    Update MMM
    75 Posts 8 Posters 55.6k Views 9 Watching
      Peter Leemon @sdetweil
      @sdetweil said in Update MMM:
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
      sorry a noob here do i run this in terminal?
        sdetweil @Peter Leemon
        @Peter-Leemon yes, stop MM first of course
          Peter Leemon
          when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
            @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
            need the trailing quote too
              Peter Leemon
              pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              the log will be /home/pi/MagicMirror/installers/upgrade.log
              No LSB modules are available.
              doing test run = true
              upgrading from version 2.10.1 to 2.11.0
              fetching latest revisions
              there are 3 local files that are different than the master repo
              modules/default/calendar/calendar.js
              modules/default/compliments/compliments.js
              package-lock.json
              any *-lock.json files do not need to be saved
              do you want to save these files for later (Y/n)?y
              processing for module MMM-NOAA3 please wait
              skipped processing for MMM-NOAA3, doing test run
              processing complete for module MMM-NOAA3
              processing for module MMM-EARTH please wait
              skipped processing for MMM-EARTH, doing test run
              processing complete for module MMM-EARTH
              processing for module MMM-GooglePhotos please wait
              skipped processing for MMM-GooglePhotos, doing test run
              processing complete for module MMM-GooglePhotos
              test run, restoring files stashed
              pi@raspberrypi:~ $
              Is this correct?
                @Peter-Leemon said in Update MMM:
                yes, now add ‘apply’’
                no changes are made to the local repo or the working copy
                if you WANT to actually apply the changes do
                bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                BUT
                package-lock.json
                I assume u might want to save those changed files…
                  Peter Leemon
                  yes that worked thank you, just have figure out how to update google photos to update now.
                    Peter Leemon
                    have just done a git pull and npm install in MMM-GooglePhotos module now the MM has a black screen everything else is working just no images showing
                      @Peter-Leemon did u npm install in the GooglePhotos folder?
                      Open the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
                        Peter Leemon
                        is that in MagicMirror/modules/MMM-GooglePhotos or just in pi@raspberrypi folder?
                          the dev window is on the MM screen itself…
                          or start MM with npm start dev and then select the console tab on the MM screen
                            Peter Leemon
                            I’ve also noticed the Calendar doesnt update any events added either in apple calendar or google calendar
                              @Peter-Leemon i will have to check that tomorrow… I haven’t done any testing except to update my install and update scripts for v 2.11.
                                Peter Leemon
                                Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
                                Thank you
                                  jims
                                  hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
                                    jims
                                    doesn t work… already black screen… I have PIR Sensor too
                                    I did this :
                                    login as: pi
                                    pi@192.168.1.18's password:
                                    Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                                    The programs included with the Debian GNU/Linux system are free software;
                                    the exact distribution terms for each program are described in the
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Thu Apr  2 09:55:59 2020 from 192.168.1.11
                                    pi@raspberrypi:~ $ cd MagicMirror/
                                    pi@raspberrypi:~/MagicMirror $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                    fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                    pi@raspberrypi:/ $ git checkout modules/node_modules/node_helper/index.js       fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                    pi@raspberrypi:/ $
                                    pi@raspberrypi:/ $
                                    login as: pi
                                    Last login: Thu Apr  2 10:20:36 2020
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~/MagicMirror $ npm stop
                                    npm ERR! missing script: stop
                                    npm ERR!     /home/pi/.npm/_logs/2020-04-02T08_23_06_473Z-debug.log
                                    pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                    [PM2][ERROR] Process or Namespace mm not found
                                      error: missing required argument `id|name|namespace|all|json|stdin'
                                    pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                                    [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                    [PM2] [MagicMirror](0) ✓
                                    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                    │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                    pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                    #: “#!/bin/bash: Aucun fichier ou dossier de ce type
                                    pi@raspberrypi:~/MagicMirror $ cd ..
