    Update MMM
    75 Posts 8 Posters 55.6k Views 9 Watching
      Peter Leemon @sdetweil
      @sdetweil run the first script?
        sdetweil @Peter Leemon
        @Peter-Leemon
        upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
        it should handle all the work… and give you a trial run of all that…
        only applying changes if u request them
        give it a try this works on Mac as well
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        no changes are made to the local repo or the working copy
        if you WANT to actually apply the changes do
        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        there is a log file (upgrade.log) in the MagicMirror/installers folder…
        P 1 Reply Last reply
          @sdetweil said in Update MMM:
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
          sorry a noob here do i run this in terminal?
            @Peter-Leemon yes, stop MM first of course
              Peter Leemon
              when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
                @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
                need the trailing quote too
                  Peter Leemon
                  pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                  the log will be /home/pi/MagicMirror/installers/upgrade.log
                  No LSB modules are available.
                  doing test run = true
                  upgrading from version 2.10.1 to 2.11.0
                  fetching latest revisions
                  there are 3 local files that are different than the master repo
                  modules/default/calendar/calendar.js
                  modules/default/compliments/compliments.js
                  package-lock.json
                  any *-lock.json files do not need to be saved
                  do you want to save these files for later (Y/n)?y
                  processing for module MMM-NOAA3 please wait
                  skipped processing for MMM-NOAA3, doing test run
                  processing complete for module MMM-NOAA3
                  processing for module MMM-EARTH please wait
                  skipped processing for MMM-EARTH, doing test run
                  processing complete for module MMM-EARTH
                  processing for module MMM-GooglePhotos please wait
                  skipped processing for MMM-GooglePhotos, doing test run
                  processing complete for module MMM-GooglePhotos
                  test run, restoring files stashed
                  pi@raspberrypi:~ $
                  Is this correct?
                    @Peter-Leemon said in Update MMM:
                    yes, now add ‘apply’’
                    BUT
                    package-lock.json
                    I assume u might want to save those changed files…
                      Peter Leemon
                      yes that worked thank you, just have figure out how to update google photos to update now.
                        Peter Leemon
                        have just done a git pull and npm install in MMM-GooglePhotos module now the MM has a black screen everything else is working just no images showing
                          @Peter-Leemon did u npm install in the GooglePhotos folder?
                          Open the developers window, ctrl-shift-i on the keyboard, then select the console tab and scroll up to see any errors
                            Peter Leemon
                            is that in MagicMirror/modules/MMM-GooglePhotos or just in pi@raspberrypi folder?
                              the dev window is on the MM screen itself…
                              or start MM with npm start dev and then select the console tab on the MM screen
                                Peter Leemon
                                I’ve also noticed the Calendar doesnt update any events added either in apple calendar or google calendar
                                  @Peter-Leemon i will have to check that tomorrow… I haven’t done any testing except to update my install and update scripts for v 2.11.
                                    Peter Leemon
                                    Thank you atm I’m doing a backup of the SD card as separate and i might put an pre updated copy back on and run that until then.
                                    Thank you
                                      jims
                                      hello! I have the same problem. I am going to test the command to check. Updat in progress. I will see if it’s okay after updating. Thanks for your help!
                                        jims
                                        doesn t work… already black screen… I have PIR Sensor too
                                        I did this :
                                        login as: pi
                                        pi@192.168.1.18's password:
                                        Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l
                                        The programs included with the Debian GNU/Linux system are free software;
                                        the exact distribution terms for each program are described in the
                                        individual files in /usr/share/doc/*/copyright.
                                        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                        permitted by applicable law.
