    MMM-TelegramBot error.
    26 Posts 5 Posters 7.9k Views 5 Watching
      Mrtrol2013
      After installing and configuring the module, the Telegram bot does not respond to messages (/ help, / commands) What should I do in this situation?
      http://skrinshoter.ru/s/080220/fPHcUQKh?a
      http://skrinshoter.ru/s/080220/JqOajiDU?a
      • ? Offline
        A Former User @Mrtrol2013
        @Mrtrol2013
        don’t put " < " and " > ".
          Mrtrol2013 @Guest
          @Sean doesn’t help, bot doesn’t work either
          ? 2 Replies Last reply Reply Quote 0
          • ? Offline
            @Mrtrol2013
            no, you just probably misconfigured.
            • ? Offline
              @Mrtrol2013
              Show me your current edited configuration again.
                Mrtrol2013 @Guest
                @Sean said in MMM-TelegramBot error.:
                @Mrtrol2013
                http://skrinshoter.ru/s/090220/hkrTecpW?a
                • ? Offline
                  @Mrtrol2013
                  Hmmm…
                  add verbose:true, in your config then let’s see the log what happens. To make things simple, disable other modules in your configuration.
                    module: 'MMM-TelegramBot',
                      verbose: true,
                    Mrtrol2013 @Guest
                    @Sean http://skrinshoter.ru/s/090220/nYYpy6Oh?a
                    MMM-TelegramBot not work
                    • ? Offline
                      @Mrtrol2013
                      I need log. show me the log. I cannot figure out anything with only configuration.
                        Mrtrol2013 @Guest
                        @Sean
                        /home/pi/MagicMirror/modules/MMM-TelegramBot/.git/logs/HEAD
                        0000000000000000000000000000000000000000 9fbce6fe4439d56d46527cd4441bf4cd823bc56b pi <pi@pi.(none)> 1581112213 +0300	clone: from https://github.com/eouia/MMM-TelegramBot.git
                          Mrtrol2013
                          @Sean
                          I do not know how to view the log file
                          • ? Offline
                            @Mrtrol2013
                            If you are using pm2 to execute MagicMirror,
                            pm2 logs
                            Or,
                            just stop pm2 and execute npm start dev on MagicMirror directory.
                            pm2 stop all
                            cd ~/MagicMirror
                            npm start dev
                            It will show runtime log on your terminal shell.
                              Mrtrol2013 @Guest
                              pm2 logs
                              http://skrinshoter.ru/s/090220/uYldwV0X?a
                              http://skrinshoter.ru/s/090220/hqejBmIE?a
                              http://skrinshoter.ru/s/090220/M8sqFA3M?a
                                Mrtrol2013 @Guest
                                Or,
                                pm2 stop all
                                cd ~/MagicMirror
                                npm start dev
                                http://skrinshoter.ru/s/090220/qvC2cwfM?a
                                http://skrinshoter.ru/s/090220/38fGJyAM?a
                                • ? Offline
                                  @Mrtrol2013
                                  Usually connect ETIMEDOUT error will occur when your device would be behind a proxy. Was it accessing the internet via a proxy server? (perhaps from a school or company)
                                  Or your firewall would be blocking it. Check it. (Sorry I can’t help these kinds of issues. Discuss with your network admin.)
                                  • ? Offline
                                    @Mrtrol2013
                                    Anyway, I’ll make some patch for using under a proxy. But cannot guarantee when it is done.
                                      Mrtrol2013 @Guest
                                      @Sean thank you
                                        Mrtrol2013 @Guest
                                        @Sean I’m very interested in your module, I can use it with a proxy at the moment. Can you explain how to make it work?
                                        • ? Offline
                                          @Mrtrol2013
                                          adding some proxy host and path info on request to telegram server, might be needed. not so complex, but real test be required.
                                          Z 1 Reply Last reply Reply Quote 0
                                          • Z Offline
                                            Zoltan @Guest
                                            @Sean
                                            Please can you have a look at my log file. I have made a fresh install but my problem still persist. When i use the /help and the other commands in the help file, then i get the expected response. But when i use the
                                            /commands or
                                            /mychatid then i get a responce of
                                            “Unrecognized command. Say what?”
                                            I have played with some of the settings of my phone and tried to whitelist my phones ip in the config file but still no joy. Any idea from your side looking at the log? I also dont see my log file grow as i try the commands on my phone