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                    $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                    $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                    $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                    $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                    $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                    \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                                            \______/
                                    install log being saved to /home/pi/install.log
                                    Updating packages ...
                                    Installing helper tools ...
                                    Minimum Node version: v10.1.0
                                    Installed Node version: v10.15.2
                                    No Node.js upgrade necessary.
                                    Minimum npm version: V6.0.0
                                    Installed npm version: V6.13.6
                                    No npm upgrade necessary.
                                    It seems like MagicMirror is already installed.
                                    To prevent overwriting, the installer will be aborted.
                                    Please rename the ~/MagicMirror folder and try again.
                                    If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                    upgrading from version 2.11.0 to 2.11.0
                                    there are 1 local files that are different than the master repo
                                       package-lock.json
                                    processing for module MMM-Selfieshot please wait
                                    skipped processing for MMM-Selfieshot, doing test run
                                    processing complete for module MMM-Selfieshot
                                    processing for module MMM-Strava please wait
                                    skipped processing for MMM-Strava, doing test run
                                    processing complete for module MMM-Strava
                                    processing for module MMM-PIR-Sensor please wait
                                    skipped processing for MMM-PIR-Sensor, doing test run
                                    processing complete for module MMM-PIR-Sensor
                                    processing for module MMM-Spotify please wait
                                    skipped processing for MMM-Spotify, doing test run
                                    processing complete for module MMM-Spotify
                                    processing for module MMM-Hotword please wait
                                    skipped processing for MMM-Hotword, doing test run
                                    processing complete for module MMM-Hotword
                                    processing for module MMM-AssistantMk2 please wait
                                    skipped processing for MMM-AssistantMk2, doing test run
                                    processing complete for module MMM-AssistantMk2
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                    doing test run = false
                                    local version 2.11.0 already same as master 2.11.0
                                    pi@raspberrypi:~ $ npm start
                                    npm ERR! code ENOENT
                                    npm ERR! syscall open
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/pi/.npm/_logs/2020-04-02T09_03_45_797Z-debug.log
                                    pi@raspberrypi:~ $ sudo reboot
                                    pi@raspberrypi:~ $
                                    login as: pi
                                    Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
                                    Last login: Thu Apr  2 11:04:36 2020
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                                    server does not have extension for -dpms option
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $ fixuppm2.sh
                                    -bash: fixuppm2.sh : commande introuvable
                                    pi@raspberrypi:~ $ pm2 stop mm
                                    ^C
                                    pi@raspberrypi:~ $ pm2 stop MagicMirror
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                    the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                                    removed 207 packages in 17.491s
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/pm2/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    [PM2][ERROR] File /home/pi/MagicMirror/installers/pm2_MagicMirror.json not found
                                    [PM2] Saving current process list...
                                    [PM2][WARN] PM2 is not managing any process, skipping save...