                                        Last login: Thu Apr  2 09:55:59 2020 from 192.168.1.11
                                        pi@raspberrypi:~ $ cd MagicMirror/
                                        pi@raspberrypi:~/MagicMirror $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                        fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                        pi@raspberrypi:/ $ git checkout modules/node_modules/node_helper/index.js       fatal: ni ceci ni aucun de ses répertoires parents n'est un dépôt git : .git
                                        pi@raspberrypi:/ $
                                        pi@raspberrypi:/ $
                                        login as: pi
                                        Last login: Thu Apr  2 10:20:36 2020
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~/MagicMirror $ npm stop
                                        npm ERR! missing script: stop
                                        npm ERR!     /home/pi/.npm/_logs/2020-04-02T08_23_06_473Z-debug.log
                                        pi@raspberrypi:~/MagicMirror $ pm2 stop mm
                                        [PM2][ERROR] Process or Namespace mm not found
                                          error: missing required argument `id|name|namespace|all|json|stdin'
                                        pi@raspberrypi:~/MagicMirror $ pm2 stop MagicMirror
                                        [PM2] Applying action stopProcessId on app [MagicMirror](ids: 0)
                                        [PM2] [MagicMirror](0) ✓
                                        │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                        │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                        pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                                        #: “#!/bin/bash: Aucun fichier ou dossier de ce type
                                        pi@raspberrypi:~/MagicMirror $ cd ..
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
                                        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
                                        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
                                        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
                                        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
                                        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
        \______/
                                        install log being saved to /home/pi/install.log
                                        Updating packages ...
                                        Installing helper tools ...
                                        Minimum Node version: v10.1.0
                                        Installed Node version: v10.15.2
                                        No Node.js upgrade necessary.
                                        Minimum npm version: V6.0.0
                                        Installed npm version: V6.13.6
                                        No npm upgrade necessary.
                                        It seems like MagicMirror is already installed.
                                        To prevent overwriting, the installer will be aborted.
                                        Please rename the ~/MagicMirror folder and try again.
                                        If you want to upgrade your installation run upgrade-script from the ~/MagicMirror/installers directory.
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                        upgrading from version 2.11.0 to 2.11.0
                                        there are 1 local files that are different than the master repo
                                           package-lock.json
                                        processing for module MMM-Selfieshot please wait
                                        skipped processing for MMM-Selfieshot, doing test run
                                        processing complete for module MMM-Selfieshot
                                        processing for module MMM-Strava please wait
                                        skipped processing for MMM-Strava, doing test run
                                        processing complete for module MMM-Strava
                                        processing for module MMM-PIR-Sensor please wait
                                        skipped processing for MMM-PIR-Sensor, doing test run
                                        processing complete for module MMM-PIR-Sensor
                                        processing for module MMM-Spotify please wait
                                        skipped processing for MMM-Spotify, doing test run
                                        processing complete for module MMM-Spotify
                                        processing for module MMM-Hotword please wait
                                        skipped processing for MMM-Hotword, doing test run
                                        processing complete for module MMM-Hotword
                                        processing for module MMM-AssistantMk2 please wait
                                        skipped processing for MMM-AssistantMk2, doing test run
                                        processing complete for module MMM-AssistantMk2
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                                        doing test run = false
                                        local version 2.11.0 already same as master 2.11.0
                                        pi@raspberrypi:~ $ npm start
                                        npm ERR! code ENOENT
                                        npm ERR! syscall open
                                        npm ERR! errno -2
                                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/pi/.npm/_logs/2020-04-02T09_03_45_797Z-debug.log
                                        pi@raspberrypi:~ $ sudo reboot
                                        pi@raspberrypi:~ $
                                        login as: pi
                                        Linux raspberrypi 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
                                        Last login: Thu Apr  2 11:04:36 2020
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/screensaveroff.sh)"
                                        server does not have extension for -dpms option
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $ fixuppm2.sh
                                        -bash: fixuppm2.sh : commande introuvable
                                        pi@raspberrypi:~ $ pm2 stop mm
                                        ^C
                                        pi@raspberrypi:~ $ pm2 stop MagicMirror
                                        pi@raspberrypi:~ $
                                        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                        the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                                        removed 207 packages in 17.491s
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/pm2/node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        [PM2][ERROR] File /home/pi/MagicMirror/installers/pm2_MagicMirror.json not found
                                        [PM2] Saving current process list...
                                        [PM2][WARN] PM2 is not managing any process, skipping save...
