    Update MMM
    75 Posts 8 Posters 39.7k Views 9 Watching
    • P Offline
      Peter Leemon
      yes that worked thank you, just have figure out how to update google photos to update now.
      • P Offline
        Peter Leemon
        have just done a git pull and npm install in MMM-GooglePhotos module now the MM has a black screen everything else is working just no images showing
          sdetweil @Peter Leemon
          @Peter-Leemon did u npm install in the GooglePhotos folder?
          Open the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
          • P Offline
            Peter Leemon
            is that in MagicMirror/modules/MMM-GooglePhotos or just in pi@raspberrypi folder?
              @Peter-Leemon said in Update MMM:
              the dev window is on the MM screen itself…
              or start MM with npm start dev and then select the console tab on the MM screen
              • P Offline
                Peter Leemon
                I’ve also noticed the Calendar doesnt update any events added either in apple calendar or google calendar
                  @Peter-Leemon i will have to check that tomorrow… I haven’t done any testing except to update my install and update scripts for v 2.11.
                  • P Offline
                    Peter Leemon
                    Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
                    Thank you
                      jims
                      hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
                        jims
                        doesn t work… already black screen… I have PIR Sensor too
                        I did this :
                        login as: pi
                        pi@192.168.1.18's password:
                        Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                        The programs included with the Debian GNU/Linux system are free software;
                        the exact distribution terms for each program are described in the
                        individual files in /usr/share/doc/*/copyright.
                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                        permitted by applicable law.
                        Last login: Thu Apr  2 09:55:59 2020 from 192.168.1.11
                        pi@raspberrypi:~ $ cd MagicMirror/
                        pi@raspberrypi:~/MagicMirror $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                        fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                        pi@raspberrypi:/ $ git checkout modules/node_modules/node_helper/index.js       fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                        pi@raspberrypi:/ $
                        pi@raspberrypi:/ $
                        login as: pi
                        Last login: Thu Apr  2 10:20:36 2020
                        pi@raspberrypi:~ $
                        pi@raspberrypi:~/MagicMirror $ npm stop
                        npm ERR! missing script: stop
                        npm ERR!     /home/pi/.npm/_logs/2020-04-02T08_23_06_473Z-debug.log
                        pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                        [PM2][ERROR] Process or Namespace mm not found
                          error: missing required argument `id|name|namespace|all|json|stdin'
                        pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                        [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                        [PM2] [MagicMirror](0) ✓
                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                        │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                        pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                        #: “#!/bin/bash: Aucun fichier ou dossier de ce type
                        pi@raspberrypi:~/MagicMirror $ cd ..
                        pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                \______/
                        install log being saved to /home/pi/install.log
                        Updating packages ...
                        Installing helper tools ...
                        Check current Node installation ...
                        Node currently installed. Checking version number.
                        Minimum Node version: v10.1.0
                        Installed Node version: v10.15.2
                        No Node.js upgrade necessary.
                        Check current NPM installation ...
                        NPM currently installed. Checking version number.
                        Minimum npm version: V6.0.0
                        Installed npm version: V6.13.6
                        No npm upgrade necessary.
                        It seems like MagicMirror is already installed.
                        To prevent overwriting, the installer will be aborted.
                        Please rename the ~/MagicMirror folder and try again.
                        If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        the log will be /home/pi/MagicMirror/installers/upgrade.log
                        No LSB modules are available.
                        doing test run = true
                        update log will be in /home/pi/MagicMirror/installers/upgrade.log
                        upgrading from version 2.11.0 to 2.11.0
                        fetching latest revisions
                        there are 1 local files that are different than the master repo
                           package-lock.json
                        any *-lock.json files do not need to be saved
                        do you want to save these files for later   (Y/n)?y
                        processing dependency changes for active modules with package.json files
                        processing for module MMM-Selfieshot please wait
                        skipped processing for MMM-Selfieshot, doing test run
                        processing complete for module MMM-Selfieshot
                        processing for module MMM-Strava please wait
                        skipped processing for MMM-Strava, doing test run
                        processing complete for module MMM-Strava
                        processing for module MMM-PIR-Sensor please wait
                        skipped processing for MMM-PIR-Sensor, doing test run
                        processing complete for module MMM-PIR-Sensor
                        processing for module MMM-Spotify please wait
                        skipped processing for MMM-Spotify, doing test run
                        processing complete for module MMM-Spotify
                        processing for module MMM-Hotword please wait
                        skipped processing for MMM-Hotword, doing test run
                        processing complete for module MMM-Hotword
                        processing for module MMM-AssistantMk2 please wait
                        skipped processing for MMM-AssistantMk2, doing test run
                        processing complete for module MMM-AssistantMk2
                        test run, restoring files stashed
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                        doing test run = false
                        local version 2.11.0 already same as master 2.11.0
                        pi@raspberrypi:~ $ npm start
                        npm ERR! code ENOENT
                        npm ERR! syscall open
                        npm ERR! path /home/pi/package.json
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/pi/.npm/_logs/2020-04-02T09_03_45_797Z-debug.log
                        pi@raspberrypi:~ $ sudo reboot
                        pi@raspberrypi:~ $
                        login as: pi
                        Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
                        Last login: Thu Apr  2 11:04:36 2020
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                        server does not have extension for -dpms option
                        pi@raspberrypi:~ $
                        pi@raspberrypi:~ $ fixuppm2.sh
                        -bash: fixuppm2.sh : commande introuvable
                        pi@raspberrypi:~ $ pm2 stop mm
                        ^C
                        pi@raspberrypi:~ $ pm2 stop MagicMirror
                        pi@raspberrypi:~ $
                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                        the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                        removed 207 packages in 17.491s
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/pm2/node_modules/fsevents):
                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                        [PM2][ERROR] File /home/pi/MagicMirror/installers/pm2_MagicMirror.json not found
                        [PM2] Saving current process list...
                        [PM2][WARN] PM2 is not managing any process, skipping save...
                        [PM2][WARN] To force saving use: pm2 save --force
                        • 6
                        • 7
                        • 8
                        • 6 / 8
