    Black screen
    18 Posts 3 Posters 6.4k Views 4 Watching
    • V
      Vauxdvihl
      Hi friends,
      i had a running system (everything worked fine)
      I installed “MMM-ip” and changed the config accordingly.
      Now i have a black screen
      I deinstalled the “MMM-ip” but the black screen is still there.
      Can please somebody help?
      Regards
      lavolp3L 1 Reply Last reply
        sdetweil @Vauxdvihl
        @Vauxdvihl Error: Cannot find module ‘del’
        that will do it
        do
        cd ~/MagicMirror
        npm install del
        • lavolp3L
          lavolp3 Module Developer @Vauxdvihl
          @Vauxdvihl
          The most probable error is a mistake in your config.
          Please move in the console into your magic mirror folder and execute
          npm run config:check
          OR
          Go on your laptop, open a browser, visit “YOURMAGICMIRRORIP:8080”, press F12 to open Developer Tools, look for errors, post them here. :-)
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • V
            Vauxdvihl
            Config check shows no errors
            and unfortunately does the other thing not work
            Any other debug possibility?
            thanks
            S lavolp3L 2 Replies Last reply
              sdetweil @Vauxdvihl
              @Vauxdvihl try keyboard on mirror, ctrl-shift-i to open dev window
              • lavolp3L
                @Vauxdvihl or, from your laptop or pc, you can ssh into the mirror, got to the MagicMirror directory and execute the following for dev mode:
                pm2 stop all
                npm start dev
                See if there are errors coming up in the console.
                Is there still no troubleshooting guide around to reference to?
                • V
                  Vauxdvihl
                  npm start dev
                  results in
                  pi@PiMirrorNeu:~ $ npm start dev
                  npm ERR! code ENOENT
                  npm ERR! syscall open
                  npm ERR! path /home/pi/package.json
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/.npm/_logs/2020-01-06T19_11_05_569Z-debug.log
                    sdetweil @Vauxdvihl
                    @Vauxdvihl from the magicmirror folder
                    all commands suggested are always from the magic mirror folder
                    • V
                      Vauxdvihl
                      Ah ok
                      Sorry
                      DevTools was disconnected from the page.
                      Once the page is reloaded, DevTools will automatically reconnect.
                        sdetweil @Vauxdvihl
                        @Vauxdvihl this is still MagicMirror version 2.9?
                        a guess
                        do
                        cd ~/MagicMirror
                        git checkout modules/node_modules/node_helper/index.js
                        • V
                          Vauxdvihl
                          Where do i see it?
                          Nothing happen:
                          pi@PiMirrorNeu:~/MagicMirror $ git checkout modules/node_modules/node_helper/index.js
                            sdetweil @Vauxdvihl
                            @Vauxdvihl
                            and then restart mirror
                            • V
                              Vauxdvihl
                              Mirror stays black :-(
                                sdetweil @Vauxdvihl
                                @Vauxdvihl if you do
                                cd ~/MagicMirror
                                npm start
                                what do you see on the terminal window?
                                (alt-spacebar, n to minimize MM screen)
                                • V
                                  Vauxdvihl
                                  pi@PiMirrorNeu:~/MagicMirror $ npm start
                                  > magicmirror@2.9.0 start /home/pi/MagicMirror
                                  > sh run-start.sh
                                  Starting MagicMirror: v2.9.0
                                  Loading config ...
                                  Loading module helpers ...
                                  Module helper loaded: MMM-PublicTransportHafas
                                  No helper found for module: MMM-HTMLBox.
                                  Module helper loaded: MMM-DarkSkyForecast
                                  Module helper loaded: MMM-CalendarExt2
                                  Module helper loaded: MMM-BMW-DS
                                  No helper found for module: MMM-Globe.
                                  No helper found for module: MMM-Timetable.
                                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
                                  Require stack:
                                  - /home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js
                                  App threw an error during load
                                  Require stack:
                                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                      at Module.require (internal/modules/cjs/loader.js:685:19)
                                      at require (internal/modules/cjs/helpers.js:16:16)
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js:3:11)
                                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                      at Module.load (internal/modules/cjs/loader.js:645:32)
                                      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                  Require stack:
                                      at Function.Module._load (internal/modules/cjs/loader.js:560:12) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [
                                      '/home/pi/MagicMirror/modules/mmm-weatherchart/node_helper.js',
                                      '/home/pi/MagicMirror/js/app.js',
                                      '/home/pi/MagicMirror/js/electron.js',
                                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                      undefined
                                  Launching application.
                                    sdetweil @Vauxdvihl
                                    that will do it
                                    do
                                    cd ~/MagicMirror
                                    npm install del
                                    • V
                                      Vauxdvihl
                                      What is “del”
                                      And why is needed now?
                                      Strange
                                        sdetweil @Vauxdvihl
                                        @Vauxdvihl it was needed by MMM-Weatherchart module, but got deleted on the base update.
                                        the automated script cycle was skipped due to the error
                                        (this is the WHOLE reason I created the automated script, to cover this very problem)
                                        what is it? its some npm library the module uses
                                        • V
                                          Vauxdvihl
                                          Ok
                                          Everythings works fine now
