    my mirror freezes!
    98 Posts 5 Posters 56.3k Views 4 Watching
      sdetweil @Manu85
      @Manu85 said in my mirror freezes!:
      0|MagicMir | [2020-04-05 09:57:55.156] [ERROR] Calendar Error. Could not fetch calendar:
      i see those on my mirror systems occasionally… usually a network problem outside my house…
      and my systems recover
        Manu85
        and what to do please?
          sdetweil @Manu85
          @Manu85 open the developers window (ctrl-shift-i on keyboard), select the tab labeled console,
          and look around (scroll up), looking for any errors, red text…
          but if the mirror hangs this will not work… thus why I suggested installing MMM-Logging module and enable electron debugging to try to capture any error messages
            Manu85
            this one :
            MMM-Logging ?
              sdetweil @Manu85
              @Manu85 yes,
              make sure to do this
              Note: You can find more detailed information on debugging your MagicMirror here: Module Debugging. If you also want the Electron rederer (web browser) console logs to be printed to the standard console (or PM2 logs), change the following line to the very top of ~/MagicMirror/run-start.sh
              export ELECTRON_ENABLE_LOGGING=true
                Manu85
                @sdetweil thank you for your answer i will follow your advice, but it exceeds my skills, can you tell me exactly what to do please?
                  sdetweil @Manu85
                  @Manu85 install the module(note that it wants to be first in the module list in config.js), and add this to the batch file starting the mirror
                    Manu85
                    The you lost me :-), "and add this to the batch file starting the mirror
                    export ELECTRON_ENABLE_LOGGING = true "
                      sdetweil @Manu85
                      @Manu85 how does MM get started? pm2?
                      if so, it usually uses a batch file (script)
                      ~/MagicMirror/installers/mm.sh
                      make it look like this
                      DISPLAY=:0 npm start
                        Manu85
                        I have this error message:
                        pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING = true
                        -bash: export: « = » : identifiant non valable
                          Manu85
                          -bash: export: “=”: invalid identifier
                            sdetweil @Manu85
                            @Manu85 sorry, hate that…
                            no spaces
                              Manu85
                              ok perfect the line has passed,
                              pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING=true
                              i downloaded the module, now i set it in config.js?
                                bhepler Module Developer
                                  sdetweil @Manu85
                                  @Manu85 yes, follow the modules readme
                                    Manu85
                                    ok i try …
                                      Manu85
                                      I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
                                      language: “fr”,
                                      timeFormat: 24,
                                      units: “metric”,
                                              module: 'MMM-Logging',
                                                  // Module functions out of the box with nothing set here.
                                                  // See below for configurable options.
                                        sdetweil @Manu85
                                        @Manu85
                                                },    // < ---- missing comma  (like behind all modules)
                                          Manu85
                                          language: “fr”,
                                          timeFormat: 24,
                                          units: “metric”,
                                            Manu85
                                            excuse me I sent the message twice because the site had crashed …, I test what you sent me
                                            • 1 / 5