                                    [PM2][WARN] To force saving use: pm2 save --force
                                      jims
                                      And during the update :
                                      pi@raspberrypi:~/MagicMirror $ git pull && npm install
                                      Mise à jour 5bf90ae..447c0bf
                                      Fast-forward
                                       .eslintrc.json                                     |    1 +
                                       .github/ISSUE_TEMPLATE.md                          |   21 +-
                                       .travis.yml                                        |   27 +-
                                       CHANGELOG.md                                       |   59 +-
                                       Gruntfile.js                                       |   13 +-
                                       clientonly/index.js                                |    2 -
                                       config/config.js.sample                            |   18 +-
                                       index.html                                         |    2 +-
                                       installers/dumpactivemodules.js                    |   15 -
                                       installers/fixuppm2.sh                             |  183 -
                                       installers/mm.sh                                   |    1 +
                                       installers/pm2_MagicMirror.json                    |    7 -
                                       installers/postinstall/postinstall.sh              |    2 -
                                       installers/raspberry.sh                            |  569 ---
                                       installers/screensaveroff.sh                       |  101 -
                                       installers/upgrade-script.sh                       |  361 --
                                       js/app.js                                          |   11 +-
                                       js/electron.js                                     |    2 -
                                       js/loader.js                                       |    6 +-
                                       js/main.js                                         |   15 +-
                                       js/module.js                                       |   11 +-
                                       js/node_helper.js                                  |    4 +-
                                       js/server.js                                       |   14 +-
                                       js/socketclient.js                                 |    8 +-
                                       modules/README.md                                  |  721 ----
                                       modules/default/alert/README.md                    |   63 +-
                                       modules/default/calendar/README.md                 |  105 +-
                                       modules/default/calendar/calendar.js               |    4 +-
                                       modules/default/calendar/calendarfetcher.js        |   13 +-
                                       modules/default/calendar/debug.js                  |    2 +-
                                       .../default/calendar/vendor/ical.js/node-ical.js   |   15 +-
                                       modules/default/clock/README.md                    |   54 +-
                                       modules/default/clock/clock.js                     |   58 +-
                                       modules/default/clock/clock_screenshot.png         |  Bin 30525 -> 0 bytes
                                       modules/default/clock/clock_styles.css             |   10 +
                                       modules/default/compliments/README.md              |  148 +-
                                       modules/default/compliments/compliments.js         |   41 +-
                                       .../default/compliments/compliments_screenshot.png |  Bin 26157 -> 0 bytes
                                       modules/default/currentweather/README.md           |   86 +-
                                       modules/default/currentweather/currentweather.js   |   23 +-
                                       .../default/currentweather/weather_screenshot.png  |  Bin 38566 -> 0 bytes
                                       modules/default/helloworld/README.md               |   23 +-
                                       modules/default/newsfeed/README.md                 |  104 +-
                                       modules/default/newsfeed/newsfeed.js               |    5 +-
                                       modules/default/newsfeed/newsfeed_screenshot.png   |  Bin 45375 -> 0 bytes
                                       modules/default/updatenotification/README.md       |   24 +-
                                       modules/default/updatenotification/node_helper.js  |   74 +-
                                       .../updatenotification/updatenotification.js       |    1 +
                                       modules/default/weather/README.md                  |  117 +-
                                       modules/default/weather/current.png                |  Bin 8141 -> 0 bytes
                                       modules/default/weather/forecast.png               |  Bin 16385 -> 0 bytes
                                       modules/default/weatherforecast/README.md          |   79 +-
                                       .../weatherforecast/forecast_screenshot.png        |  Bin 86206 -> 0 bytes
                                       package-lock.json                                  | 4524 +++++++++-----------
                                       package.json                                       |   21 +-
                                       run-start.sh                                       |   67 -
                                       serveronly/index.js                                |    3 +-
                                       tests/configs/check_config.js                      |   14 +-
                                       .../modules/compliments/compliments_date.js        |   41 +
                                       .../modules/weather/forecastweather_default.js     |   46 +-
                                       .../modules/weather/forecastweather_options.js     |   52 +-
                                       tests/e2e/modules/compliments_spec.js              |   15 +
                                       tests/e2e/modules/mocks/weather_current.js         |   98 +-
                                       tests/e2e/modules/mocks/weather_forecast.js        |  184 +-
                                       tests/e2e/modules/weather_spec.js                  |   39 +-
                                       tests/e2e/vendor_spec.js                           |   15 +-
                                       tests/node_modules/webdriverajaxstub/index.js      |    4 +-
