Working Google-Assistant on Raspbian Buster and 4b
Hi All,
I have a Magic Mirror installation running on the new Rasp4b and Rasbian Buster. I tried getting MMM-AssistantMk2 and MMM-Hotword working using various documents on here, but could not get it to work, so I tried another route -> getting Google Assistant to work on the Raspberry. It works now.Is there any way from going from a working google assistant to implement it into the Magic Mirror and can anyone point me in the right direction?
Best Regards and thanks!
Milkshake
Hello,
I confirm that MMM-Assistantmk2 works well with raspberry 4 and buster because I run it on a pi 4 B 4GB ram.
I followed the wiki of Eouia and Bugsounet available on the Next link:
https://github.com/eouia/MMM-AssistantMk2/wiki/Installation
the installer is very well designed and easy and greatly facilitates installation compared to the previous version.
Hope this will help you,
Regards,
@Chris Hey, thanks man! A little bit disheartening after getting it to work on the pi, but I will definitely restore the pi once again and give it a try. Am I right in understanding that you need some software to listen for an activation command, e.i. HotWord? I think I succeeded in installing MMM-AssistantMk2 earlier, but I did not get HotWord to work, after which I gave up.
@MilkShake
Hotword is just one method to activate amk2. If you prefer, any other methods can be used. - touchscreen button, hw button, sensors like pir, 3d gesture detector, touchscreen gesture, finger snapping, or Any module can emit some notifications of MagicMirror.
@Sean said in Working Google-Assistant on Raspbian Buster and 4b:
@MilkShake
Hotword is just one method to activate amk2. If you prefer, any other methods can be used. - touchscreen button, hw button, sensors like pir, 3d gesture detector, touchscreen gesture, finger snapping, or Any module can emit some notifications of MagicMirror.Yes ok
I would like to be able to enable the Assistant using voice, so HotWord seems like the way to go. The mirror has a pir sensor also for turning on the screen, built into the side of the frame, so it can be activated by hand movement.
Since I managed to get the regular assistant working on the PI, I will have a go at Assistant-Mk2 and HotWord tonight. Hopefully it will just install
@MilkShake : after if you want AMk2 with a built-in activator, you can try AMk2 addons with snowboy
Personnaly, with my mirror, i use this AMk2 addons: governor, pir, snowboy, screen, briefToday, A2D and internet
notes:
- all addons are linked, and it use AMk2 micConfig for snowboy
- A2D: display your photos, weblink found by your mirror
(in dev : display youtube video and sync with screen addons, will be released very soon ! )
Weblink sample:
Youtube sample:
@Bugsounet That seems like a good way to go! I’m mostly just after the voice activation for the Assistant, but I’ll go with anything that works. So would the process be:
- Install MMM-AssistantMk2 from https://github.com/eouia/MMM-AssistantMk2/wiki/Installation
- Install MMM-AssistantMk2 Plugins embedded with addons.js from https://github.com/bugsounet/addons
Thanks for all the help guys!
I think I got MMM-AssistantMk2 and Bugsounet’s https://github.com/bugsounet/addons installed successfully! Used the same credentials.json file as I used in the other Assistant setup and tested with node auth_and_test.js.It’s can become quite confusing with all these modules and addons. Can anyone elaborate on what is needed configuration wise, to allow for voice activation of AssistantMk2.
I guess addons need to be activated for Assistant and HotWord needs a configuration of sorts. I will have a look at this later.
Best
MilkShake
@MilkShake I tried editing my config.js with the following:
{ module: "MMM-Hotword", position: "top_left", config: { recipes: ["with-AMk2v3_smart-mirror.js"], } }, { module: "MMM-AssistantMk2", position: "top_left", config: { assistantConfig: { latitude: 55.749842, longitude: 12.497128, }, recipes: [ "with-MMM-Hotword.js" ], addons: true, }, },
But it crashes my MagicMirror. If I remove “addons: true,” the mirror starts and the two top_left positions are empty.
hi, i have a lot of time … [#StayInHome #COVID19]
so i can help you to configure from begining- what addons do you want to use ?
- AMk2 don’t show icon by default, just because default interface is like Google Nest
so i will be showing only when activating by hotkey
