    Update MMM
    75 Posts 8 Posters 55.2k Views 9 Watching
    • M
      mattx38
      Hello,
      I juste saw there is an update of MMM.
      I try to launch the " git pull && npm install " command but I have a warning message that the following packages would be crushed :
      -package-lock.json
      -package.json
      Then, how can I manage updating my MMM ?
        sdetweil @mattx38
        @mattx38 erase package-lock.json
        Did u modify package.json?
        And git checkout package.json to restore it if u are ok w that
        M 2 Replies Last reply
        • M
          mattx38
          don’t remember doing so…
          I’m backuping my whole “MagicMirror” folder from the pi.
          • StoffbeuteluweS
            Stoffbeuteluwe Project Sponsor
            patrickhahn@Patricks-Mini MagicMirror % git pull
            Updating 5bf90ae..447c0bf
            Fast-forward
             .eslintrc.json                                     |    1 +
             .github/ISSUE_TEMPLATE.md                          |   21 +-
             .travis.yml                                        |   27 +-
             CHANGELOG.md                                       |   59 +-
             Gruntfile.js                                       |   13 +-
             clientonly/index.js                                |    2 -
             config/config.js.sample                            |   18 +-
             index.html                                         |    2 +-
             installers/dumpactivemodules.js                    |   15 -
             installers/fixuppm2.sh                             |  183 -
             installers/mm.sh                                   |    1 +
             installers/pm2_MagicMirror.json                    |    7 -
             installers/postinstall/postinstall.sh              |    2 -
             installers/raspberry.sh                            |  569 ---
             installers/screensaveroff.sh                       |  101 -
             installers/upgrade-script.sh                       |  361 --
             js/app.js                                          |   11 +-
             js/electron.js                                     |    2 -
             js/loader.js                                       |    6 +-
             js/main.js                                         |   15 +-
             js/module.js                                       |   11 +-
             js/node_helper.js                                  |    4 +-
             js/server.js                                       |   14 +-
             js/socketclient.js                                 |    8 +-
             modules/README.md                                  |  721 ----
             modules/default/alert/README.md                    |   63 +-
             modules/default/calendar/README.md                 |  105 +-
             modules/default/calendar/calendar.js               |    4 +-
             modules/default/calendar/calendarfetcher.js        |   13 +-
             modules/default/calendar/debug.js                  |    2 +-
             .../default/calendar/vendor/ical.js/node-ical.js   |   15 +-
             modules/default/clock/README.md                    |   54 +-
             modules/default/clock/clock.js                     |   58 +-
             modules/default/clock/clock_screenshot.png         |  Bin 30525 -> 0 bytes
             modules/default/clock/clock_styles.css             |   10 +
             modules/default/compliments/README.md              |  148 +-
             modules/default/compliments/compliments.js         |   41 +-
             .../default/compliments/compliments_screenshot.png |  Bin 26157 -> 0 bytes
             modules/default/currentweather/README.md           |   86 +-
             modules/default/currentweather/currentweather.js   |   23 +-
             .../default/currentweather/weather_screenshot.png  |  Bin 38566 -> 0 bytes
             modules/default/helloworld/README.md               |   23 +-
             modules/default/newsfeed/README.md                 |  104 +-
             modules/default/newsfeed/newsfeed.js               |    5 +-
             modules/default/newsfeed/newsfeed_screenshot.png   |  Bin 45375 -> 0 bytes
             modules/default/updatenotification/README.md       |   24 +-
             modules/default/updatenotification/node_helper.js  |   74 +-
             .../updatenotification/updatenotification.js       |    1 +
             modules/default/weather/README.md                  |  117 +-
             modules/default/weather/current.png                |  Bin 8141 -> 0 bytes
             modules/default/weather/forecast.png               |  Bin 16385 -> 0 bytes
             modules/default/weatherforecast/README.md          |   79 +-
             .../weatherforecast/forecast_screenshot.png        |  Bin 86206 -> 0 bytes
             package-lock.json                                  | 4524 +++++++++-----------
             package.json                                       |   21 +-
             run-start.sh                                       |   67 -
             serveronly/index.js                                |    3 +-
             tests/configs/check_config.js                      |   14 +-
             .../modules/compliments/compliments_date.js        |   41 +
             .../modules/weather/forecastweather_default.js     |   46 +-
             .../modules/weather/forecastweather_options.js     |   52 +-
             tests/e2e/modules/compliments_spec.js              |   15 +
             tests/e2e/modules/mocks/weather_current.js         |   98 +-
             tests/e2e/modules/mocks/weather_forecast.js        |  184 +-
             tests/e2e/modules/weather_spec.js                  |   39 +-
             tests/e2e/vendor_spec.js                           |   15 +-
             tests/node_modules/webdriverajaxstub/index.js      |    4 +-
             tests/unit/functions/currentweather_spec.js        |    1 +
             tests/unit/functions/weatherforecast_spec.js       |    1 +
             translations/fi.json                               |    5 +-
             translations/he.json                               |   36 +
             translations/hr.json                               |    2 +-
             translations/pl.json                               |    3 +-
             translations/pt-br.json                            |    5 +-
             translations/tr.json                               |   14 +-
             translations/translations.js                       |   10 +-
             translations/uk.json                               |   36 +
             untrack-css.sh                                     |   11 -
             78 files changed, 2680 insertions(+), 5790 deletions(-)
             mode change 100755 => 100644 CHANGELOG.md
             delete mode 100644 installers/dumpactivemodules.js
             delete mode 100755 installers/fixuppm2.sh
             delete mode 100644 installers/pm2_MagicMirror.json
             delete mode 100644 installers/postinstall/postinstall.sh
             delete mode 100755 installers/raspberry.sh
             delete mode 100755 installers/screensaveroff.sh
             delete mode 100755 installers/upgrade-script.sh
             delete mode 100644 modules/README.md
             delete mode 100644 modules/default/clock/clock_screenshot.png
             delete mode 100644 modules/default/compliments/compliments_screenshot.png
             delete mode 100644 modules/default/currentweather/weather_screenshot.png
             delete mode 100644 modules/default/newsfeed/newsfeed_screenshot.png
             delete mode 100644 modules/default/weather/current.png
             delete mode 100644 modules/default/weather/forecast.png
             delete mode 100644 modules/default/weatherforecast/forecast_screenshot.png
             delete mode 100755 run-start.sh
             create mode 100644 tests/configs/modules/compliments/compliments_date.js
             create mode 100644 translations/he.json
             create mode 100644 translations/uk.json
             delete mode 100755 untrack-css.sh
            patrickhahn@Patricks-Mini MagicMirror % npm install
            npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
            npm WARN ws@7.2.1 requires a peer of bufferutil@^4.0.1 but none is installed. You must install peer dependencies yourself.
