    Update MMM
    75 Posts 8 Posters 55.6k Views 9 Watching
      Peter Leemon
      HI all I’m getting the following message on my MM screen “MagicMirror2 update available” then underneath “The current installation is 2994 comments behind on the master branch”
      Anyone know how to resolve this issue?
        sdetweil @Peter Leemon
        @Peter-Leemon run my update script from here
        P 1 Reply Last reply
          Peter Leemon @sdetweil
          @sdetweil run the first script?
            @Peter-Leemon
            upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
            it should handle all the work… and give you a trial run of all that…
            only applying changes if u request them
            give it a try this works on Mac as well
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            no changes are made to the local repo or the working copy
            if you WANT to actually apply the changes do
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            there is a log file (upgrade.log) in the MagicMirror/installers folder…
              @sdetweil said in Update MMM:
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              sorry a noob here do i run this in terminal?
                @Peter-Leemon yes, stop MM first of course
                  Peter Leemon
                  when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
                    @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
                    need the trailing quote too
                      Peter Leemon
                      pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                      No LSB modules are available.
                      doing test run = true
                      upgrading from version 2.10.1 to 2.11.0
                      fetching latest revisions
                      there are 3 local files that are different than the master repo
                      modules/default/calendar/calendar.js
                      modules/default/compliments/compliments.js
                      package-lock.json
                      any *-lock.json files do not need to be saved
                      do you want to save these files for later (Y/n)?y
                      processing for module MMM-NOAA3 please wait
                      skipped processing for MMM-NOAA3, doing test run
                      processing complete for module MMM-NOAA3
                      processing for module MMM-EARTH please wait
                      skipped processing for MMM-EARTH, doing test run
                      processing complete for module MMM-EARTH
                      processing for module MMM-GooglePhotos please wait
                      skipped processing for MMM-GooglePhotos, doing test run
                      processing complete for module MMM-GooglePhotos
                      test run, restoring files stashed
                      pi@raspberrypi:~ $
                      Is this correct?
                        @Peter-Leemon said in Update MMM:
                        yes, now add ‘apply’’
                        BUT
                        package-lock.json
                        I assume u might want to save those changed files…
                          Peter Leemon
                          yes that worked thank you, just have figure out how to update google photos to update now.
                            Peter Leemon
                            have just done a git pull and npm install in MMM-GooglePhotos module now the MM has a black screen everything else is working just no images showing
                              @Peter-Leemon did u npm install in the GooglePhotos folder?
                              Open the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
                                Peter Leemon
                                is that in MagicMirror/modules/MMM-GooglePhotos or just in pi@raspberrypi folder?
                                  the dev window is on the MM screen itself…
                                  or start MM with npm start dev and then select the console tab on the MM screen
                                    Peter Leemon
                                    I’ve also noticed the Calendar doesnt update any events added either in apple calendar or google calendar
                                      @Peter-Leemon i will have to check that tomorrow… I haven’t done any testing except to update my install and update scripts for v 2.11.
                                        Peter Leemon
                                        Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
                                        Thank you
                                          jims
                                          hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
                                            jims
                                            doesn t work… already black screen… I have PIR Sensor too
                                            I did this :
                                            login as: pi
                                            pi@192.168.1.18's password:
                                            Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                                            The programs included with the Debian GNU/Linux system are free software;
                                            the exact distribution terms for each program are described in the
                                            individual files in /usr/share/doc/*/copyright.
                                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                            permitted by applicable law.