                                       tests/unit/functions/currentweather_spec.js        |    1 +
                                       tests/unit/functions/weatherforecast_spec.js       |    1 +
                                       translations/fi.json                               |    5 +-
                                       translations/he.json                               |   36 +
                                       translations/hr.json                               |    2 +-
                                       translations/pl.json                               |    3 +-
                                       translations/pt-br.json                            |    5 +-
                                       translations/tr.json                               |   14 +-
                                       translations/translations.js                       |   10 +-
                                       translations/uk.json                               |   36 +
                                       untrack-css.sh                                     |   11 -
                                       78 files changed, 2680 insertions(+), 5790 deletions(-)
                                       mode change 100755 => 100644 CHANGELOG.md
                                       delete mode 100644 installers/dumpactivemodules.js
                                       delete mode 100755 installers/fixuppm2.sh
                                       delete mode 100644 installers/pm2_MagicMirror.json
                                       delete mode 100644 installers/postinstall/postinstall.sh
                                       delete mode 100755 installers/raspberry.sh
                                       delete mode 100755 installers/screensaveroff.sh
                                       delete mode 100755 installers/upgrade-script.sh
                                       delete mode 100644 modules/README.md
                                       delete mode 100644 modules/default/clock/clock_screenshot.png
                                       delete mode 100644 modules/default/compliments/compliments_screenshot.png
                                       delete mode 100644 modules/default/currentweather/weather_screenshot.png
                                       delete mode 100644 modules/default/newsfeed/newsfeed_screenshot.png
                                       delete mode 100644 modules/default/weather/current.png
                                       delete mode 100644 modules/default/weather/forecast.png
                                       delete mode 100644 modules/default/weatherforecast/forecast_screenshot.png
                                       delete mode 100755 run-start.sh
                                       create mode 100644 tests/configs/modules/compliments/compliments_date.js
                                       create mode 100644 translations/he.json
                                       create mode 100644 translations/uk.json
                                       delete mode 100755 untrack-css.sh
                                      npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition.                                      vfile-message provides its own type definitions, so you do not need this instal                                     led.
                                      > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron                                     -chromedriver
                                      > node ./download-chromedriver.js
                                      > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
                                      > node install.js
                                      Downloading tmp-1525-1-SHASUMS256.txt-6.1.7
                                      [============================================>] 100.0% of 5.56 kB (5.56 kB/s)
                                      > magicmirror@2.11.0 install /home/pi/MagicMirror
                                      " && cd vendor && npm install --loglevel=error
                                      audited 220 packages in 25.414s
                                      found 8 vulnerabilities (7 low, 1 high)
                                        run `npm audit fix` to fix them, or `npm audit` for details
                                      > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                                      > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                      > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                                      > echo "Installing fonts ...
                                      " && cd fonts && npm install --loglevel=error
                                      audited 1 package in 3.182s
                                      found 0 vulnerabilities
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fse                                     vents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                     2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                     )
                                      added 124 packages from 84 contributors, removed 79 packages, updated 54 package                                     s and moved 1 package in 774.482s
                                      26 packages are looking for funding
                                        run `npm fund` for details
                                      pi@raspberrypi:~/MagicMirror $ sudo reboot
                                      npm ERR! errno -2
                                      npm ERR! enoent
                                      npm ERR!     /home/pi/.npm/_logs/2020-04-02T07_56_36_218Z-debug.log
                                      > magicmirror@2.11.0 start /home/pi/MagicMirror
                                      [2020-04-02 09:57:00.458] [LOG]    Starting MagicMirror: v2.11.0
                                      [2020-04-02 09:57:00.477] [LOG]    Loading config ...
                                      [2020-04-02 09:57:00.488] [LOG]    Loading module helpers ...
                                      [2020-04-02 09:57:00.492] [LOG]    No helper found for module: alert.
                                      [2020-04-02 09:57:00.601] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:00.604] [LOG]    Module helper loaded: updatenotification
                                      [2020-04-02 09:57:00.607] [LOG]    No helper found for module: clock.
                                      [2020-04-02 09:57:01.480] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:01.481] [LOG]    Module helper loaded: calendar
                                      [2020-04-02 09:57:01.700] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:01.703] [LOG]    Module helper loaded: MMM-Selfieshot
                                      [2020-04-02 09:57:01.705] [LOG]    No helper found for module: compliments.
                                      [2020-04-02 09:57:01.708] [LOG]    No helper found for module: currentweather.