                                        [PM2][WARN] To force saving use: pm2 save --force
                                          jims
                                          And during the update :
                                          pi@raspberrypi:~/MagicMirror $ git pull && npm install
                                          Mise à jour 5bf90ae..447c0bf
                                          Fast-forward
                                           .eslintrc.json                                     |    1 +
                                           .github/ISSUE_TEMPLATE.md                          |   21 +-
                                           .travis.yml                                        |   27 +-
                                           CHANGELOG.md                                       |   59 +-
                                           Gruntfile.js                                       |   13 +-
                                           clientonly/index.js                                |    2 -
                                           config/config.js.sample                            |   18 +-
                                           index.html                                         |    2 +-
                                           installers/dumpactivemodules.js                    |   15 -
                                           installers/fixuppm2.sh                             |  183 -
                                           installers/mm.sh                                   |    1 +
                                           installers/pm2_MagicMirror.json                    |    7 -
                                           installers/postinstall/postinstall.sh              |    2 -
                                           installers/raspberry.sh                            |  569 ---
                                           installers/screensaveroff.sh                       |  101 -
                                           installers/upgrade-script.sh                       |  361 --
                                           js/app.js                                          |   11 +-
                                           js/electron.js                                     |    2 -
                                           js/loader.js                                       |    6 +-
                                           js/main.js                                         |   15 +-
                                           js/module.js                                       |   11 +-
                                           js/node_helper.js                                  |    4 +-
                                           js/server.js                                       |   14 +-
                                           js/socketclient.js                                 |    8 +-
                                           modules/README.md                                  |  721 ----
                                           modules/default/alert/README.md                    |   63 +-
                                           modules/default/calendar/README.md                 |  105 +-
                                           modules/default/calendar/calendar.js               |    4 +-
                                           modules/default/calendar/calendarfetcher.js        |   13 +-
                                           modules/default/calendar/debug.js                  |    2 +-
                                           .../default/calendar/vendor/ical.js/node-ical.js   |   15 +-
                                           modules/default/clock/README.md                    |   54 +-
                                           modules/default/clock/clock.js                     |   58 +-
                                           modules/default/clock/clock_screenshot.png         |  Bin 30525 -> 0 bytes
                                           modules/default/clock/clock_styles.css             |   10 +
                                           modules/default/compliments/README.md              |  148 +-
                                           modules/default/compliments/compliments.js         |   41 +-
                                           .../default/compliments/compliments_screenshot.png |  Bin 26157 -> 0 bytes
                                           modules/default/currentweather/README.md           |   86 +-
                                           modules/default/currentweather/currentweather.js   |   23 +-
                                           .../default/currentweather/weather_screenshot.png  |  Bin 38566 -> 0 bytes
                                           modules/default/helloworld/README.md               |   23 +-
                                           modules/default/newsfeed/README.md                 |  104 +-
                                           modules/default/newsfeed/newsfeed.js               |    5 +-
                                           modules/default/newsfeed/newsfeed_screenshot.png   |  Bin 45375 -> 0 bytes
                                           modules/default/updatenotification/README.md       |   24 +-
                                           modules/default/updatenotification/node_helper.js  |   74 +-
                                           .../updatenotification/updatenotification.js       |    1 +
                                           modules/default/weather/README.md                  |  117 +-
                                           modules/default/weather/current.png                |  Bin 8141 -> 0 bytes
                                           modules/default/weather/forecast.png               |  Bin 16385 -> 0 bytes
                                           modules/default/weatherforecast/README.md          |   79 +-
                                           .../weatherforecast/forecast_screenshot.png        |  Bin 86206 -> 0 bytes
                                           package-lock.json                                  | 4524 +++++++++-----------
                                           package.json                                       |   21 +-
                                           run-start.sh                                       |   67 -
                                           serveronly/index.js                                |    3 +-
                                           tests/configs/check_config.js                      |   14 +-
                                           .../modules/compliments/compliments_date.js        |   41 +
                                           .../modules/weather/forecastweather_default.js     |   46 +-
                                           .../modules/weather/forecastweather_options.js     |   52 +-
                                           tests/e2e/modules/compliments_spec.js              |   15 +
