    MMM-TelegramBot error.
    26 Posts 5 Posters 8.3k Views 5 Watching
      Mrtrol2013 @Guest
      @Sean
      /home/pi/MagicMirror/modules/MMM-TelegramBot/.git/logs/HEAD
      0000000000000000000000000000000000000000 9fbce6fe4439d56d46527cd4441bf4cd823bc56b pi <pi@pi.(none)> 1581112213 +0300	clone: from https://github.com/eouia/MMM-TelegramBot.git
      ? 1 Reply Last reply
        Mrtrol2013
        @Sean
        I do not know how to view the log file
          A Former User @Mrtrol2013
          @Mrtrol2013
          If you are using pm2 to execute MagicMirror,
          pm2 logs
          Or,
          just stop pm2 and execute npm start dev on MagicMirror directory.
          pm2 stop all
          npm start dev
          It will show runtime log on your terminal shell.
          M 2 Replies Last reply
            Mrtrol2013 @Guest
            @Sean said in MMM-TelegramBot error.:
            pm2 logs
            http://skrinshoter.ru/s/090220/uYldwV0X?a
            http://skrinshoter.ru/s/090220/hqejBmIE?a
            http://skrinshoter.ru/s/090220/M8sqFA3M?a
            ? 2 Replies Last reply
              Mrtrol2013 @Guest
              Or,
              pm2 stop all
              npm start dev
              http://skrinshoter.ru/s/090220/qvC2cwfM?a
              http://skrinshoter.ru/s/090220/38fGJyAM?a
                @Mrtrol2013
                Usually connect ETIMEDOUT error will occur when your device would be behind a proxy. Was it accessing the internet via a proxy server? (perhaps from a school or company)
                Or your firewall would be blocking it. Check it. (Sorry I can’t help these kinds of issues. Discuss with your network admin.)
                  @Mrtrol2013
                  Anyway, I’ll make some patch for using under a proxy. But cannot guarantee when it is done.
                    Mrtrol2013 @Guest
                    @Sean thank you
                      Mrtrol2013 @Guest
                      @Sean I’m very interested in your module, I can use it with a proxy at the moment. Can you explain how to make it work?
                        @Mrtrol2013
                        adding some proxy host and path info on request to telegram server, might be needed. not so complex, but real test be required.
                        Z 1 Reply Last reply
                        • Z
                          Zoltan @Guest
                          @Sean
                          Please can you have a look at my log file. I have made a fresh install but my problem still persist. When i use the /help and the other commands in the help file, then i get the expected response. But when i use the
                          /commands or
                          /mychatid then i get a responce of
                          “Unrecognized command. Say what?”
                          I have played with some of the settings of my phone and tried to whitelist my phones ip in the config file but still no joy. Any idea from your side looking at the log? I also dont see my log file grow as i try the commands on my phone
                            A Former User
                            Hi, You need to launch a conversation with your new bot created. Not with BotFather.
                            To talk to your bot:
                            above the token you have the link to talking to your bot !
                            like : t.me/ just click on it :)
                            Z S 2 Replies Last reply
                            • Z
                              Zoltan @Guest
                              @Bugsounet
                              Fantastic, thanks Cedric, much appreciated. I am onboard again :-)
                                sonicgoose @Guest
                                @Bugsounet This is not working for me. Step 4 in the install instructions just responds with “You are not allowed to command me. Ask Admin.”
                                My config:
                                                        disabled: false,
                                                        module: "MMM-TelegramBot",
        telegramAPIKey: "12XXXXX892:AAHXXXXXXXXXXXXXXXX_0Dme-XXXXXXX",
        allowedUser: "BXXXXXdBXXXXFXXXX",
                                Console show MMM-TelegramBot started ok.
