    Working Google-Assistant on Raspbian Buster and 4b
    19 Posts 4 Posters 5.0k Views 3 Watching
      MilkShake @Guest
      @Bugsounet That seems like a good way to go! I’m mostly just after the voice activation for the Assistant, but I’ll go with anything that works. So would the process be:
      1. Install MMM-AssistantMk2 from https://github.com/eouia/MMM-AssistantMk2/wiki/Installation
      2. Install MMM-AssistantMk2 Plugins embedded with addons.js from https://github.com/bugsounet/addons
      Thanks for all the help guys!
        MilkShake
        I think I got MMM-AssistantMk2 and Bugsounet’s https://github.com/bugsounet/addons installed successfully! Used the same credentials.json file as I used in the other Assistant setup and tested with node auth_and_test.js.
        It’s can become quite confusing with all these modules and addons. Can anyone elaborate on what is needed configuration wise, to allow for voice activation of AssistantMk2.
        I guess addons need to be activated for Assistant and HotWord needs a configuration of sorts. I will have a look at this later.
        Best
        MilkShake
        M 1 Reply Last reply
          MilkShake @MilkShake
          @MilkShake I tried editing my config.js with the following:
                      module: "MMM-Hotword",
                              recipes: ["with-AMk2v3_smart-mirror.js"],
                      module: "MMM-AssistantMk2",
                              assistantConfig: {
                                      latitude: 55.749842,
                                      longitude: 12.497128,
                              recipes: [ "with-MMM-Hotword.js" ],
                              addons: true,
          But it crashes my MagicMirror. If I remove “addons: true,” the mirror starts and the two top_left positions are empty.
            A Former User
            hi, i have a lot of time … [#StayInHome #COVID19]
            so i can help you to configure from begining
            1. what addons do you want to use ?
            2. AMk2 don’t show icon by default, just because default interface is like Google Nest
              so i will be showing only when activating by hotkey
              MilkShake @Guest
              @Bugsounet Hi. Thanks a bunch. Something good from the virus, hurray!
              So the mirror functions with a PIR sensor installed in the frame. It hangs where there is a lot of traffic, so a hand gesture along side the frame activates the screen using DPMS -> DISPLAY=:0 xset dpms force on (only way I could get the screen to turn on again was with DPMS). No movement and the mirror turns on again in x time.
              So what I would like to accomplish is, when the screen is activated, it should start listening for a google assistant hotword.
              Would that be Hotword and PIR? Depending on how Assistant2Display works, that could be interesting as well, but for now, I just want to get it working.
              ? 1 Reply Last reply
                A Former User
                actually, i can’t do this (not coded)
                I have coded this:
                • wake up screen with voice (when calling assistant)
                • delay turn off screen if mirror is not used
                • if used pir detector : wake up the screen
                • if used snowboy or MMM-Hotword and pi sensor : keyword activator is turn off when not used and need pir sensor to wake up
                you can do that what addon ;)
                  A Former User @MilkShake
                  @MilkShake
                  You can emit HOTWORD_PAUSE and HOTWORD_RESUME notification when you need if your PIR module could emit these notifications. Or to translate different notifications through MMM-NotificationTrigger.
                    MilkShake @Guest
                    @Bugsounet
                    Does the keyword activator (I guess that is the code listening for a keyword?) pay a toll on the electrical bill and thus, you would like to turn it off?
                    Isn’t the snowboy/HotWord, PIR sensor and governor combo a means of achieving that?
                      MilkShake @Guest
                      @Sean So the python script that wakes up my screen along with the PIR, could potentially also emit a HOTWORD_RESUME and HOTWORD_PAUSE to the assistant along with executing a shellscript for turning on/off the screen. That sounds like the right way to go, but I have no clue how to do that and not enough time to figure it out :)
                        A Former User
                        We solves the problem by instant messaging ;)
                        And all works
                          A Former User @Guest
                          @Bugsounet
                          Share your works even briefly for others. :)
                            A Former User
                            for resume :
                            @MilkShake have a misconfig MMM-Hotword and turn on all AMk2 addons (include snowboy and porcupine)
                            so i will never works like this.
                            We change like this:
                            desactived MMM-Hotword
                            used: snowboy addons with “computer” keyword, Assistant2Display addons
                            and works:
                            notes : he have an RPI 4 (4go) , he use pir sensor.
                            he send me his screen monitoring to add it in screen addon
                            I rewrite screen addon for solve screen issue
                            because actually only RPI3 is supported
                            we will try screen/pir addon with his config tomorrow for sync with all AMk2 addon (Assistant2Display inclued)
                            and he should have CPU less (and electricity) usage on screen sleeping:
                            • when screen is on (wake up by pir sensor) snowboy will be on and display on
                            • when screen if off (setting by inused delay) -> all module is hidden, display is off and snowboy is off
                            it’s actualy my personnal AMk2 config
                            Edit:
                            we finish the configuration and everything works ;)
                            now screen/pir are linked to snowboy and Assistant2Display for more cpu save (and electricity)
                              MilkShake
                              It works really well now. Mirror and assistant/addons turns on when the pir detects motion. Awesome combo of AssistantMk2 and Addons.
