    After need take another config.js
    12 Posts 2 Posters 6.2k Views 2 Watching
    • P Offline
      pi-user
      In which file is it defined that the config.js file is the main configuration file? Can you define different config.js files? How for example configXYZ.js? So take another config.js as needed?
      Many thanks for the help
        sdetweil @pi-user
        @pi-user set env variable
        export config=???
        ??? Is new filename, full path if not in config folder
        • P Offline
          pi-user
          @sdetweil said in After need take another config.js:
          export config
          Where can I put export config? So, that means that I can take another configuration file if necessary?
            sdetweil @pi-user
            @pi-user in the terminal window or script. If pm2 then in installers/mm.sh
            • P Offline
              pi-user
              mm.sh
              I discovered that the file name is defined in the check_config.js file!
              /opt/magic_mirror/tests/configs/check_config.js
              function getConfigFile() {
              // FIXME: This function should be in core. Do you want refactor me ;) ?, be good!
              rootPath = path.resolve(__dirname + “/…/…/”);
              var configFileName = path.resolve(rootPath + “/config/config.js”);
              if (process.env.MM_CONFIG_FILE) {
              configFileName = path.resolve(process.env.MM_CONFIG_FILE);
              return configFileName;
                sdetweil @pi-user
                @pi-user in electron.js is says process.env.config
                P 2 Replies Last reply Reply Quote 0
                • P Offline
                  pi-user @sdetweil
                  Thank you
                  • P Offline
                    pi-user @sdetweil
                    I looked at it. But how can I edit this file so that another config file is read? Such as: configXYZ.js and not the standard name config.js
                    Thank you
                      sdetweil @pi-user
                      @pi-user just copy the default config.sample.js to anyname.js
                      then edit that name and do
                      export config=anyname.js
                      npm start
                      if using pm2, then edit the installers/mm.sh file which what pm2 starts
                      and add the export= line
                      • P Offline
                        pi-user @sdetweil
                        Thank you:thumbs_up_light_skin_tone:
                          sdetweil
                          it doesn’t work… trying to resolve
                            sdetweil
                            if can’t get it to work… MM_CONFIG_FILE (full path to file) reads the right config file, but then
                            still get missing config file…
                            AND you MUST have a config.js in the config folder, or nothing will work…
                            sorry, i give up right now…