                                Log file:
                                [2020-08-13 13:45:32.619] [ERROR]  TelegramError: ETELEGRAM: 404 Not Found
                                    at /home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/node-telegram-bot-api/src/telegram.js:213:15
                                    at tryCatcher (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/util.js:16:23)
                                    at Promise._settlePromiseFromHandler (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/promise.js:547:31)
                                    at Promise._settlePromise (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/promise.js:604:18)
                                    at Promise._settlePromise0 (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/promise.js:649:10)
                                    at Promise._settlePromises (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/promise.js:729:18)
                                    at _drainQueueStep (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/async.js:93:12)
                                    at _drainQueue (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/async.js:86:9)
                                    at Async._drainQueues (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/async.js:102:5)
                                    at Immediate.Async.drainQueues [as _onImmediate] (/home/pi/MagicMirror/modules/MMM-TelegramBot/node_modules/bluebird/js/release/async.js:15:14)
                                    at processImmediate (internal/timers.js:439:21) {
                                  code: 'ETELEGRAM',
                                  response: IncomingMessage {
                                    _readableState: ReadableState {
                                      objectMode: false,
                                      highWaterMark: 16384,
                                      buffer: BufferList { head: null, tail: null, length: 0 },
                                      length: 0,
                                      pipes: null,
                                      pipesCount: 0,
                                      flowing: true,
                                      ended: true,
                                      endEmitted: true,
                                      reading: false,
                                      sync: true,
                                      needReadable: false,
                                      emittedReadable: false,
                                      readableListening: false,
                                      resumeScheduled: false,
                                      paused: false,
                                      emitClose: true,
                                      autoDestroy: false,
                                      destroyed: false,
                                      defaultEncoding: 'utf8',
                                      awaitDrain: 0,
                                      readingMore: true,
                                      decoder: null,
                                      encoding: null
                                    readable: false,
                                    _events: [Object: null prototype] {
                                      end: [Array],
                                      close: [Array],
                                      data: [Function],
                                      error: [Function]
                                    _eventsCount: 4,
                                    _maxListeners: undefined,
                                    socket: TLSSocket {
                                      _tlsOptions: [Object],
                                      _secureEstablished: true,
                                      _securePending: false,
                                      _newSessionPending: false,
                                      _controlReleased: true,
                                      _SNICallback: null,
                                      servername: 'api.telegram.org',
                                      alpnProtocol: false,
                                      authorized: true,
                                      authorizationError: null,
                                      encrypted: true,
                                      _events: [Object: null prototype],
                                      _eventsCount: 9,
                                      connecting: false,
                                      _hadError: false,
                                      _parent: null,
                                      _host: 'api.telegram.org',
                                      _readableState: [ReadableState],
                                      readable: true,
                                      _writableState: [WritableState],
                                      writable: true,
                                      allowHalfOpen: false,
                                      _sockname: null,
                                      _pendingData: null,
                                      _pendingEncoding: '',
                                      server: undefined,
                                      _server: null,
                                      ssl: [TLSWrap],
                                      _requestCert: true,
                                      _rejectUnauthorized: true,
                                      parser: null,
                                      _httpMessage: null,
                                      [Symbol(res)]: [TLSWrap],
                                      [Symbol(asyncId)]: -1,
                                      [Symbol(kHandle)]: [TLSWrap],
                                      [Symbol(lastWriteQueueSize)]: 0,
                                      [Symbol(timeout)]: null,
                                      [Symbol(kBytesRead)]: 0,
                                      [Symbol(kBytesWritten)]: 0,
                                      [Symbol(connect-options)]: [Object]
                                    connection: TLSSocket {
                                      _SNICallback: null,
                                      authorized: true,
                                      encrypted: true,
                                      _eventsCount: 9,
                                      connecting: false,
                                      _hadError: false,
                                      _parent: null,
                                      readable: true,
                                      writable: true,
                                      _sockname: null,
                                      _pendingData: null,
                                      server: undefined,
                                      _server: null,
                                      ssl: [TLSWrap],
                                      _requestCert: true,
                                      parser: null,
                                      _httpMessage: null,
                                    httpVersionMajor: 1,
                                    httpVersionMinor: 1,
                                    httpVersion: '1.1',
                                    complete: true,
                                    headers: {
                                      server: 'nginx/1.16.1',
                                      date: 'Thu, 13 Aug 2020 17:45:32 GMT',
                                      'content-type': 'application/json',
                                      'content-length': '55',
                                      connection: 'keep-alive',
                                      'strict-transport-security': 'max-age=31536000; includeSubDomains; preload',
                                      'access-control-allow-origin': '*',
                                      'access-control-expose-headers': 'Content-Length,Content-Type,Date,Server,Connection'
                                    rawHeaders: [
                                      'Server',
                                      'nginx/1.16.1',
                                      'Date',
                                      'Content-Type',
                                      'application/json',
                                      'Content-Length',
                                      '55',
                                      'Connection',
                                      'keep-alive',
