    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    Time wont change even if timezone is correct - WIFI
    Troubleshooting
      seklind last edited by seklind
      Re: Time is not changing
      Im trying to get the right time on my raspberry pi 3 but even if the timezone if correct it wont change the actual clock over WIFI. It works if im connected via ethernet. Has anyone solved this?
      • mochman
        mochman Module Developer last edited by
        Did you try this yet? If so, what other things have you tried?
        • A
          AAPS last edited by
          I have it set up on my raspberry pi 3 too, but I use Ethernet for the whole thing. All I did was go to the menu, and after searching around a bit, I found out how to change the settings for time ( I put EST since I live in the east of the USA). It changed right away. I hope this helps and sorry if it doesn’t.
            Thanks for the answers, had a bit of vacation during christmas but will sure try this! Will come back with results in a while 🙂
            • A
              AAPS last edited by
              By the way, have you set up motion detection? I am trying to, but I don’t have any idea what to do. Do you know?
                seklind @AAPS last edited by
                @AAPS hey! I havent done that yet but i think i will do, will keep you posted when im done, BTW check this one out https://helentronica.com/2016/01/11/magic-mirror-with-motion-detector/
