    Update MMM
    75 Posts 8 Posters 55.7k Views 9 Watching
      mattx38 @sdetweil
      @sdetweil said in Update MMM:
      @mattx38 do
      git checkout package.json
      I did it but the command did not return any information.
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe you guys should really use my upgrade script
        see here https://github.com/sdetweil/MagicMirror_scripts
        StoffbeuteluweS 1 Reply Last reply
          mattx38
          I did the “npm install”.
          I fixed 2 moderate vulnerabilities and it still remains 8 low severity vulnerabilities.
          I don’t get if this can have consequences or not.
            sdetweil @mattx38
            @mattx38 don’t worry about the audit stuff… does it run?
              mattx38
              No, the mirror stays black with the mouse arrow in the left upper corner.
              I did a reboot and a “pm2 restart mm”, but nothing works…
                sdetweil @mattx38
                @mattx38
                pm2 stop mm
                cd ~/magicMirror
                npm start dev
                alt-spacebar, n to minimize MM,… any messages on the terminal window?
                select the MM window to reopen, select the console, and scroll up to see if any errors…
                there is a fatal one somewhere
                  mattx38
                  Yes there is an error in red :
                  [2020-04-01 22:06:21.797] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’
                  was compiled against a different Node.js version using
                  NODE_MODULE_VERSION 64. This version of Node.js requires
                  NODE_MODULE_VERSION 73. Please try re-compiling or re-installing
                  the module (for instance, using npm rebuild or npm install).
                  and other errors still with PIR module, but the errors are written in white
                  EDIT : I try a “npm rebuild” ?
                    sdetweil @mattx38
                    @mattx38 pir is a pain in the rear… I would disable it in config.js for now
                    add
                    disabled:true,
                    after module:“MMM-PIR-Sensor”,
                      mattx38
                      Done.
                      I did again a “npm start dev” and I have new errors written in red :
                      [2020-04-01 22:14:46.668] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node’
                      Require stack:
                      • /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                      • /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                        sdetweil @mattx38
                        @mattx38 yep, snowboy is broke too… disable MMM-Hotword
                          mattx38
                          This update broke a lot of things… What a pain !
                            sdetweil @mattx38
                            @mattx38 for hotword, from the hotword doc, try
                            in the MMm_Hotword folder
                            git clone https://github.com/Kitt-AI/snowboy.git
                            cd snowboy
                            rm -rf .git
                            cp -r resources/models ..
                            npm install -y nan node-pre-gyp
                            ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                            npm install -y
                            npm install -y electron-rebuild
                            ./node_modules/.bin/electron-rebuild
                            its because electron changed versions… some modules are compiled at certain node and electron versions
                            if u change the versions (how would u know), then these modules break… Hotword and PIR are two such modules…
                              mattx38
                              Now it is the Jarvis Assitant :
                              [2020-04-01 22:22:29.776] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                              Expected directory: electron-v6.1-linux-arm-glibc
                              Found: [electron-v3.1-linux-arm-glibc, node-v64-linux-arm-glibc]
                              This problem can often be fixed by running “npm rebuild” on the current system
                              Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
                              Require stack:
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/index.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/assistant.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/components/assistant.js
                              • /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                                sdetweil @mattx38
                                @mattx38 said in Update MMM:
                                MMM-AssistantMk2
                                yep assistant… same problem as hotword… incompatible binary versions
                                assistant doc
                                Then, you need to rebuild grpc module for electron of MagicMirror.
                                npm install --save-dev electron-rebuild
                                M 1 Reply Last reply
                                  for pir-sensor try
                                  npm install electron-rebuild
                                    mattx38 @sdetweil
                                    MMM-AssistantMk2
                                    assistant doc
                                    For the last command, it is very long to achieve ; 5 minutes that it runs.
                                    It’s written : Building module : grpc, Completed: 0
                                      sdetweil @mattx38
                                      @mattx38 every machine is different… I ignore how long it takes…
                                      did i work?
                                        mattx38
                                        Don’t know yet.
                                        Did I do something wrong with the update ?
                                        Everything seams to be broken…
                                        Anyway, thank you very much for your precious help and sorry for my poor english (I’m from France)
                                          sdetweil @mattx38
                                          @mattx38 no issue… the ‘default’ instructions don’t consider all the other things that will break.
                                          even my upgrade script does not handle these problems… as they are so module specific…
                                          my french is a LOT worse than your english!..
                                            mattx38
                                            Ok I understand.
                                            I saw a message on the Remote Control module github and it seams there is also a problem with it after the MMM update.
                                            My MagicMirror was running as a charm till this update. I saw the alert on the MM screen so I did it… what a shame
                                            • 1 / 4