                                           tests/e2e/modules/mocks/weather_current.js         |   98 +-
                                           tests/e2e/modules/mocks/weather_forecast.js        |  184 +-
                                           tests/e2e/modules/weather_spec.js                  |   39 +-
                                           tests/e2e/vendor_spec.js                           |   15 +-
                                           tests/node_modules/webdriverajaxstub/index.js      |    4 +-
                                           tests/unit/functions/currentweather_spec.js        |    1 +
                                           tests/unit/functions/weatherforecast_spec.js       |    1 +
                                           translations/fi.json                               |    5 +-
                                           translations/he.json                               |   36 +
                                           translations/hr.json                               |    2 +-
                                           translations/pl.json                               |    3 +-
                                           translations/pt-br.json                            |    5 +-
                                           translations/tr.json                               |   14 +-
                                           translations/translations.js                       |   10 +-
                                           translations/uk.json                               |   36 +
                                           untrack-css.sh                                     |   11 -
                                           78 files changed, 2680 insertions(+), 5790 deletions(-)
                                           mode change 100755 => 100644 CHANGELOG.md
                                           delete mode 100644 installers/dumpactivemodules.js
                                           delete mode 100755 installers/fixuppm2.sh
                                           delete mode 100644 installers/pm2_MagicMirror.json
                                           delete mode 100644 installers/postinstall/postinstall.sh
                                           delete mode 100755 installers/raspberry.sh
                                           delete mode 100755 installers/screensaveroff.sh
                                           delete mode 100755 installers/upgrade-script.sh
                                           delete mode 100644 modules/README.md
                                           delete mode 100644 modules/default/clock/clock_screenshot.png
                                           delete mode 100644 modules/default/compliments/compliments_screenshot.png
                                           delete mode 100644 modules/default/currentweather/weather_screenshot.png
                                           delete mode 100644 modules/default/newsfeed/newsfeed_screenshot.png
                                           delete mode 100644 modules/default/weather/current.png
                                           delete mode 100644 modules/default/weather/forecast.png
                                           delete mode 100644 modules/default/weatherforecast/forecast_screenshot.png
                                           delete mode 100755 run-start.sh
                                           create mode 100644 tests/configs/modules/compliments/compliments_date.js
                                           create mode 100644 translations/he.json
                                           create mode 100644 translations/uk.json
                                           delete mode 100755 untrack-css.sh
                                          npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition.                                      vfile-message provides its own type definitions, so you do not need this instal                                     led.
                                          > electron-chromedriver@6.0.0 install /home/pi/MagicMirror/node_modules/electron                                     -chromedriver
                                          > node ./download-chromedriver.js
                                          > electron@6.1.7 postinstall /home/pi/MagicMirror/node_modules/electron
                                          > node install.js
                                          Downloading tmp-1525-1-SHASUMS256.txt-6.1.7
                                          [============================================>] 100.0% of 5.56 kB (5.56 kB/s)
                                          > magicmirror@2.11.0 install /home/pi/MagicMirror
                                          " && cd vendor && npm install --loglevel=error
                                          audited 220 packages in 25.414s
                                          found 8 vulnerabilities (7 low, 1 high)
                                            run `npm audit fix` to fix them, or `npm audit` for details
                                          > magicmirror@2.11.0 postinstall /home/pi/MagicMirror
                                          > npm run install-fonts && echo "MagicMirror installation finished successfully!
                                          > magicmirror@2.11.0 install-fonts /home/pi/MagicMirror
                                          > echo "Installing fonts ...
                                          " && cd fonts && npm install --loglevel=error
                                          audited 1 package in 3.182s
                                          found 0 vulnerabilities
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fse                                     vents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                     2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                     )
                                          added 124 packages from 84 contributors, removed 79 packages, updated 54 package                                     s and moved 1 package in 774.482s
                                          26 packages are looking for funding
                                            run `npm fund` for details
                                          pi@raspberrypi:~/MagicMirror $ sudo reboot
                                          npm ERR! errno -2
                                          npm ERR! enoent
                                          npm ERR!     /home/pi/.npm/_logs/2020-04-02T07_56_36_218Z-debug.log
                                          > magicmirror@2.11.0 start /home/pi/MagicMirror
                                          [2020-04-02 09:57:00.458] [LOG]    Starting MagicMirror: v2.11.0
                                          [2020-04-02 09:57:00.477] [LOG]    Loading config ...
