    my mirror freezes!
    98 Posts 5 Posters 56.3k Views 4 Watching
      sdetweil @Manu85
      @Manu85 yes,
      make sure to do this
      Note: You can find more detailed information on debugging your MagicMirror here: Module Debugging. If you also want the Electron rederer (web browser) console logs to be printed to the standard console (or PM2 logs), change the following line to the very top of ~/MagicMirror/run-start.sh
      export ELECTRON_ENABLE_LOGGING=true
        Manu85
        @sdetweil thank you for your answer i will follow your advice, but it exceeds my skills, can you tell me exactly what to do please?
          sdetweil @Manu85
          @Manu85 install the module(note that it wants to be first in the module list in config.js), and add this to the batch file starting the mirror
            Manu85
            The you lost me :-), "and add this to the batch file starting the mirror
            export ELECTRON_ENABLE_LOGGING = true "
              sdetweil @Manu85
              @Manu85 how does MM get started? pm2?
              if so, it usually uses a batch file (script)
              ~/MagicMirror/installers/mm.sh
              make it look like this
              DISPLAY=:0 npm start
                Manu85
                I have this error message:
                pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING = true
                -bash: export: « = » : identifiant non valable
                  Manu85
                  -bash: export: “=”: invalid identifier
                    sdetweil @Manu85
                    @Manu85 sorry, hate that…
                    no spaces
                      Manu85
                      ok perfect the line has passed,
                      pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING=true
                      i downloaded the module, now i set it in config.js?
                        bhepler Module Developer
                          sdetweil @Manu85
                          @Manu85 yes, follow the modules readme
                            Manu85
                            ok i try …
                              Manu85
                              I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
                              language: “fr”,
                              timeFormat: 24,
                              units: “metric”,
                                      module: 'MMM-Logging',
                                          // Module functions out of the box with nothing set here.
                                          // See below for configurable options.
                                sdetweil @Manu85
                                @Manu85
                                        },    // < ---- missing comma  (like behind all modules)
                                  Manu85
                                  language: “fr”,
                                  timeFormat: 24,
                                  units: “metric”,
                                    Manu85
                                    excuse me I sent the message twice because the site had crashed …, I test what you sent me
                                      Manu85
                                      I still have the same message.
                                      language: “fr”,
                                      timeFormat: 24,
                                      units: “metric”,
                                        sdetweil @Manu85
                                        @Manu85 sorry, copy error on my part
                                            } ,    // < --- add comma here  means continued
                                          Manu85
                                          impeccable, you’re the best, the mirror has restarted, and now what’s next please
                                            sdetweil @Manu85
                                            @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
                                            find it and practice how to view it
                                            • 2 / 5
