    FHEM Module
    9 Posts 4 Posters 6.7k Views 4 Watching
    • D
      DirkS
      Is anybody using FHEM for house automation?
      It would be great to have a module to show status of sensors and so on.
      On the other hand a FHEM module for the Mirror would be also great just to send messages to the mirror.
      What do you think?
      Best regards
      Dirk
      • Z
        zombi27
        Hey Dirk,
        I want to do a similar thing if i have some spare time ! I’m using Loxone for home automation and i’m plannung to integrate this into mm :)
        I think my idea to use UDP commands to do this will also be working with FHEM
        greets
        max
        • D
          DirkS
          Oh that’s great! Do you have some programming skills? I’m more a hardware based skilled guy, but if i can help you in anyway please let me know.
          • Z
            zombi27
            haha, i’m not a crack… but i’ll trial&error it out :P
            • B
              BenRoe Module Developer
              @DirkS i am working on a module for FHEM. It works, but i have one bug. If i solved it, i will relase it.
              Here is a screenshot.
              alt text
              • D
                DirkS @BenRoe
                @BenRoe said in FHEM Module:
                alt text
                Oh that’s so GREAT!! Keep working on it :D
                • B
                  BenRoe Module Developer @DirkS
                  @DirkS any ideas how to improve?
                  • D
                    DirkS @BenRoe
                    @BenRoe Yes :D
                    • changing the Device names showed on the mirror. Within FHEM i use names like “KuTempFeuchte” etc. On the mirror i would like to have more clear name like “Küche Temperatur”
                    • I discovered that the values are not updated after they are pulled once. Don’t know why
                    • Would be great to have push messages on the mirror depending on some trigger of a FHEM device
                    • i would have some more ideas ;)
                    • B
                      bobbythemoh
                      Hi, i am also using loxone and i am interested in the plugin. is it available?
                      thanks