                                            Last login: Thu Apr  2 09:55:59 2020 from 192.168.1.11
                                            pi@raspberrypi:~ $ cd MagicMirror/
                                            pi@raspberrypi:~/MagicMirror $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                            fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                            pi@raspberrypi:/ $ git checkout modules/node_modules/node_helper/index.js       fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                            pi@raspberrypi:/ $
                                            pi@raspberrypi:/ $
                                            login as: pi
                                            Last login: Thu Apr  2 10:20:36 2020
                                            pi@raspberrypi:~ $
                                            pi@raspberrypi:~/MagicMirror $ npm stop
                                            npm ERR! missing script: stop
                                            npm ERR!     /home/pi/.npm/_logs/2020-04-02T08_23_06_473Z-debug.log
                                            pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                            [PM2][ERROR] Process or Namespace mm not found
                                              error: missing required argument `id|name|namespace|all|json|stdin'
                                            pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                                            [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                            [PM2] [MagicMirror](0) ✓
                                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                            │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                            pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                            #: “#!/bin/bash: Aucun fichier ou dossier de ce type
                                            pi@raspberrypi:~/MagicMirror $ cd ..
                                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                            $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                            $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                            $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                            $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                            $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                            $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                            \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
        \______/
                                            install log being saved to /home/pi/install.log
                                            Updating packages ...
                                            Installing helper tools ...
                                            Minimum Node version: v10.1.0
                                            Installed Node version: v10.15.2
                                            No Node.js upgrade necessary.
                                            Minimum npm version: V6.0.0
                                            Installed npm version: V6.13.6
                                            No npm upgrade necessary.
                                            It seems like MagicMirror is already installed.
                                            To prevent overwriting, the installer will be aborted.
                                            Please rename the ~/MagicMirror folder and try again.
                                            If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                            upgrading from version 2.11.0 to 2.11.0
                                            there are 1 local files that are different than the master repo
                                               package-lock.json
                                            processing for module MMM-Selfieshot please wait
                                            skipped processing for MMM-Selfieshot, doing test run
                                            processing complete for module MMM-Selfieshot
                                            processing for module MMM-Strava please wait
                                            skipped processing for MMM-Strava, doing test run
                                            processing complete for module MMM-Strava
                                            processing for module MMM-PIR-Sensor please wait
                                            skipped processing for MMM-PIR-Sensor, doing test run
                                            processing complete for module MMM-PIR-Sensor
                                            processing for module MMM-Spotify please wait
                                            skipped processing for MMM-Spotify, doing test run
                                            processing complete for module MMM-Spotify
                                            processing for module MMM-Hotword please wait
                                            skipped processing for MMM-Hotword, doing test run
                                            processing complete for module MMM-Hotword
                                            processing for module MMM-AssistantMk2 please wait
                                            skipped processing for MMM-AssistantMk2, doing test run
                                            processing complete for module MMM-AssistantMk2
                                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                            doing test run = false
                                            local version 2.11.0 already same as master 2.11.0
                                            pi@raspberrypi:~ $ npm start
                                            npm ERR! code ENOENT
                                            npm ERR! syscall open
                                            npm ERR! errno -2
                                            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                            npm ERR! enoent This is related to npm not being able to find a file.
                                            npm ERR! enoent
                                            npm ERR!     /home/pi/.npm/_logs/2020-04-02T09_03_45_797Z-debug.log
                                            pi@raspberrypi:~ $ sudo reboot
                                            pi@raspberrypi:~ $
                                            login as: pi
                                            Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
                                            Last login: Thu Apr  2 11:04:36 2020
                                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                                            server does not have extension for -dpms option
                                            pi@raspberrypi:~ $
                                            pi@raspberrypi:~ $ fixuppm2.sh
                                            -bash: fixuppm2.sh : commande introuvable
                                            pi@raspberrypi:~ $ pm2 stop mm
                                            ^C
                                            pi@raspberrypi:~ $ pm2 stop MagicMirror
                                            pi@raspberrypi:~ $
                                            pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                            the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                                            removed 207 packages in 17.491s
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/pm2/node_modules/fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                            [PM2][ERROR] File /home/pi/MagicMirror/installers/pm2_MagicMirror.json not found
                                            [PM2] Saving current process list...
                                            [PM2][WARN] PM2 is not managing any process, skipping save...
                                            [PM2][WARN] To force saving use: pm2 save --force
                                            • 3 / 4