                                          [2020-04-02 09:57:00.488] [LOG]    Loading module helpers ...
                                          [2020-04-02 09:57:00.492] [LOG]    No helper found for module: alert.
                                          [2020-04-02 09:57:00.601] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:00.604] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-02 09:57:00.607] [LOG]    No helper found for module: clock.
                                          [2020-04-02 09:57:01.480] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:01.481] [LOG]    Module helper loaded: calendar
                                          [2020-04-02 09:57:01.700] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:01.703] [LOG]    Module helper loaded: MMM-Selfieshot
                                          [2020-04-02 09:57:01.705] [LOG]    No helper found for module: compliments.
                                          [2020-04-02 09:57:01.708] [LOG]    No helper found for module: currentweather.
                                          [2020-04-02 09:57:01.711] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-02 09:57:02.820] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:02.822] [LOG]    Check MagicMirror version for node helper 'MM                                     M-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                          [2020-04-02 09:57:02.823] [LOG]    Version is ok!
                                          [2020-04-02 09:57:02.824] [LOG]    Module helper loaded: MMM-Strava
                                          [2020-04-02 09:57:02.861] [ERROR]  WARNING! Could not load config file. Starting                                      with default configuration. Error found: Error: The module '/home/pi/MagicMirro                                     r/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                          was compiled against a different Node.js version using
                                          NODE_MODULE_VERSION 64. This version of Node.js requires
                                          NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                                          the module (for instance, using `npm rebuild` or `npm install`).
                                          [2020-04-02 09:57:02.864] [LOG]    Loading module helpers ...
                                          [2020-04-02 09:57:02.867] [LOG]    No helper found for module: alert.
                                          [2020-04-02 09:57:02.869] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:02.871] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-02 09:57:02.873] [LOG]    No helper found for module: clock.
                                          [2020-04-02 09:57:02.875] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:02.877] [LOG]    Module helper loaded: calendar
                                          [2020-04-02 09:57:02.878] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:02.879] [LOG]    Module helper loaded: MMM-Selfieshot
                                          [2020-04-02 09:57:02.881] [LOG]    No helper found for module: compliments.
                                          [2020-04-02 09:57:02.882] [LOG]    No helper found for module: currentweather.
                                          [2020-04-02 09:57:02.883] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-02 09:57:02.884] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:57:02.885] [LOG]    Check MagicMirror version for node helper 'MM                                     M-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                          [2020-04-02 09:57:02.886] [LOG]    Version is ok!
                                          [2020-04-02 09:57:02.887] [LOG]    Module helper loaded: MMM-Strava
                                          [2020-04-02 09:57:02.899] [ERROR]  App threw an error during load
                                          [2020-04-02 09:57:02.902] [ERROR]  Error: The module '/home/pi/MagicMirror/modul                                     es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                              at process.func (electron/js2c/asar.js:138:31)
                                              at process.func [as dlopen] (electron/js2c/asar.js:138:31)
                                              at Object.Module._extensions..node (internal/modules/cjs/loader.js:828:18)
                                              at Object.func (electron/js2c/asar.js:138:31)
                                              at Object.func [as .node] (electron/js2c/asar.js:138:31)
                                              at Module.load (internal/modules/cjs/loader.js:645:32)
                                              at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                              at Module.require (internal/modules/cjs/loader.js:685:19)
                                              at require (internal/modules/cjs/helpers.js:16:16)
                                              at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin                                     gs/bindings.js:112:48)
                                              at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:7                                     :31
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu                                     les/epoll/epoll.js:15:3)
                                              at Module._compile (internal/modules/cjs/loader.js:786:30)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modu                                     les/onoff/onoff.js:5:15)
                                          [2020-04-02 09:57:02.907] [LOG]    Whoops! There was an uncaught exception...
                                          [2020-04-02 09:57:02.909] [ERROR]  Error: The module '/home/pi/MagicMirror/modul                                     es/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node'
                                          [2020-04-02 09:57:02.917] [LOG]    MagicMirror will not quit, but it might be a                                      good idea to check why this happened. Maybe no internet connection?
