    MMM-TelegramBot error.
    26 Posts 5 Posters 5.5k Views 5 Watching
      Mrtrol2013
      After installing and configuring the module, the Telegram bot does not respond to messages (/ help, / commands) What should I do in this situation?
      http://skrinshoter.ru/s/080220/fPHcUQKh?a
      http://skrinshoter.ru/s/080220/JqOajiDU?a
      • ? Offline
        A Former User @Mrtrol2013
        @Mrtrol2013
        don’t put " < " and " > ".
          Mrtrol2013 @Guest
          @Sean doesn’t help, bot doesn’t work either
          ? 2 Replies Last reply Reply Quote 0
          • ? Offline
            @Mrtrol2013
            no, you just probably misconfigured.
            • ? Offline
              @Mrtrol2013
              Show me your current edited configuration again.
                Mrtrol2013 @Guest
                @Sean said in MMM-TelegramBot error.:
                @Mrtrol2013
                http://skrinshoter.ru/s/090220/hkrTecpW?a
                • ? Offline
                  @Mrtrol2013
                  Hmmm…
                  add verbose:true, in your config then let’s see the log what happens. To make things simple, disable other modules in your configuration.
                    module: 'MMM-TelegramBot',
                      verbose: true,
                    Mrtrol2013 @Guest
                    @Sean http://skrinshoter.ru/s/090220/nYYpy6Oh?a
                    MMM-TelegramBot not work
                    • ? Offline
                      @Mrtrol2013
                      I need log. show me the log. I cannot figure out anything with only configuration.
                        Mrtrol2013 @Guest
                        @Sean
                        /home/pi/MagicMirror/modules/MMM-TelegramBot/.git/logs/HEAD
                        0000000000000000000000000000000000000000 9fbce6fe4439d56d46527cd4441bf4cd823bc56b pi <pi@pi.(none)> 1581112213 +0300	clone: from https://github.com/eouia/MMM-TelegramBot.git
                        • 1 / 3
