    Update MMM
    75 Posts 8 Posters 41.8k Views 9 Watching
      mattx38 @sdetweil
      @sdetweil How can I acknowledge the update anyway (it will overwrite the two files) ?
        sdetweil @mattx38
        @mattx38 it will not overwrite
        U have to do the two commands I said before
          mattx38 @sdetweil
          @sdetweil said in Update MMM:
          @mattx38 erase package-lock.json
          Did u modify package.json?
          And git checkout package.json to restore it if u are ok w that
          Ok, I erased the package-lock.json file.
          What command should I use to check package.json ?
          I’m a beginner…
            sdetweil @mattx38
            @mattx38 do
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor @sdetweil
              @sdetweil Perfect Sam thanks…
                mattx38 @sdetweil
                @mattx38 do
                I did it but the command did not return any information.
                  sdetweil @Stoffbeuteluwe
                  @Stoffbeuteluwe you guys should really use my upgrade script
                  see here https://github.com/sdetweil/MagicMirror_scripts
                    mattx38
                    I did the “npm install”.
                    I fixed 2 moderate vulnerabilities and it still remains 8 low severity vulnerabilities.
                    I don’t get if this can have consequences or not.
                      sdetweil @mattx38
                      @mattx38 don’t worry about the audit stuff… does it run?
                        mattx38
                        No, the mirror stays black with the mouse arrow in the left upper corner.
                        I did a reboot and a “pm2 restart mm”, but nothing works…
                        • 1 / 8