                                          [2020-04-02 09:57:02.918] [LOG]    If you think this really is an issue, please                                      open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-04-02 09:57:03.080] [LOG]    Launching application.
                                          ^C[2020-04-02 09:59:16.827] [LOG]    Shutting down server...
                                          [2020-04-02 09:59:16.835] [LOG]    Stopping module helper: updatenotification
                                          [2020-04-02 09:59:16.836] [LOG]    Stopping module helper: calendar
                                          [2020-04-02 09:59:16.837] [LOG]    Stopping module helper: MMM-Selfieshot
                                          [2020-04-02 09:59:16.838] [LOG]    Stopping module helper: MMM-Strava
                                          [2020-04-02 09:59:16.839] [LOG]    Stopping module helper: updatenotification
                                          [2020-04-02 09:59:16.840] [LOG]    Stopping module helper: calendar
                                          [2020-04-02 09:59:16.842] [LOG]    Stopping module helper: MMM-Selfieshot
                                          [2020-04-02 09:59:16.843] [LOG]    Stopping module helper: MMM-Strava
                                          [2020-04-02 09:59:39.647] [LOG]    Starting MagicMirror: v2.11.0
                                          [2020-04-02 09:59:39.665] [LOG]    Loading config ...
                                          [2020-04-02 09:59:39.675] [LOG]    Loading module helpers ...
                                          [2020-04-02 09:59:39.682] [LOG]    No helper found for module: alert.
                                          [2020-04-02 09:59:39.796] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:39.798] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-02 09:59:39.799] [LOG]    No helper found for module: clock.
                                          [2020-04-02 09:59:40.636] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:40.637] [LOG]    Module helper loaded: calendar
                                          [2020-04-02 09:59:40.856] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:40.858] [LOG]    Module helper loaded: MMM-Selfieshot
                                          [2020-04-02 09:59:40.861] [LOG]    No helper found for module: compliments.
                                          [2020-04-02 09:59:40.862] [LOG]    No helper found for module: currentweather.
                                          [2020-04-02 09:59:40.864] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-02 09:59:41.992] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:41.994] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                          [2020-04-02 09:59:41.996] [LOG]    Version is ok!
                                          [2020-04-02 09:59:41.997] [LOG]    Module helper loaded: MMM-Strava
                                          [2020-04-02 09:59:42.049] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.051] [LOG]    Module helper loaded: newsfeed
                                          [2020-04-02 09:59:42.054] [LOG]    No helper found for module: MMM-YouTube.
                                          [2020-04-02 09:59:42.074] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.076] [LOG]    Module helper loaded: MMM-Spotify
                                          [2020-04-02 09:59:42.382] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                          Require stack:
                                          - /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                                          - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                          [2020-04-02 09:59:42.385] [LOG]    Loading module helpers ...
                                          [2020-04-02 09:59:42.388] [LOG]    No helper found for module: alert.
                                          [2020-04-02 09:59:42.391] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.392] [LOG]    Module helper loaded: updatenotification
                                          [2020-04-02 09:59:42.394] [LOG]    No helper found for module: clock.
                                          [2020-04-02 09:59:42.396] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.397] [LOG]    Module helper loaded: calendar
                                          [2020-04-02 09:59:42.398] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.398] [LOG]    Module helper loaded: MMM-Selfieshot
                                          [2020-04-02 09:59:42.400] [LOG]    No helper found for module: compliments.
                                          [2020-04-02 09:59:42.401] [LOG]    No helper found for module: currentweather.
                                          [2020-04-02 09:59:42.402] [LOG]    No helper found for module: weatherforecast.
                                          [2020-04-02 09:59:42.403] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.404] [LOG]    Check MagicMirror version for node helper 'MMM-Strava' - Minimum version:  2.2.0 - Current version: 2.11.0
                                          [2020-04-02 09:59:42.405] [LOG]    Version is ok!
                                          [2020-04-02 09:59:42.406] [LOG]    Module helper loaded: MMM-Strava
                                          [2020-04-02 09:59:42.407] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.408] [LOG]    Module helper loaded: newsfeed
                                          [2020-04-02 09:59:42.410] [LOG]    No helper found for module: MMM-YouTube.