                                      [2020-04-02 09:57:01.711] [LOG]    No helper found for module: weatherforecast.
                                      [2020-04-02 09:57:02.820] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:02.822] [LOG]    Check MagicMirror version for node helper 'MM                                     M-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                      [2020-04-02 09:57:02.823] [LOG]    Version is ok!
                                      [2020-04-02 09:57:02.824] [LOG]    Module helper loaded: MMM-Strava
                                      [2020-04-02 09:57:02.861] [ERROR]  WARNING! Could not load config file. Starting                                      with default configuration. Error found: Error: The module '/home/pi/MagicMirro                                     r/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                      was compiled against a different Node.js version using
                                      NODE_MODULE_VERSION 64. This version of Node.js requires
                                      NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                                      the module (for instance, using `npm rebuild` or `npm install`).
                                      [2020-04-02 09:57:02.864] [LOG]    Loading module helpers ...
                                      [2020-04-02 09:57:02.867] [LOG]    No helper found for module: alert.
                                      [2020-04-02 09:57:02.869] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:02.871] [LOG]    Module helper loaded: updatenotification
                                      [2020-04-02 09:57:02.873] [LOG]    No helper found for module: clock.
                                      [2020-04-02 09:57:02.875] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:02.877] [LOG]    Module helper loaded: calendar
                                      [2020-04-02 09:57:02.878] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:02.879] [LOG]    Module helper loaded: MMM-Selfieshot
                                      [2020-04-02 09:57:02.881] [LOG]    No helper found for module: compliments.
                                      [2020-04-02 09:57:02.882] [LOG]    No helper found for module: currentweather.
                                      [2020-04-02 09:57:02.883] [LOG]    No helper found for module: weatherforecast.
                                      [2020-04-02 09:57:02.884] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:57:02.885] [LOG]    Check MagicMirror version for node helper 'MM                                     M-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                      [2020-04-02 09:57:02.886] [LOG]    Version is ok!
                                      [2020-04-02 09:57:02.887] [LOG]    Module helper loaded: MMM-Strava
                                      [2020-04-02 09:57:02.899] [ERROR]  App threw an error during load
                                      [2020-04-02 09:57:02.902] [ERROR]  Error: The module '/home/pi/MagicMirror/modul                                     es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                          at process.func (electron/js2c/asar.js:138:31)
                                          at process.func [as dlopen] (electron/js2c/asar.js:138:31)
                                          at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
                                          at Object.func (electron/js2c/asar.js:138:31)
                                          at Object.func [as .node] (electron/js2c/asar.js:138:31)
                                          at Module.load (internal/modules/cjs/loader.js:645:32)
                                          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                          at Module.require (internal/modules/cjs/loader.js:685:19)
                                          at require (internal/modules/cjs/helpers.js:16:16)
                                          at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin                                     gs/bindings.js:112:48)
                                          at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7                                     :31
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu                                     les/epoll/epoll.js:15:3)
                                          at Module._compile (internal/modules/cjs/loader.js:786:30)
                                          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu                                     les/onoff/onoff.js:5:15)
                                      [2020-04-02 09:57:02.907] [LOG]    Whoops! There was an uncaught exception...
                                      [2020-04-02 09:57:02.909] [ERROR]  Error: The module '/home/pi/MagicMirror/modul                                     es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                      [2020-04-02 09:57:02.917] [LOG]    MagicMirror will not quit, but it might be a                                      good idea to check why this happened. Maybe no internet connection?
                                      [2020-04-02 09:57:02.918] [LOG]    If you think this really is an issue, please                                      open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      [2020-04-02 09:57:03.080] [LOG]    Launching application.
                                      ^C[2020-04-02 09:59:16.827] [LOG]    Shutting down server...
