    MMM-plex-recently-added
    4 Posts 3 Posters 1.4k Views 4 Watching
      JohnBachini
      Hi, just started trying to set up magicmirror and am having problem with MMM-plex-recently-added module, when running get error about plex-api module, but cant any information about this module .
      Thank you for any help
      [08:43:43.559] [LOG]    Starting MagicMirror: v2.10.1
      [08:43:43.562] [LOG]    Loading config ...
      [08:43:43.564] [LOG]    Loading module helpers ...
      [08:43:43.565] [LOG]    No helper found for module: alert.
      [08:43:43.592] [LOG]    Initializing new module helper ...
      [08:43:43.592] [LOG]    Module helper loaded: updatenotification
      [08:43:43.594] [LOG]    No helper found for module: clock.
      [08:43:43.839] [LOG]    Initializing new module helper ...
      [08:43:43.840] [LOG]    Module helper loaded: calendar
      [08:43:43.841] [LOG]    No helper found for module: compliments.
      [08:43:43.842] [LOG]    No helper found for module: currentweather.
      [08:43:43.842] [LOG]    No helper found for module: weatherforecast.
      [08:43:43.844] [LOG]    Initializing new module helper ...
      [08:43:43.844] [LOG]    Module helper loaded: mmm-hue-lights
      [08:43:43.846] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'plex-api'
      [08:43:43.846] [LOG]    Loading module helpers ...
      [08:43:43.846] [LOG]    No helper found for module: alert.
      [08:43:43.847] [LOG]    Initializing new module helper ...
      [08:43:43.847] [LOG]    Module helper loaded: updatenotification
      [08:43:43.847] [LOG]    No helper found for module: clock.
      [08:43:43.847] [LOG]    Module helper loaded: calendar
      [08:43:43.848] [LOG]    No helper found for module: compliments.
      [08:43:43.848] [LOG]    No helper found for module: currentweather.
      [08:43:43.848] [LOG]    No helper found for module: weatherforecast.
      [08:43:43.848] [LOG]    Initializing new module helper ...
      [08:43:43.848] [LOG]    Module helper loaded: mmm-hue-lights
      [08:43:43.849] [ERROR]  App threw an error during load
      [08:43:43.849] [ERROR]  Error: Cannot find module 'plex-api'
          at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          at Function.Module._resolveFilename (/home/john/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._resolveFilename (/home/john/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/john/MagicMirror/modules/MMM-plex-recently-added/plex.js:1:170)
          at Object.<anonymous> (/home/john/MagicMirror/modules/MMM-plex-recently-added/plex.js:45:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      [08:43:43.850] [LOG]    Whoops! There was an uncaught exception...
      [08:43:43.850] [ERROR]  { Error: Cannot find module 'plex-api'
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' }
      [08:43:43.854] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [08:43:43.855] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [08:43:43.947] [LOG]    Launching application.
      ^C[08:43:59.685] [LOG]    Shutting down server...
      [08:43:59.688] [LOG]    Stopping module helper: updatenotification
      [08:43:59.689] [LOG]    Stopping module helper: calendar
      [08:43:59.690] [LOG]    Stopping module helper: mmm-hue-lights
      [08:43:59.690] [LOG]    Stopping module helper: updatenotification
      [08:43:59.691] [LOG]    Stopping module helper: calendar
      [08:43:59.691] [LOG]    Stopping module helper: mmm-hue-lights
        sdetweil @JohnBachini
        @JohnBachini said in MMM-plex-recently-added:
        Cannot find module ‘plex-api’
        there is a package.json file for this module, which lists the plex-api as a dependency
        according to the instructions
        Installation
        Clone this repo
        run npm install in the cloned folder
        you need to do
        cd ~/MagicMirror/modules/MMM-plex-recently-added
        npm install
        • T Offline
          tomyboy96 Project Sponsor
          How did u find the token?
          Trying to add this module but can’t seem to find a token anywhere. Looked at the Plex Guide for finding the token but didn’t help me at all…
            sdetweil @tomyboy96
            @tomyboy96 the readme says
            Get your plex token (https://support.plex.tv/hc/en-us/articles/204059436-Finding-your-account-token-X-Plex-Token)
