    Help for a Novice....
    22 Posts 3 Posters 8.5k Views 3 Watching
      j.ason
      Re: MMM-Bose-Soundtouch
      Hi there,
      As I like others are at home I thought I would give this MMM a go and first task was to see if I could sort out the Bose Module.
      I have never repeat never done anything like this before so please be patient :-)
      I have entered the above lines into my config.js yet when I reboot my Pi I get nothing - not even the header?
      I went into Terminal and went to the modules part and then ran the GitHub clone within the ~/MagicMirror/modules location ( hope that is correct)?
      Any ideas why I see nothing at all folks?
        sdetweil @j.ason
        @j-ason so, if you go back to the original config.js (copy the sample to config.js, save your current one first)
        does mirror come back up?
          j.ason
          Hi Sam,
          The mirror works with the modules I have - calendar, calendar and time :-)
          Its just the Bose one I get seem to get to work that is frustrating me tbh :-(
          I fi could figure out how to add a screenshot I would :thinking_face:
            j.ason @sdetweil
            @sdetweil Thanks for replying so quickly too :clapping_hands:
              sdetweil @j.ason
              @j-ason the forum posting pics is broken (still)… so u have to post them somewhere else
              black screen usually means some config or setup problem…
              open the developers window (ctrl-shift-i on the keyboard), and select the console tab,. and scroll up to see any errors (usually red text)
              u did not edit any module file, right, only the config.js…
              does the module have a package.json file, and if so, did u run npm install in the module folder?
                j.ason @sdetweil
                @sdetweil Can I send you the screenshot? (email , WhatsApp ?)
                As I said I am way out of my depth tbh - only started this the other day and hoping it will make sense as I go along :crossed_fingers_light_skin_tone:
                All I have done is load Raspberry Jessie version, MM2 install with default calendar, time, weather - edit… Have managed to work around getting my Google calendar to work and change location to UK for calendar and weather settings…
                S Mykle1M 2 Replies Last reply Reply Quote 0
                  sdetweil @j.ason
                  @j-ason sure, send to same userid as here, at gmail.
                    Mykle1 Project Sponsor Module Developer @j.ason
                    @j-ason
                    Looking at the documentation, I see the config sample entry does not have a comma after the last bracket. The config entry should look like this:
                    	module: "MMM-Bose-Soundtouch",
                    	position: "top_right",   // see mirror setting for options
                    		updateInterval: 5, // every 5 seconds
                    		apiBase: '192.168.xxx.xxx',
                    Notice the comma after the last curly bracket?
                    Of course, @sdetweil has probably brought that to your attention already. :-)
                      sdetweil @Mykle1
                      @Mykle1 the comma only matters IF this is the not the last module config entry…
                      but blackscreen shouldn’t be because of this, you’d get a “create a config file” error
                        True, but it IS the most common mistake for beginners, or I am much mistaken. :-)
                          j.ason @Mykle1
                          @Mykle1 - thanks for replying :-)
                          I do have a comma on my file like what you attached within this chat
                          J
                          Mykle1M S 2 Replies Last reply Reply Quote 0
                            @j-ason
                            Very well. Then I suggest you follow the suggestions that @sdetweil has posted above. I’m sure he will get you sorted, if he hasn’t already.
                              sdetweil @j.ason
                              @j-ason ok. good…
                              then u still have a black screen when starting MM…right>
                              so, let start from the terminal window
                              pm2 stop 0
                              cd ~/MagicMirror
                              npm start
                              wait for it to come up…
                              if working from PI screen do
                              alt-spacebar, n to minimize the MM screen
                              no errors reported?
                              then to get the MM screen displayed again
                              on MM do
                              alt (hold down)
                              press tab key
                              a list of windows will appear
                              tab to the MagicMirror screen view,
                              release alt key
                              open developers window
                              press ctrl-shift-i
                              select the tab labeled console
                              enter ‘bose’ (no quotes) in the filter field
                              are there any errors (usually red text), may have to scroll up
                                j.ason
                                Hi Sam,
                                I do have the MM working and no black screen :-)
                                I have weather, clock and calendar working and it boots up fine too…
                                Just wanted to figure out about this Bose module - partly because I have a Bose setup in my house and secondly the more of this I read and try to understand the more I hopefully will :crossed_fingers_light_skin_tone:
                                  sdetweil @j.ason
                                  @j-ason ok, developers window may still help
                                  use developers window instructions above
                                    j.ason @sdetweil
                                    BTW I have sent you an email with the screenshot
                                    J
                                      sdetweil @j.ason
                                      @j-ason ok, got screenshot, but doesn’t show any error… so, see instructions above
                                      that is what we call black screen “I get nothing”
                                      u don’t have to reboot each time, just use
                                      pm2 restart 0
                                      if using pm2 to start at boot
                                        j.ason @sdetweil
                                        @sdetweil Apologies,
                                        What I meant was I get nothing in relation to the Bose Module - no header no text and no music showing etc…
                                        Having gone into Developers window I see no red errors relating to Bose. I did filter and let only warnings and errors show too.
                                          sdetweil @j.ason
                                          @j-ason but u see messages related to bose module, in developers window, correct?
                                          J 2 Replies Last reply Reply Quote 0
                                            j.ason @sdetweil
                                            @sdetweil I do see Bose listed and no errors - screenshot sent to you to show you…
