    What is the procedure for reviving a dead module?
    13 Posts 6 Posters 3.8k Views 6 Watching
    • V Offline
      Vizulize Module Developer @sdetweil
      @sdetweil Obviously this would be an option if it weren’t dead. My question was what to do given the fact that a PR is unlikely to be responded to.
      @Sean I think that this is probably the way to go, so I’ll do that.
      Thanks!
      • F Offline
        Fr8Trayne
        Yes please do this. I was just looking to add this today, but looks like I’ll wait. If you’re able do you mind adding the water stat as well?
        • V Offline
          @Fr8Trayne I’ve got the following currently supported data:
          • Steps Walked (compared to goal)
          • Calories Burned (compared to goal)
          • Total Distance Walked (compared to goal)
          • # of Active Minutes (compared to goal)
          • # of Floors Climbed (compared to goal)
          • Resting Heart Rate (average for the day)
          • Today’s Remaining Water Intake (amount consumed subtracted from goal)
          • Today’s Remaining Calories To Consume (amount consumed subtracted from goal)
          • Sleep Time (compared to goal)
          • Current Weight (last weigh-in, if within the last 30 days)
          I need icons for water, food and weight, and some assistance with formatting before I will post it publicly. Perhaps I will create a new forum post for this.
          • F Offline
            Fr8Trayne
            This is awesome! Did you add it as a new module?
            • V Offline
              I want to get icons and formatting sorted before I add it publicly. However, you can try it here: https://github.com/m-roberts/MMM-Fitbit2
              Also, I need to handle credentials from the config, as currently they are hard-coded into files that are used by the Python Fitbit library. This needs to be handled from the config directly, to support multiple Fitbit accounts on one setup.
              F 1 Reply Last reply Reply Quote 2
              • F Offline
                Fr8Trayne @Vizulize
                @Vizulize keep up the great work! If I had the coding knowledge to help I would definitely lend a hand. This will be an awesome addition to many Magic Mirrors.
                • V Offline
                  I have posted the module here. I am looking for testers!
                  lavolp3L bheplerB 2 Replies Last reply Reply Quote 1
                  • lavolp3L Offline
                    lavolp3 Module Developer @Vizulize
                    Oh, am I jealous of you fitbit guys. Garmin has a very costly API only intended for professionals.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • bheplerB Offline
                      bhepler Module Developer @Vizulize
                      @Vizulize - Thank you for your work. I’ll give it a go as soon as I get home.
