    Update MMM
    75 Posts 8 Posters 40.9k Views 9 Watching
    • P Offline
      Peter Leemon
      HI all I’m getting the following message on my MM screen “MagicMirror2 update available” then underneath “The current installation is 2994 comments behind on the master branch”
      Anyone know how to resolve this issue?
        sdetweil @Peter Leemon
        @Peter-Leemon run my update script from here
        • P Offline
          Peter Leemon @sdetweil
          @sdetweil run the first script?
            @Peter-Leemon
            upgrade-script.sh will do the git pull and npm install, and refresh npm setup for any modules that might need it
            it should handle all the work… and give you a trial run of all that…
            only applying changes if u request them
            give it a try this works on Mac as well
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
            no changes are made to the local repo or the working copy
            if you WANT to actually apply the changes do
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            there is a log file (upgrade.log) in the MagicMirror/installers folder…
            • P Offline
              @sdetweil said in Update MMM:
              bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
              sorry a noob here do i run this in terminal?
                @Peter-Leemon yes, stop MM first of course
                • P Offline
                  Peter Leemon
                  when I paste bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh) i get no such file or directory
                    @Peter-Leemon dang forum, change the " to wrong character… copy/paste it again
                    need the trailing quote too
                    • P Offline
                      Peter Leemon
                      pi@raspberrypi:~ $ bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                      No LSB modules are available.
                      doing test run = true
                      update log will be in /home/pi/MagicMirror/installers/upgrade.log
                      upgrading from version 2.10.1 to 2.11.0
                      fetching latest revisions
                      there are 3 local files that are different than the master repo
                      modules/default/calendar/calendar.js
                      modules/default/compliments/compliments.js
                      package-lock.json
                      any *-lock.json files do not need to be saved
                      do you want to save these files for later (Y/n)?y
                      processing dependency changes for active modules with package.json files
                      processing for module MMM-NOAA3 please wait
                      skipped processing for MMM-NOAA3, doing test run
                      processing complete for module MMM-NOAA3
                      processing for module MMM-EARTH please wait
                      skipped processing for MMM-EARTH, doing test run
                      processing complete for module MMM-EARTH
                      processing for module MMM-GooglePhotos please wait
                      skipped processing for MMM-GooglePhotos, doing test run
                      processing complete for module MMM-GooglePhotos
                      test run, restoring files stashed
                      pi@raspberrypi:~ $
                      Is this correct?
                        @Peter-Leemon said in Update MMM:
                        yes, now add ‘apply’’
                        BUT
                        package-lock.json
                        I assume u might want to save those changed files…
                        • 6
                        • 7
                        • 8
                        • 5 / 8
