    Problem with currentweather module
    3 Posts 2 Posters 817 Views 2 Watching
    • C Offline
      chris.uvm
      Hi.
      My config.js stops after running the currentweather module and does not display the rest of the modules. If i erase it everything shows up so I figured that something must be wrong with the code but I cannot find it… Anyone else that can see the misstake or knows whats wrong? The appid is working because it works in the weatherforecast module.
      			module: "currentweather",
      			position: "lower_right",
      				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "*********************"
      Does anyone know the problem?
      Thanks!
        Mykle1 Project Sponsor Module Developer @chris.uvm
        @chris-uvm said in Problem with currentweather module:
        This will work:
        position: "bottom_right",
        There is no position “lower_right”
        • C Offline
          chris.uvm
          Thank you, weird thing cuz it’s been working for about a year but it works now, Thank you!