                                      'Strict-Transport-Security',
                                      'Access-Control-Allow-Origin',
                                      'Access-Control-Expose-Headers',
                                    trailers: {},
                                    rawTrailers: [],
                                    aborted: false,
                                    upgrade: false,
                                    url: '',
                                    method: null,
                                    statusCode: 404,
                                    statusMessage: 'Not Found',
                                    client: TLSSocket {
                                      _SNICallback: null,
                                      authorized: true,
                                      encrypted: true,
                                      _eventsCount: 9,
                                      connecting: false,
                                      _hadError: false,
                                      _parent: null,
                                      readable: true,
                                      writable: true,
                                      _sockname: null,
                                      _pendingData: null,
                                      server: undefined,
                                      _server: null,
                                      ssl: [TLSWrap],
                                      _requestCert: true,
                                      parser: null,
                                      _httpMessage: null,
                                    _consuming: false,
                                    _dumped: false,
                                    req: ClientRequest {
                                      _eventsCount: 5,
                                      outputData: [],
                                      outputSize: 0,
                                      writable: true,
                                      _last: false,
                                      chunkedEncoding: false,
                                      shouldKeepAlive: true,
                                      useChunkedEncodingByDefault: true,
                                      sendDate: false,
                                      _removedConnection: false,
                                      _removedContLen: false,
                                      _removedTE: false,
                                      _contentLength: null,
                                      _hasBody: true,
                                      _trailer: '',
                                      finished: true,
                                      _headerSent: true,
                                      socket: [TLSSocket],
                                      connection: [TLSSocket],
                                      _header: 'POST /botAAHXXXXXXXXXXXXXXXX_0Dme-XXXXXXX/getUpdates ' +
                                        'HTTP/1.1\r' +
                                        '\nhost: api.telegram.org\r' +
                                        '\ncontent-type: application/x-www-form-urlencoded\r' +
                                        '\ncontent-length: 19\r' +
                                        '\nConnection: keep-alive\r' +
                                        '\n\r' +
                                        '\n',
                                      _onPendingData: [Function: noopPendingOutput],
                                      agent: [Agent],
                                      socketPath: undefined,
                                      method: 'POST',
                                      path: '/botAAHXXXXXXXXXXXXXXXX_0Dme-XXXXXXX/getUpdates',
                                      _ended: true,
                                      res: [Circular],
                                      aborted: false,
                                      timeoutCb: null,
                                      upgradeOrConnect: false,
                                      parser: null,
                                      maxHeadersCount: null,
                                      [Symbol(isCorked)]: false,
                                      [Symbol(outHeadersKey)]: [Object: null prototype]
                                    request: Request {
                                      _eventsCount: 5,
                                      method: 'POST',
                                      simple: false,
                                      resolveWithFullResponse: true,
                                      forever: true,
                                      readable: true,
                                      writable: true,
                                      explicitMethod: true,
                                      _qs: [Querystring],
                                      _auth: [Auth],
                                      _oauth: [OAuth],
                                      _multipart: [Multipart],
                                      _redirect: [Redirect],
                                      _tunnel: [Tunnel],
                                      _rp_resolve: [Function],
                                      _rp_reject: [Function],
                                      _rp_promise: [Promise [Object]],
                                      _rp_callbackOrig: undefined,
                                      callback: [Function],
                                      _rp_options: [Object],
                                      headers: [Object],
                                      setHeader: [Function],
                                      hasHeader: [Function],
                                      getHeader: [Function],
                                      removeHeader: [Function],
                                      localAddress: undefined,
                                      pool: [Object],
                                      dests: [],
                                      __isRequestRequest: true,
                                      _callback: [Function: RP$callback],
                                      uri: [Url],
                                      proxy: null,
                                      tunnel: true,
                                      setHost: true,
                                      originalCookieHeader: undefined,
                                      _disableCookies: true,
                                      _jar: undefined,
                                      port: 443,
                                      body: 'offset=0&timeout=10',
                                      httpModule: [Object],
                                      agentClass: [Function: Agent],
                                      agentOptions: [Object],
                                      agent: [Agent],
                                      _started: true,
                                      href: 'https://api.telegram.org/botAAHXXXXXXXXXXXXXXXX_0Dme-XXXXXXX/getUpdates',
                                      req: [ClientRequest],
                                      ntick: true,
                                      response: [Circular],
                                      originalHost: 'api.telegram.org',
                                      originalHostHeaderName: 'host',
                                      responseContent: [Circular],
                                      _destdata: true,
                                      _ended: true,
                                      _callbackCalled: true
                                    toJSON: [Function: responseToJSON],
                                    caseless: Caseless { dict: [Object] },
                                    body: { ok: false, error_code: 404, description: 'Not Found' }
                                  sonicgoose @sonicgoose
                                  Bump for @Bugsounet
                                    A Former User
                                    @sonicgoose said in MMM-TelegramBot error.:
                                    try with:
                                    allowedUser: ["BXXXXXdBXXXXFXXXX"],
                                    sorry for last response ! I just return from vacations :)
                                      sonicgoose @Guest
                                      @Bugsounet Thanks. That seems to have done the trick. I didn’t notice the square brackets when reading the instructions.
