    Does magicmirror need minimal X11 to run?
    26 Posts 2 Posters 9.4k Views 3 Watching
    • L Offline
      lpt2007
        sdetweil @lpt2007
        @lpt2007 if u want to run it on the same system, yes, it is a graphical application,
        if you want to access the server from a remote system (only) , then no… it can run in serveronly mode
        for pi 0, the local embedded browser (electron) is no longer available for the version of node now being provided, so we drop back to serveronly mode and use chromium-browser to run the mirror locally, but that requires graphical mode
        as most users don’t know all this, i updated the run-start.sh script to do all this for you.
        if no X11, (system in console mode) then run in serveronly
        • L Offline
          lpt2007
          I try to run it in docker container with gui on my pi . But when I start it, there is no output to HDMI. MM starts in server mode no matter what I do.
            sdetweil @lpt2007
            @lpt2007 said in Does magicmirror need minimal X11 to run?:
            which docker container?
            the linked one starts MM in serveronly inside the container and then u use a browser on the outside of the container to access to exposed port.
            there is a second docker solution that uses the fact that one can SEE and ACCESS the docker runtime and launches electron to push content out to the X11 gui… this is really cheating…
            but there was a fix created
            replace the run-start.sh with this one from the next release
            https://raw.githubusercontent.com/MichMich/MagicMirror/develop/run-start.sh
            • L Offline
              lpt2007 @sdetweil
              @sdetweil said in Does magicmirror need minimal X11 to run?:
              I changed run-start.sh file and now I get this error:
              > magicmirror@2.10.1 start /root/MagicMirror
              > ./run-start.sh
              /root/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
              npm ERR! code ELIFECYCLE
              npm ERR! syscall spawn
              npm ERR! file sh
              npm ERR! errno ENOENT
              npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.10.1 start script.
              npm ERR!     /root/.npm/_logs/2020-01-15T11_40_27_011Z-debug.log
                sdetweil @lpt2007
                @lpt2007 graphical stuff not loaded in container.
                  sdetweil
                  I would look at this docker setup
                  https://gitlab.com/khassel/magicmirror
                  Otherwise run container in serveronly mode and use chrome on the pi to view the app.
                  • L Offline
                    lpt2007 @sdetweil
                    I added needed graphical libraries, now I get this error:
                    /root/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /root/MagicMirror/node_modules/electron/dist/electron)
                    npm ERR! errno 1
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR!     /root/.npm/_logs/2020-01-16T19_00_47_796Z-debug.log
                      sdetweil @lpt2007
                      @lpt2007 need more libraries.
                      I’d run serveronly in the container, and use chromium from outside the container
                      • L Offline
                        lpt2007 @sdetweil
                        Thanks, but this is not an option, because I try to use mm as addon for Home Assistant and I use hassos image. The mm will be one of the systems I will use on rpi and I will call them trough ha when I need them.
                        Any idea what error I posted means?
                        S 3 Replies Last reply Reply Quote 0
                          sdetweil @lpt2007
                          yes, u need more libraries loaded into the container…
                            sdetweil @lpt2007
                            @lpt2007 use the other docker image I posted a link to… it ‘supposedly’ works… but depends on a security breach in my opinion,
                            letting a container write directly to the docker host XWIndows
                              sdetweil @lpt2007
                              i don’t really understand, as BOTH approaches will require some browser to be running ON the HASSOS image ALL THE TIME… (somewhere)
                              • L Offline
                                lpt2007 @sdetweil
                                This library is already installed.
                                  sdetweil @lpt2007
                                  https://github.com/electron/electron/issues/16364
                                  • L Offline
                                    lpt2007 @sdetweil
                                    not the right one
                                    I installed this one:
                                    root@local-mm:/# apt install libdbus-1-3
                                    Reading package lists... Done
                                    Building dependency tree
                                    Reading state information... Done
                                    libdbus-1-3 is already the newest version (1.10.28-0+deb9u1).
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      sdetweil @lpt2007
                                      @lpt2007 i don’t know… the error says its not right.
                                      I don’t know how to solve it…
                                      again, I would go look at that other docker container which does what you want (maybe)
                                      • L Offline
                                        lpt2007 @sdetweil
                                        Container with mm must connect to host display. I made something simmilar with kodi media center in docker container.
                                          sdetweil @lpt2007
                                          @lpt2007 ok, and why does chrome on the hassos not work?
                                          • L Offline
                                            lpt2007 @sdetweil
                                            Maybe I can try to made ha addon with chrome in kiosk mode to see where the problem is?
