    my mirror freezes!
    98 Posts 5 Posters 52.3k Views 4 Watching
      Manu85
      Hello everyone, I am French and I use a translator to post. sorry for errors syntaxes …
      I mounted a magic mirror, thanks to all of you and I thank the developers and all the people who work for free for this success.
      on my mirror I have a few modules, calendar, time, date, weather, soccer results and news, when my mirror works after 2 or 3 hours the modules no longer react the watch stops, I changed my pi because I thought that the pi2 could not support the load I bought a pi3 I redid a complete installation on a new sd card I changed the power supply and I always have the same problem … for work around this problem I set up an automatic reboot every hour, it works but it’s not the best, I would like to know if you could help me?
      I hope I posted in the right place
      thank you all again
        sdetweil @Manu85
        @Manu85 can u connect to the mirror via ssh from your pc? if so, when the system doesn’t look active can u get in?
        (is the system hung, or just MM?)
        if just MM, then start my looking at the console log (in pm2 that is shown with
        pm2 logs --lines=??? (some number, default is 15)
        also, u may need to run MM with the MMM-Logging module installed to get traces from the UI components.
        I just finished about 6 months of debug on a similar problem, to discover an out of memory problem in one of my modules… MM just hung.
        pouvez-vous vous connecter au miroir via ssh depuis votre PC? si oui, quand le système ne semble pas actif, pouvez-vous entrer?
        (le système est-il bloqué, ou tout simplement MM?)
        si seulement MM, alors commencez à regarder le journal de la console (en pm2 qui est montré avec
        pm2 logs --lines = ??? (un certain nombre, la valeur par défaut est 15)
        en outre, vous devrez peut-être exécuter MM avec le module de journalisation MMM installé pour obtenir des traces des composants de l’interface utilisateur.
        Je viens de terminer environ 6 mois de débogage sur un problème similaire, pour découvrir un problème de mémoire insuffisante dans l’un de mes modules … MM vient de se bloquer.
          Manu85
          thank you for your response I just launched the command line that you recommended and the answer is as follows:
          pi@raspberrypi:~ $ pm2 logs --lines = ???
          [TAILING] Tailing last 15 lines for [???] process (change the value with --lines option)
          what should i do please?
            sdetweil @Manu85
            @Manu85 do
            pm2 logs --lines=100
              Manu85
              I passed the command line and I have several lines, do you want me to copy them on my answer?
                sdetweil @Manu85
                @Manu85 you are looking for things that look like trouble
                vous cherchez des choses qui ressemblent à des ennuis
                  Manu85
                  I have several lines that look like errors, I put you the copy of all the lines, I tried to hide the confidential data !!!
                  /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                  0|MagicMir | npm ERR! code ELIFECYCLE
                  0|MagicMir | npm ERR! errno 1
                  0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                  0|MagicMir | npm ERR! Exit status 1
                  0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script.
                  0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  0|MagicMir |
                  0|MagicMir | npm ERR! A complete log of this run can be found in:
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T07_00_02_234Z-debug.log
                  0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                  0|MagicMir | [2020-04-05 09:00:36.357] [ERROR]  (node:954) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir | [2020-04-05 09:57:55.156] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIXXXXXXXXXXXXXXXE_Pic { Error: connect ETIMEDOUT 17.248.144.201:443
                  0|MagicMir |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14)
                  0|MagicMir |   errno: 'ETIMEDOUT',
                  0|MagicMir |   code: 'ETIMEDOUT',
                  0|MagicMir |   syscall: 'connect',
                  0|MagicMir |   address: '17.XXXXXXX',
                  0|MagicMir |   port: 443 }
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T08_00_01_545Z-debug.log
                  0|MagicMir | [2020-04-05 10:00:36.536] [ERROR]  (node:978) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T09_00_02_026Z-debug.log
                  0|MagicMir | [2020-04-05 11:00:37.769] [ERROR]  (node:1007) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir | [2020-04-05 11:30:42.125] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENnXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX_Pic { Error: connect EHOSTUNREACH 17XXXXXXXXXXX:80
                  0|MagicMir |   errno: 'EHOSTUNREACH',
                  0|MagicMir |   code: 'EHOSTUNREACH',
                  0|MagicMir |   address: 'XXXXXXXXXXXXX1',
                  0|MagicMir |   port: 80 }
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T10_00_02_273Z-debug.log
                  0|MagicMir | [2020-04-05 12:00:36.374] [ERROR]  (node:904) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir | [2020-04-05 12:17:53.271] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXK6-6HzuFLzdeE_Pic { Error: connect ETIMEDOUT 17.248.144.201:80
                  0|MagicMir |   address: '17.XXXXXXXXXX1',
                  0|MagicMir | [2020-04-05 12:27:52.308] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6XXXXXXXXXXXXXXXXXXXXXXXXXXeE_Pic { Error: connect ETIMEDOUT 17.248.144.176:80
                  0|MagicMir |   address: 'XXXXXXXXXXXX6',
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T11_00_02_185Z-debug.log
                  0|MagicMir | [2020-04-05 13:00:36.526] [ERROR]  (node:909) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  0|MagicMir |
                  0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T12_00_02_475Z-debug.log
                  0|MagicMir | [2020-04-05 14:00:36.327] [ERROR]  (node:953) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    sdetweil @Manu85
                    @Manu85 said in my mirror freezes!:
                    i see those on my mirror systems occasionally… usually a network problem outside my house…
                    and my systems recover
                      Manu85
                      and what to do please?
                        sdetweil @Manu85
                        @Manu85 open the developers window (ctrl-shift-i on keyboard), select the tab labeled console,
                        and look around (scroll up), looking for any errors, red text…
                        but if the mirror hangs this will not work… thus why I suggested installing MMM-Logging module and enable electron debugging to try to capture any error messages
                          Manu85
                          this one :
                          MMM-Logging ?
                            sdetweil @Manu85
                            @Manu85 yes,
                            make sure to do this
                            Note: You can find more detailed information on debugging your MagicMirror here: Module Debugging. If you also want the Electron rederer (web browser) console logs to be printed to the standard console (or PM2 logs), change the following line to the very top of ~/MagicMirror/run-start.sh
                            export ELECTRON_ENABLE_LOGGING=true
                              Manu85
                              @sdetweil thank you for your answer i will follow your advice, but it exceeds my skills, can you tell me exactly what to do please?
                                sdetweil @Manu85
                                @Manu85 install the module(note that it wants to be first in the module list in config.js), and add this to the batch file starting the mirror
                                  Manu85
                                  The you lost me :-), "and add this to the batch file starting the mirror
                                  export ELECTRON_ENABLE_LOGGING = true "
                                    sdetweil @Manu85
                                    @Manu85 how does MM get started? pm2?
                                    if so, it usually uses a batch file (script)
                                    ~/MagicMirror/installers/mm.sh
                                    make it look like this
                                    cd ~/MagicMirror
                                    DISPLAY=:0 npm start
                                      Manu85
                                      I have this error message:
                                      pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING = true
                                      -bash: export: « = » : identifiant non valable
                                        Manu85
                                        -bash: export: “=”: invalid identifier
                                          sdetweil @Manu85
                                          @Manu85 sorry, hate that…
                                          no spaces
                                            Manu85
                                            ok perfect the line has passed,
                                            pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING=true
                                            i downloaded the module, now i set it in config.js?
                                            • 1 / 5
