    MMM-TelegramBot error.
    26 Posts 5 Posters 8.3k Views 5 Watching
      Mrtrol2013 @Guest
      @Sean doesn’t help, bot doesn’t work either
      ? 2 Replies Last reply
        A Former User @Mrtrol2013
        @Mrtrol2013
        no, you just probably misconfigured.
          @Mrtrol2013
          Show me your current edited configuration again.
          M 1 Reply Last reply
            Mrtrol2013 @Guest
            @Sean said in MMM-TelegramBot error.:
            @Mrtrol2013
            http://skrinshoter.ru/s/090220/hkrTecpW?a
            ? 1 Reply Last reply
              @Mrtrol2013
              Hmmm…
              add verbose:true, in your config then let’s see the log what happens. To make things simple, disable other modules in your configuration.
                module: 'MMM-TelegramBot',
                  verbose: true,
                Mrtrol2013 @Guest
                @Sean http://skrinshoter.ru/s/090220/nYYpy6Oh?a
                MMM-TelegramBot not work
                  @Mrtrol2013
                  I need log. show me the log. I cannot figure out anything with only configuration.
                    Mrtrol2013 @Guest
                    @Sean
                    /home/pi/MagicMirror/modules/MMM-TelegramBot/.git/logs/HEAD
                    0000000000000000000000000000000000000000 9fbce6fe4439d56d46527cd4441bf4cd823bc56b pi <pi@pi.(none)> 1581112213 +0300	clone: from https://github.com/eouia/MMM-TelegramBot.git
                      Mrtrol2013
                      @Sean
                      I do not know how to view the log file
                        @Mrtrol2013
                        If you are using pm2 to execute MagicMirror,
                        pm2 logs
                        Or,
                        just stop pm2 and execute npm start dev on MagicMirror directory.
                        pm2 stop all
                        npm start dev
                        It will show runtime log on your terminal shell.
                        M 2 Replies Last reply
                          Mrtrol2013 @Guest
                          pm2 logs
                          http://skrinshoter.ru/s/090220/uYldwV0X?a
                          http://skrinshoter.ru/s/090220/hqejBmIE?a
                          http://skrinshoter.ru/s/090220/M8sqFA3M?a
                            Mrtrol2013 @Guest
                            Or,
                            pm2 stop all
                            npm start dev
                            http://skrinshoter.ru/s/090220/qvC2cwfM?a
                            http://skrinshoter.ru/s/090220/38fGJyAM?a
                              @Mrtrol2013
                              Usually connect ETIMEDOUT error will occur when your device would be behind a proxy. Was it accessing the internet via a proxy server? (perhaps from a school or company)
                              Or your firewall would be blocking it. Check it. (Sorry I can’t help these kinds of issues. Discuss with your network admin.)
                                @Mrtrol2013
                                Anyway, I’ll make some patch for using under a proxy. But cannot guarantee when it is done.
                                  Mrtrol2013 @Guest
                                  @Sean thank you
                                    Mrtrol2013 @Guest
                                    @Sean I’m very interested in your module, I can use it with a proxy at the moment. Can you explain how to make it work?
                                      @Mrtrol2013
                                      adding some proxy host and path info on request to telegram server, might be needed. not so complex, but real test be required.
                                      Z 1 Reply Last reply
                                      • Z
                                        Zoltan @Guest
                                        @Sean
                                        Please can you have a look at my log file. I have made a fresh install but my problem still persist. When i use the /help and the other commands in the help file, then i get the expected response. But when i use the
                                        /commands or
                                        /mychatid then i get a responce of
                                        “Unrecognized command. Say what?”
                                        I have played with some of the settings of my phone and tried to whitelist my phones ip in the config file but still no joy. Any idea from your side looking at the log? I also dont see my log file grow as i try the commands on my phone
                                          A Former User
                                          Hi, You need to launch a conversation with your new bot created. Not with BotFather.
                                          To talk to your bot:
                                          above the token you have the link to talking to your bot !
                                          like : t.me/ just click on it :)
                                          Z S 2 Replies Last reply
                                          • Z
                                            Zoltan @Guest
                                            @Bugsounet
                                            Fantastic, thanks Cedric, much appreciated. I am onboard again :-)
