHEM
      without npm install
      then i go to the config an i put this into:
          module: 'MMM-FHEM',
          position: 'bottom_bar',
            host: 'my IP',
            port: '8083',
            https: false,
            devices: [
                        { deviceName: 'Temperatur_Feuchte_Speicher',
                          deviceReadings: [
                                            { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                            { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
      this is the device name of my sensor
      but when i restart the mirror, my mirror is black on screen :-(
      • FoziF Offline
        Fozi Project Sponsor @kusselin
        @kusselin You must insert the IP-address of your FHEM in
        host: 'my IP',
        Check also if it is running on port 8083 or on another port.
        If ‘npm install’ is required by the author of the module then it is advisable to do so (at least that is required so in the README.MD on github)
        Just to make sure: This module is not supported anymore (as stated on the github repo).
        kusselinK 1 Reply Last reply Reply Quote 0
        • thedoorsfanaticT Offline
          thedoorsfanatic
          Can’t spot a mistake at first glance. Does the mirror work if you deactivate the module? For example, with disabled: true,
          Kann auf den ersten Blick keinen Fehler entdecken. Funktioniert der Spiegel, wenn du das Modul deaktivierst? Z.B. mit disabled:true,
          My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          • kusselinK Offline
            kusselin @Fozi
            @Fozi said in a new problem with fhem:
            host: 'my IP',
            Hi fozi, instead of IP NAS I of course wrote my IP 192.168.xxx.xx and the port is also 8083 standard
            • FoziF Offline
              @kusselin Have you deactivated the module like @thedoorsfanatic recommended? Alternatively you can also comment the module in config.js. Just to make sure that there are no other side-effects.
              • kusselinK Offline
                kusselin
                Sorry, i Havent. Give me Time tomorrow please.
                • kusselinK Offline
                  kusselin
                  @thedoorsfanatic said in a new problem with fhem:
                  disabled:true,
                  yes than i can see the mirror again and i have the npm install in the fhem directory make.
                  but so the mirror is not show again
                  • FoziF Offline
                    @kusselin said in a new problem with fhem:
                    If the mirror is working again after deactivating the module, then remove the module from the /modules directory and re-install it from scratch.
                    $ sudo rm -R MMM-FHEM
                    $ git clone https://github.com/BenRoe/MMM-FHEM
                    $ cd MMM-FHEM
                    $ npm install
                    • kusselinK Offline
                      kusselin
                      sudo rm -R MMM-FHEM
                      whats that!!
                      pi@raspberrypi:~ $  sudo rm -R MMM-FHEM
                      rm: das Entfernen von 'MMM-FHEM' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-FHEM
                      pi@raspberrypi:~/MagicMirror/modules/MMM-FHEM $ sudo rm -R MMM-FHEM
                      thedoorsfanaticT FoziF 2 Replies Last reply Reply Quote 0
                        thedoorsfanatic @kusselin
                        @kusselin
                        Du kannst den Ordner ja auch händisch über den Dateiexplorer löschen
