    Calendar and iCloud
    8 Posts 5 Posters 2.9k Views 5 Watching
    • L Offline
      lodam
      Hey to all,
      Just because i spent a lot of time looking for this info : how to synchronize my icloud calendar and MM2
      This is my solution :
      in the default module calendar :
      just use the URL iCloud gives you when you make your calendar public but using https instead of “webcal…”… so this should like this : “https://gt551_caldav.icould.com/published/88/xxxxxxxxxxxx…”
      hope this could help someone :-)
      damien
      French version :
      Pour ceux qui cherchent à afficher l’agenda partagé de leur Mac ou iPac, etc, vous pouvez utiliser l’adresse que donne iCould lorsque vous rendez public l’agenda.
      Entrer alors l’adresse sous la forme : “https://gt551_caldav.icould.com/published/88/xxxxxxxxxxxx…” (sans le “webcal…”)
      bonne utilisation :)
      StoffbeuteluweS M 2 Replies Last reply Reply Quote 2
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @lodam
        @lodam put the public url in your calendar module…that’s it.
        S L 2 Replies Last reply Reply Quote 0
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe all he was saying is that he had to change webcal:// to https:// on the calendar url
          StoffbeuteluweS L 2 Replies Last reply Reply Quote 0
            Stoffbeuteluwe Project Sponsor @sdetweil
            @sdetweil ok :slightly_smiling_face:
            • L Offline
              lodam @sdetweil
              @sdetweil exactly, thanks :)
              • L Offline
                lodam @Stoffbeuteluwe
                @Stoffbeuteluwe Sorry, not sure i understand you. But it took me a few hours to make it work because i do not want to use gogol agenda.
                I thought this could be helpful for other users :) (and i added a french translation for those who do not speak english)
                I tried to use other agenda Framagenda.org (NextCloud) but did not succeed yet
                Thanks anyway for your help
                have a great day
                damien
                  monkeyjb123 @lodam
                  @lodam Hey there! So I tried to sync my icloud calendar and using “https://xxxxxx…” I was able to get the MM started, however none of my events on this calendar are showing up. Just the baseline holiday one that comes with the MM. Was wondering if you had any insight to that.
                  Thanks!
                  • Y Offline
                    yk
                    I was able to do this without making my iCloud calendar public. Look around for vdirsyncer. It gives you the ability to log in to iCloud and replicate your calendar locally. Then point your calendar to your local ics file. I have mine refreshing a few times a day. Works like a charm.
