    Docker and custom.css
    11 Posts 2 Posters 6.8k Views 2 Watching
    • T
      technofab
      I’ve a docker installation… where I need to put my custom.css file?
      I need to generally downsize the font size a little.
      Thanks in advance.
        sdetweil @technofab
        @technofab see the doc(README.md) of the docker container
        https://github.com/bastilimbach/docker-MagicMirror
        /opt/magic_mirror/css/custom.css
        Mount this file to add your own custom css into the docker container.
        Important: You need to create the file before you run the container. Otherwise Docker will create a custom.css folder.
        • T
          technofab
          I did’nt find that path in the container, but I follow the gh container instructions… so? 🤔
            sdetweil @technofab
            @technofab correct, its not IN the container, you need to CREATE a docker mount point at that path
            • T
              technofab
              This post is deleted!
                sdetweil @technofab
                @technofab
                docker takes a --volume=source:dest or a --mount src=,dest= to map a local folder/file into the container at a particular file system location
                so, as this container wants the custom.css at /opt/magic_mirror/css/custom.css
                the parm on docker run would be
                --volume=local_path_to_custom_css:/opt/magic_mirror/css/custom.css
                notice the : between the source and dest
                in a Windows environment where : also appears in driveletter:\path
                u must use the --mount type parameter
                • T
                  technofab
                  Thanks and merry Christmas
                  • T
                    technofab
                    OK I finally put my custom empty file custom.css now: i edit to limit default module calendart in witdh so:
                    body {
                     .module.calendar {
                         width:50px;
                    Stop and restart container but nothing change. What I’m missing?
                      sdetweil @technofab
                      @technofab
                      well, two things
                      1. do not use ‘.module’ in front of the module name
                      2. there is no single style that will set the width…
                        there are these classes (from the calendar README)
                      | `symbolClass`         | Add a class to the cell of symbol. default 'symbol'
                      | `titleClass`          | Add a class to the title's cell.   default 'title'
                      | `timeClass`           | Add a class to the time's cell. default 'time'
                      and
                       'tableClass'      which might be usable to contain the overall width, default not specified
                      in a sample I did this in custom.css
                      .calendar .title {
                      color : blue;
                      .calendar .fribble {
                        background-color:rgba(32,32,32,0.6);
                        border-radius:8px;
                        padding:8px;
                      and in config.js for the calendar module
                        config:{
                           tableClass:'fribble'
                        @technofab you can also confirm your custom.css is in the right place by doing
                        docker exec container_id (or name) cat /opt/magic_mirror/css/custom.css
                        that should match yours
                        • T
                          technofab @sdetweil
                          @sdetweil ok I was assuming is necessary add .module, now works.
                          I find some example that use that keyword… 🤔