                                          [2020-04-02 09:59:42.412] [LOG]    Initializing new module helper ...
                                          [2020-04-02 09:59:42.414] [LOG]    Module helper loaded: MMM-Spotify
                                          [2020-04-02 09:59:42.428] [ERROR]  App threw an error during load
                                          [2020-04-02 09:59:42.429] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                          Require stack:
                                              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js:8:29)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18)
                                              at loadModule (/home/pi/MagicMirror/js/app.js:131:17)
                                              at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5)
                                          [2020-04-02 09:59:42.432] [LOG]    Whoops! There was an uncaught exception...
                                          [2020-04-02 09:59:42.433] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                          Require stack:
                                              at loadNextModule (/home/pi/MagicMirror/js/app.js:165:5) {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: [
                                              '/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js',
                                              '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                              '/home/pi/MagicMirror/js/app.js',
                                              '/home/pi/MagicMirror/js/electron.js',
                                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                              undefined
                                          [2020-04-02 09:59:42.447] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-04-02 09:59:42.449] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-04-02 09:59:42.629] [LOG]    Launching application.
                                          ^C[2020-04-02 10:01:17.981] [LOG]    Shutting down server...
                                          [2020-04-02 10:01:17.990] [LOG]    Stopping module helper: updatenotification
                                          [2020-04-02 10:01:17.992] [LOG]    Stopping module helper: calendar
                                          [2020-04-02 10:01:17.993] [LOG]    Stopping module helper: MMM-Selfieshot
                                          [2020-04-02 10:01:17.994] [LOG]    Stopping module helper: MMM-Strava
                                          [2020-04-02 10:01:17.996] [LOG]    Stopping module helper: newsfeed
                                          [2020-04-02 10:01:17.997] [LOG]    Stopping module helper: MMM-Spotify
                                          [2020-04-02 10:01:17.999] [LOG]    Stopping module helper: updatenotification
                                          [2020-04-02 10:01:18.001] [LOG]    Stopping module helper: calendar
                                          [2020-04-02 10:01:18.003] [LOG]    Stopping module helper: MMM-Selfieshot
                                          [2020-04-02 10:01:18.005] [LOG]    Stopping module helper: MMM-Strava
                                          [2020-04-02 10:01:18.007] [LOG]    Stopping module helper: newsfeed
                                          [2020-04-02 10:01:18.009] [LOG]    Stopping module helper: MMM-Spotify
                                          Déjà à jour.
                                          pi@raspberrypi:~/MagicMirror $ apt-get update
                                          Lecture des listes de paquets... Fait
                                          E: Impossible d'ouvrir le fichier verrou /var/lib/apt/lists/lock - open (13: Permission non accordée)
                                          E: Impossible de verrouiller le répertoire /var/lib/apt/lists/
                                          W: Problème de suppression du lien /var/cache/apt/pkgcache.bin - RemoveCaches (13: Permission non accordée)
                                          W: Problème de suppression du lien /var/cache/apt/srcpkgcache.bin - RemoveCaches (13: Permission non accordée)
                                          pi@raspberrypi:~ $ apt-get update
                                          pi@raspberrypi:~ $ ^C
                                          pi@raspberrypi:~ $ cmd": "cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                          -bash: cmd: cd : commande introuvable
                                          pi@raspberrypi:~ $ cd $MIRROR_APP_PATH/ && git checkout modules/node_modules/node_helper/index.js
                                          pi@raspberrypi:/ $ ls
                                          bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  root  run  sbin  srv  sys  tmp  usr  var
                                          pi@raspberrypi:/ $
                                          Thanks for help…
                                            jims
                                            after had followed the explanations page 3, the mirror is okay.
                                            But, he seems that jarvis doesn’t work as before… when I say ‘what time is it’ he open a windows with the google search haha but otherwize the over questions are ok, jarvis answer correctly.
                                            After, The module spotify doesn t work and PIR sensor… I will check it
                                            sorry for my english, i m french
                                            • 3 / 4