            npm WARN ws@7.2.1 requires a peer of utf-8-validate@^5.0.2 but none is installed. You must install peer dependencies yourself.
            npm ERR! path /Users/patrickhahn/MagicMirror/node_modules/.bin/jsonlint
            npm ERR! code EEXIST
            npm ERR! Refusing to delete /Users/patrickhahn/MagicMirror/node_modules/.bin/jsonlint: ../jsonlint/lib/cli.js symlink target is not controlled by npm /Users/patrickhahn/MagicMirror/node_modules/@prantlf/jsonlint
            npm ERR! File exists: /Users/patrickhahn/MagicMirror/node_modules/.bin/jsonlint
            npm ERR! Move it away, and try again.
            npm ERR!     /Users/patrickhahn/.npm/_logs/2020-04-01T16_02_31_101Z-debug.log
            i have some errors to…need help please
            thanks
              sdetweil @Stoffbeuteluwe
              @Stoffbeuteluwe erase that jsonlint file, and npm install again
              StoffbeuteluweS 1 Reply Last reply
              • M
                mattx38 @sdetweil
                @sdetweil How can I acknowledge the update anyway (it will overwrite the two files) ?
                  sdetweil @mattx38
                  @mattx38 it will not overwrite
                  U have to do the two commands I said before
                  • M
                    mattx38 @sdetweil
                    @sdetweil said in Update MMM:
                    Ok, I erased the package-lock.json file.
                    What command should I use to check package.json ?
                    I’m a beginner…
                      sdetweil @mattx38
                      @mattx38 do
                      cd ~/MagicMirror
                      M 1 Reply Last reply
                      Reply Quote 1
                      • StoffbeuteluweS
                        Stoffbeuteluwe Project Sponsor @sdetweil
                        @sdetweil Perfect Sam thanks…
                        • M
                          mattx38 @sdetweil
                          @mattx38 do
                          cd ~/MagicMirror
                          I did it but the command did not return any information.
                            @Stoffbeuteluwe you guys should really use my upgrade script
                            see here https://github.com/sdetweil/MagicMirror_scripts
                            • M
                              mattx38
                              I did the “npm install”.
                              I fixed 2 moderate vulnerabilities and it still remains 8 low severity vulnerabilities.
                              I don’t get if this can have consequences or not.
                                sdetweil @mattx38
                                @mattx38 don’t worry about the audit stuff… does it run?
                                • M
                                  mattx38
                                  No, the mirror stays black with the mouse arrow in the left upper corner.
                                  I did a reboot and a “pm2 restart mm”, but nothing works…
                                    sdetweil @mattx38
                                    @mattx38
                                    pm2 stop mm
                                    cd ~/magicMirror
                                    npm start dev
                                    alt-spacebar, n to minimize MM,… any messages on the terminal window?
                                    select the MM window to reopen, select the console, and scroll up to see if any errors…
                                    there is a fatal one somewhere
                                    • M
                                      mattx38
                                      Yes there is an error in red :
                                      [2020-04-01 22:06:21.797] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
                                      was compiled against a different Node.js version using
                                      NODE_MODULE_VERSION 64. This version of Node.js requires
                                      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                                      the module (for instance, using npm rebuild or npm install).
                                      and other errors still with PIR module, but the errors are written in white
                                      EDIT : I try a “npm rebuild” ?
                                        sdetweil @mattx38
                                        @mattx38 pir is a pain in the rear… I would disable it in config.js for now
                                        add
                                        disabled:true,
                                        after module:“MMM-PIR-Sensor”,
                                        • M
                                          mattx38
                                          Done.
                                          I did again a “npm start dev” and I have new errors written in red :
                                          [2020-04-01 22:14:46.668] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                                          Require stack:
                                          • /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                                          • /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                          • /home/pi/MagicMirror/js/app.js
                                          • /home/pi/MagicMirror/js/electron.js
                                          • /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                            sdetweil @mattx38
                                            @mattx38 yep, snowboy is broke too… disable MMM-Hotword
                                            • 1 / 4
