    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 644.4k Views 47 Watching
    • Andrius okA Offline
      Andrius ok @bmarofsky
      @bmarofsky if need advice please you can ask me
      • H Offline
        Hawking @bmarofsky
        @bmarofsky said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
        so i have all my modules in place and the system crashes: unable to handle kernel null pointer dereference at virtual address
        I’ll roll back to your setup and see if it is stable. i am using calendar, weather, clock and newsfeed- very similar to yours.
        Please report if you could stabilize your system. I also had crashes (approx twice a day) when using Chromium. I didn’t had time to investigate the exact cause (to heavy load?).
        Andrius okA 1 Reply Last reply Reply Quote 0
        • L Offline
          lasharor
          @Andrius-ok Thanks for the image. This works fine. Have you had any succes trying to upgrade Magic mirror? Noticed this image was running a older version.
            Andrius ok @Hawking
            @Hawking my MM with this image on Raspberry Pi Zero W working a half a year without crashing, restarting etc., what modules do you using? Did you try only with my modules? You have to know that SBC is very slow and poor on performance so my modules which is in img is taking 99% CPU always, if tou trying to add one more module I think it’s too much
              Andrius ok @lasharor
              @lasharor yes of course, no problems? Did you? Having issues?
              • P Offline
                patoberli @Andrius ok
                @Andrius-ok said in How I got my Magic Mirror working on a Raspberry Pi 0 (zero):
                Hi @lasharor , my apologies. Yes I have forgotten, very sorry was on long vacation.
                So there is my MM image with Chromium for Raspberry Pi Zero W
                https://www.dropbox.com/sh/kdo5q1pxjluca49/AACvP81YjZik6R90BHZNiSZ5a?dl=0
                note: you have to configure WiFi by yoursefl and also all modules to work properly in Yours language.
                Thanks! Worked nice, until I updated and Chromium 56 (or so) got installed.
                That version can’t connect (for whatever reason) connect to http://localhost:8080/.
                Because of this, I had to change the file /home/pi/startMirror.sh and replace the word localhost with the word 127.0.0.1 and reboot.
                Now it’s working again :)
                Next thing I’m going to try is to update the MagicMirror installation.
                Thanks for your image!
                • T Offline
                  tbanzato
                  @Andrius-ok
                  I used your image and works quite well, only one issue.
                  The server doesn’t star till I SSH it.
                  What I’m saying the Pi Zero W boots and keeps on the prompt but doesn’t start the magic mirror till I ssh the Pi.
                  Any hints?
                  • G Offline
                    greenwaydev
                    Great tutorial but when I booted up my pi I got this:
                    -bash: xset: command not found
                    -bash: midori: command not found
                    pi@raspberrypi:~ $ matchbox: can’t open display! check your DISPLAY variable.
                    I do not know what to do to fix this.
                    MikgaboM 1 Reply Last reply Reply Quote 0
                    • MikgaboM Offline
                      Mikgabo @greenwaydev
                      @greenwaydev
                      Hey!
                      Try this link to a disc image from Andrius:
                      Works amazing for me, and I’m sure for you too!
                      Cheers
                      • G Offline
                        greenwaydev @Mikgabo
                        @Mikgabo Should I flash this to the SD card on my pi?
                        • MikgaboM Offline
                          @greenwaydev
                          I did, worked great for me.
                          • G Offline
                            greenwaydev
                            Awesome! Last question. Do I have to remove the other things I have put on the SD card in my pi? Like everything other than raspbian and jessie? Im kind of new to this stuff
                            • MikgaboM Offline
                              @greenwaydev
                              So what I did was format the sd card and use win32 disc imager to flash the sd card, put it my my Pi Zero and it worked.
                              After install I got rid of some stuff via the config file as I didn’t want all that stuff on my MM.
                              Cheers!
                              • G Offline
                                greenwaydev
                                Changed the display_rotate setting back to 0 but the display is still turned. Any suggestions?
                                • MikgaboM Offline
                                  @greenwaydev
                                  Did you reboot?
                                  • G Offline
                                    @Mikgabo I unplugged the pi, removed the SD, and changed the rotate setting. Then, I put it back in and plugged the pi back in.
                                    MikgaboM 3 Replies Last reply Reply Quote 0
                                    • MikgaboM Offline
                                      @greenwaydev I’m thinking you aren’t making the adjustment in the right location (possibly).
                                      Try this from terminal:
                                      sudo nano /boot/config.txt
                                      and add the following to the file. Where you add it doesn’t really matter:
                                      # Rotate display virtically
                                      display_rotate=0
                                      • MikgaboM Offline
                                        @greenwaydev After you insert that text save it by ctrl + x, then y and enter
                                        • MikgaboM Offline
                                          Mikgabo
                                          the type the command:
                                          sudo reboot
                                          • MikgaboM Offline
                                            @greenwaydev Here is a great tutorial that can help you learn your way around MM.
                                            https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6
                                            I would recommend, once you get your MM configured the way you like to make a back up of it using win32 disk imager (make sure .img is on the end of the file or it won’t save as a disc image). That way if you mess up your SD card somehow you have a back up to use.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 9 / 11
