    Newsfeed with own RSS2 resp. XML
    8 Posts 2 Posters 2.0k Views 2 Watching
    • thgmirrorT
      thgmirror
      Hi colleagues,
      I’m trying to use in the Newsfeed-module an own feed on the RPI. So no external link to for example Tagesschau but to a file in the MagicMirror-folder.
      I tried this:
      url: “http://192.168.2.117:8080/home/pi/MagicMirror/podcasts.rss2”
      but without success. I only see “Lade …”
      Currently I have in podcasts.rss2 a copy of the Tagesschau-feed.
      Anyone an idea?
      Thank you for any help
      and Greetings from Bonn
      Thomas
        sdetweil @thgmirror
        @thgmirror said in Newsfeed with own RSS2 resp. XML:
        the server at http://192.168.2.117:8080
        uses the MagicMirror folder as the root
        so
        “http://192.168.2.117:8080/podcasts.rss2”
        • thgmirrorT
          thgmirror
          @sdetweil said in Newsfeed with own RSS2 resp. XML:
          Hm, no success…any other idea?
          S 2 Replies Last reply
            sdetweil @thgmirror
            @thgmirror the MM should says starting a fetcher for
            like this from my system
            Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            this will show in the terminal window where npm start was done, or in the logs if pm2
            pm2 logs --lines=100
            (or more than 100)
              sdetweil @thgmirror
              @thgmirror also, is your config set to address:“0.0.0.0” or “localhost”
              if localhost, then u must use localhost or 127.0.0.1
              “http://localhost:8080/podcasts.rss2”
              • thgmirrorT
                thgmirror
                http://localhost:8080/os
                Also localhost has no affect…and the solution yoi mentioned before I’ll try later;-)
                Thomas
                  sdetweil @thgmirror
                  @thgmirror sorry, the root is /MagicMirror, but the available paths under are modules etc
                  so, this works
                  http://localhost:8080/modules/podcasts.rss2
                  and the file is located in MagicMirror/modules
                  • thgmirrorT
                    thgmirror
                    Yeah Yeah Yeah - Success!!!
                    I moved the file to the modules-folder and now it works!!!
                    I plan to use the Newsfeed-ticker to display a protocoll of my podcast-downloader…I have some special requirements;-)
                    Thank you, Sam
