    Update MMM
    75 Posts 8 Posters 53.3k Views 9 Watching
      sdetweil @mattx38
      @mattx38 cool. My update script would have fixed PIR problem. But not assistant or hotword
        Peter Leemon
        HI all I’m getting the following message on my MM screen “MagicMirror2 update available” then underneath “The current installation is 2994 comments behind on the master branch”
        Anyone know how to resolve this issue?
          sdetweil @Peter Leemon
          @Peter-Leemon run my update script from here
            Peter Leemon @sdetweil
            @sdetweil run the first script?
              @Peter-Leemon
              upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
              it should handle all the work… and give you a trial run of all that…
              only applying changes if u request them
              give it a try this works on Mac as well
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              no changes are made to the local repo or the working copy
              if you WANT to actually apply the changes do
              bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
              there is a log file (upgrade.log) in the MagicMirror/installers folder…
                @sdetweil said in Update MMM:
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                sorry a noob here do i run this in terminal?
                  @Peter-Leemon yes, stop MM first of course
                    Peter Leemon
                    when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
                      @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
                      need the trailing quote too
                        Peter Leemon
                        pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                        the log will be /home/pi/MagicMirror/installers/upgrade.log
                        No LSB modules are available.
                        doing test run = true
                        upgrading from version 2.10.1 to 2.11.0
                        fetching latest revisions
                        there are 3 local files that are different than the master repo
                        modules/default/calendar/calendar.js
                        modules/default/compliments/compliments.js
                        package-lock.json
                        any *-lock.json files do not need to be saved
                        do you want to save these files for later (Y/n)?y
                        processing for module MMM-NOAA3 please wait
                        skipped processing for MMM-NOAA3, doing test run
                        processing complete for module MMM-NOAA3
                        processing for module MMM-EARTH please wait
                        skipped processing for MMM-EARTH, doing test run
                        processing complete for module MMM-EARTH
                        processing for module MMM-GooglePhotos please wait
                        skipped processing for MMM-GooglePhotos, doing test run
                        processing complete for module MMM-GooglePhotos
                        test run, restoring files stashed
                        pi@raspberrypi:~ $
                        Is this correct?
                          @Peter-Leemon said in Update MMM:
                          yes, now add ‘apply’’
                          BUT
                          package-lock.json
                          I assume u might want to save those changed files…
                            Peter Leemon
                            yes that worked thank you, just have figure out how to update google photos to update now.
                              Peter Leemon
                              have just done a git pull and npm install in MMM-GooglePhotos module now the MM has a black screen everything else is working just no images showing
                                @Peter-Leemon did u npm install in the GooglePhotos folder?
                                Open the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
                                  Peter Leemon
                                  is that in MagicMirror/modules/MMM-GooglePhotos or just in pi@raspberrypi folder?
                                    the dev window is on the MM screen itself…
                                    or start MM with npm start dev and then select the console tab on the MM screen
                                      Peter Leemon
                                      I’ve also noticed the Calendar doesnt update any events added either in apple calendar or google calendar
                                        @Peter-Leemon i will have to check that tomorrow… I haven’t done any testing except to update my install and update scripts for v 2.11.
                                          Peter Leemon
                                          Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
                                          Thank you
                                            jims
                                            hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
                                            • 3 / 4