                                      [2020-04-02 09:59:16.835] [LOG]    Stopping module helper: updatenotification
                                      [2020-04-02 09:59:16.836] [LOG]    Stopping module helper: calendar
                                      [2020-04-02 09:59:16.837] [LOG]    Stopping module helper: MMM-Selfieshot
                                      [2020-04-02 09:59:16.838] [LOG]    Stopping module helper: MMM-Strava
                                      [2020-04-02 09:59:16.839] [LOG]    Stopping module helper: updatenotification
                                      [2020-04-02 09:59:16.840] [LOG]    Stopping module helper: calendar
                                      [2020-04-02 09:59:16.842] [LOG]    Stopping module helper: MMM-Selfieshot
                                      [2020-04-02 09:59:16.843] [LOG]    Stopping module helper: MMM-Strava
                                      [2020-04-02 09:59:39.647] [LOG]    Starting MagicMirror: v2.11.0
                                      [2020-04-02 09:59:39.665] [LOG]    Loading config ...
                                      [2020-04-02 09:59:39.675] [LOG]    Loading module helpers ...
                                      [2020-04-02 09:59:39.682] [LOG]    No helper found for module: alert.
                                      [2020-04-02 09:59:39.796] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:39.798] [LOG]    Module helper loaded: updatenotification
                                      [2020-04-02 09:59:39.799] [LOG]    No helper found for module: clock.
                                      [2020-04-02 09:59:40.636] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:40.637] [LOG]    Module helper loaded: calendar
                                      [2020-04-02 09:59:40.856] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:40.858] [LOG]    Module helper loaded: MMM-Selfieshot
                                      [2020-04-02 09:59:40.861] [LOG]    No helper found for module: compliments.
                                      [2020-04-02 09:59:40.862] [LOG]    No helper found for module: currentweather.
                                      [2020-04-02 09:59:40.864] [LOG]    No helper found for module: weatherforecast.
                                      [2020-04-02 09:59:41.992] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:41.994] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                      [2020-04-02 09:59:41.996] [LOG]    Version is ok!
                                      [2020-04-02 09:59:41.997] [LOG]    Module helper loaded: MMM-Strava
                                      [2020-04-02 09:59:42.049] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.051] [LOG]    Module helper loaded: newsfeed
                                      [2020-04-02 09:59:42.054] [LOG]    No helper found for module: MMM-YouTube.
                                      [2020-04-02 09:59:42.074] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.076] [LOG]    Module helper loaded: MMM-Spotify
                                      [2020-04-02 09:59:42.382] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                      Require stack:
                                      - /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                                      - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                      [2020-04-02 09:59:42.385] [LOG]    Loading module helpers ...
                                      [2020-04-02 09:59:42.388] [LOG]    No helper found for module: alert.
                                      [2020-04-02 09:59:42.391] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.392] [LOG]    Module helper loaded: updatenotification
                                      [2020-04-02 09:59:42.394] [LOG]    No helper found for module: clock.
                                      [2020-04-02 09:59:42.396] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.397] [LOG]    Module helper loaded: calendar
                                      [2020-04-02 09:59:42.398] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.398] [LOG]    Module helper loaded: MMM-Selfieshot
                                      [2020-04-02 09:59:42.400] [LOG]    No helper found for module: compliments.
                                      [2020-04-02 09:59:42.401] [LOG]    No helper found for module: currentweather.
                                      [2020-04-02 09:59:42.402] [LOG]    No helper found for module: weatherforecast.
                                      [2020-04-02 09:59:42.403] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.404] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                      [2020-04-02 09:59:42.405] [LOG]    Version is ok!
                                      [2020-04-02 09:59:42.406] [LOG]    Module helper loaded: MMM-Strava
                                      [2020-04-02 09:59:42.407] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.408] [LOG]    Module helper loaded: newsfeed
                                      [2020-04-02 09:59:42.410] [LOG]    No helper found for module: MMM-YouTube.
                                      [2020-04-02 09:59:42.412] [LOG]    Initializing new module helper ...
