    Update MMM
    75 Posts 8 Posters 54.0k Views 9 Watching
      mattx38 @sdetweil
      @sdetweil said in Update MMM:
      @mattx38 erase package-lock.json
      Did u modify package.json?
      And git checkout package.json to restore it if u are ok w that
      Ok, I erased the package-lock.json file.
      What command should I use to check package.json ?
      I’m a beginner…
        sdetweil @mattx38
        @mattx38 do
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @sdetweil
          @sdetweil Perfect Sam thanks…
            mattx38 @sdetweil
            @mattx38 do
            I did it but the command did not return any information.
              sdetweil @Stoffbeuteluwe
              @Stoffbeuteluwe you guys should really use my upgrade script
              see here https://github.com/sdetweil/MagicMirror_scripts
                mattx38
                I did the “npm install”.
                I fixed 2 moderate vulnerabilities and it still remains 8 low severity vulnerabilities.
                I don’t get if this can have consequences or not.
                  sdetweil @mattx38
                  @mattx38 don’t worry about the audit stuff… does it run?
                    mattx38
                    No, the mirror stays black with the mouse arrow in the left upper corner.
                    I did a reboot and a “pm2 restart mm”, but nothing works…
                      sdetweil @mattx38
                      @mattx38
                      pm2 stop mm
                      cd ~/magicMirror
                      npm start dev
                      alt-spacebar, n to minimize MM,… any messages on the terminal window?
                      select the MM window to reopen, select the console, and scroll up to see if any errors…
                      there is a fatal one somewhere
                        mattx38
                        Yes there is an error in red :
                        [2020-04-01 22:06:21.797] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
                        was compiled against a different Node.js version using
                        NODE_MODULE_VERSION 64. This version of Node.js requires
                        NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                        the module (for instance, using npm rebuild or npm install).
                        and other errors still with PIR module, but the errors are written in white
                        EDIT : I try a “npm rebuild” ?
                          sdetweil @mattx38
                          @mattx38 pir is a pain in the rear… I would disable it in config.js for now
                          add
                          disabled:true,
                          after module:“MMM-PIR-Sensor”,
                            mattx38
                            Done.
                            I did again a “npm start dev” and I have new errors written in red :
                            [2020-04-01 22:14:46.668] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                            Require stack:
                            • /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                            • /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                              sdetweil @mattx38
                              @mattx38 yep, snowboy is broke too… disable MMM-Hotword
                                mattx38
                                This update broke a lot of things… What a pain !
                                  sdetweil @mattx38
                                  @mattx38 for hotword, from the hotword doc, try
                                  in the MMm_Hotword folder
                                  git clone https://github.com/Kitt-AI/snowboy.git
                                  cd snowboy
                                  rm -rf .git
                                  cp -r resources/models ..
                                  npm install -y nan node-pre-gyp
                                  ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                                  npm install -y
                                  npm install -y electron-rebuild
                                  ./node_modules/.bin/electron-rebuild
                                  its because electron changed versions… some modules are compiled at certain node and electron versions
                                  if u change the versions (how would u know), then these modules break… Hotword and PIR are two such modules…
                                    mattx38
                                    Now it is the Jarvis Assitant :
                                    [2020-04-01 22:22:29.776] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                    Expected directory: electron-v6.1-linux-arm-glibc
                                    Found: [electron-v3.1-linux-arm-glibc, node-v64-linux-arm-glibc]
                                    This problem can often be fixed by running “npm rebuild” on the current system
                                    Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
                                    Require stack:
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/index.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/assistant.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js
                                    • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                                      sdetweil @mattx38
                                      @mattx38 said in Update MMM:
                                      MMM-AssistantMk2
                                      yep assistant… same problem as hotword… incompatible binary versions
                                      assistant doc
                                      Then, you need to rebuild grpc module for electron of MagicMirror.
                                      npm install --save-dev electron-rebuild
                                        for pir-sensor try
                                        npm install electron-rebuild
                                          mattx38 @sdetweil
                                          MMM-AssistantMk2
                                          assistant doc
                                          For the last command, it is very long to achieve ; 5 minutes that it runs.
                                          It’s written : Building module : grpc, Completed: 0
                                            sdetweil @mattx38
                                            @mattx38 every machine is different… I ignore how long it takes…
                                            did i work?
                                            • 1 / 4
