    MMM-Netatmo updated
    56 Posts 15 Posters 42.7k Views 16 Watching
    • L Offline
      Laz @Tribun
      @Tribun
      Thank you
      Did you create an app on the https://dev.netatmo.com/apps/ website?
      I tried to put the RaymondMolenaar module once.
      Here above (September 27, 2022) I wrote about my problem…
      How did you get token ?
      On the Netatmo application page, it is not clear which token should be used… ((Screenshot_19.png
      • T Offline
        Tribun @Laz
        @Laz
        At choose scopes: select “read station” and press generate token, you will get the “refreshToken:” and
        “accessToken:”
        Enter all newly created values ​​in config.js after that it should work again.
        • L Offline
          Laz @Tribun
          @Tribun
            Mitch_66 @Laz
            Hi All, thanks for the support provided in this forum here. Awesome!
            I’m following all what is said here: got “refreshToken”, “accessToken” via the Netatmo page, entered it in the config.js exactly as stated here. Nevertheless, the module won’t show up on the mirror - just a small circle beneath the header.
            Am I missing “something”, a specific setting for the mirror? The RBpi is not publicly accessible from the internet, no web hook URI, no direct URI configured.
            Any help appreciated! The Netatmo module is the feature why we have the MM2!
              Mitch_66 @Mitch_66
              @Mitch_66 I found the solution to my problem: once I inserted the moduleOrder parameter, the module showed up. As it isn’t marked as “required”, I didn’t put it in the first place.
              Maybe helps somebody having the same issue
              • L Offline
                Laz @Mitch_66
                @Mitch_66
                Good afternoon!
                Please show your config in this module. I also prescribed this parameter, but my Netatmo module does not appear… (((
                  Mitch_66 @Laz
                  @Laz
                  Will do but you’ll need to wait a bit. Currently far away from home, back in a week
                    Mitch_66 @Mitch_66
                    @Laz
                    Here’s my config that works. The name for the rooms in Netatmo are as specified in the Netatmo App. It’s a quite ‘old’ Netatmo module, talking about 8 years or so hence for sure not the latest hardware.
                                        module: 'MMM-Netatmo',
                                        disabled: false,
                                        position: 'bottom_bar', // the location where the module should be displayed
                                        header: 'Netatmo',
                                                clientId: 'clientID', // your app id
                                                clientSecret: 'clientSecret', // your app secret
                                                refreshToken: 'refresh|token', // your generated refresh token
                                                accessToken: 'access|token',
                                                location: "germany/badenwurttemberg/stuttgart-arnulf-klett-platz",  //for AirQuality
                                                updateIntervalAirQuality: 300, // in secondes = every 30 minutes
                                                updatesIntervalDisplay: 60, //refresh internal
                                                lastMessageThreshold: 600, // in seconds (10 minutes)
                                                horizontal: true,
                                                horizontalOverflow: false,
                                                windUnit: "KMH",
                                                showLastMessage: true,
                                                showDataIcon: true,
                                                showDataHeader: true,
                                                showModuleStatus: true,
                                                showModuleFirmware: true,
                                                refreshInterval: 3,
                                                moduleOrder: ["Wohnzimmer", "Schlafzimmer", "Terrasse" ],
                    L 2 Replies Last reply Reply Quote 0
                    • L Offline
                      Laz @Mitch_66
                      @Mitch_66
                      Thank you!
                      I’ll try to check. Unfortunately, I have already left the city where my MM is standing. I will try through VNC access.
                      • L Offline
                        Laz @Mitch_66
                        @Mitch_66
                        Good afternoon!
                        Do you use what module of Netatmo of the author?
                        I use the module from CFenner
                        In July the module ceased to become authorized. In August the author finished it, but after completion (some files were replaced), at restart of a mirror all modules ceased to be started. If to rename the folder of the module of Netatmo, then other modules are started.
                        I tried to return the kept folder of the module of their archive, with the old version of this module all other modules are started. Except the module of Netatmo. I tried also your config (with my data), but all the same the module isn’t started… (((
                          Mitch_66 @Laz
                          @Laz
                          Nope, using this one: https://github.com/RaymondMolenaar/MMM-Netatmo/blob/master/README.md
                          Couldn‘t make the Renner module work again. Good luck!
                          • L Offline
                            Laz @Mitch_66
                            @Mitch_66 said in MMM-Netatmo updated:
                            @Laz
                            And what is this “Rener module”?
                              Mitch_66 @Laz
                              @Laz Auto-correction at work - the CFenner module
                              • L Offline
                                Laz @Mitch_66
                                @Mitch_66
                                Unfortunately, I did not understand your answer… (
                                What does “autocorrection” mean…?
                                  sdetweil @Laz
                                  @Laz phone auto correction, changing the text you type to what it thinks is the right word
                                  • L Offline
                                    Laz @sdetweil
                                    Thank you ))
                                    When I sent the message, I already understood))
                                    But you can only delete it when it is published… (
                                    • 3 / 3