                                      [2020-04-02 09:59:42.414] [LOG]    Module helper loaded: MMM-Spotify
                                      [2020-04-02 09:59:42.428] [ERROR]  App threw an error during load
                                      [2020-04-02 09:59:42.429] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                      Require stack:
                                          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js:8:29)
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18)
                                          at loadModule (/home/pi/MagicMirror/js/app.js:131:17)
                                          at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
                                      [2020-04-02 09:59:42.432] [LOG]    Whoops! There was an uncaught exception...
                                      [2020-04-02 09:59:42.433] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                      Require stack:
                                          at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [
                                          '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js',
                                          '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                          '/home/pi/MagicMirror/js/app.js',
                                          '/home/pi/MagicMirror/js/electron.js',
                                          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                          undefined
                                      [2020-04-02 09:59:42.447] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [2020-04-02 09:59:42.449] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      [2020-04-02 09:59:42.629] [LOG]    Launching application.
                                      ^C[2020-04-02 10:01:17.981] [LOG]    Shutting down server...
                                      [2020-04-02 10:01:17.990] [LOG]    Stopping module helper: updatenotification
                                      [2020-04-02 10:01:17.992] [LOG]    Stopping module helper: calendar
                                      [2020-04-02 10:01:17.993] [LOG]    Stopping module helper: MMM-Selfieshot
                                      [2020-04-02 10:01:17.994] [LOG]    Stopping module helper: MMM-Strava
                                      [2020-04-02 10:01:17.996] [LOG]    Stopping module helper: newsfeed
                                      [2020-04-02 10:01:17.997] [LOG]    Stopping module helper: MMM-Spotify
                                      [2020-04-02 10:01:17.999] [LOG]    Stopping module helper: updatenotification
                                      [2020-04-02 10:01:18.001] [LOG]    Stopping module helper: calendar
                                      [2020-04-02 10:01:18.003] [LOG]    Stopping module helper: MMM-Selfieshot
                                      [2020-04-02 10:01:18.005] [LOG]    Stopping module helper: MMM-Strava
                                      [2020-04-02 10:01:18.007] [LOG]    Stopping module helper: newsfeed
                                      [2020-04-02 10:01:18.009] [LOG]    Stopping module helper: MMM-Spotify
                                      Déjà à jour.
                                      pi@raspberrypi:~/MagicMirror $ apt-get update
                                      Lecture des listes de paquets... Fait
                                      E: Impossible d'ouvrir le fichier verrou /var/lib/apt/lists/lock - open (13: Permission non accordée)
                                      E: Impossible de verrouiller le répertoire /var/lib/apt/lists/
                                      W: Problème de suppression du lien /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission non accordée)
                                      W: Problème de suppression du lien /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission non accordée)
                                      pi@raspberrypi:~ $ apt-get update
                                      pi@raspberrypi:~ $ ^C
                                      pi@raspberrypi:~ $ cmd": "cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                      -bash: cmd: cd : commande introuvable
                                      pi@raspberrypi:~ $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                      pi@raspberrypi:/ $ ls
                                      bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
                                      pi@raspberrypi:/ $
                                      Thanks for help…
                                        jims
                                        after had followed the explanations page 3, the mirror is okay.
                                        But, he seems that jarvis doesn’t work as before… when I say ‘what time is it’ he open a windows with the google search haha but otherwize the over questions are ok, jarvis answer correctly.
                                        After, The module spotify doesn t work and PIR sensor… I will check it
                                        sorry for my english, i m french
                                          minomit
                                          Some problem:
                                          git pull
                                          Updating 5bf90ae…447c0bf
                                          error: Your local changes to the following files would be overwritten by merge:
                                          package-lock.json
                                          Please commit your changes or stash them before you merge.
                                          Aborting
                                          help me please, thanks
                                            sdetweil @jims
                                            @jims said in Update MMM:
                                            if at the same level u have to use ‘force’ as ‘apply’ will stop if the same level
                                            always start MM from the ~/MagicMirror folder, not the users home folder
                                            • 3 / 4
