    my mirror freezes!
    98 Posts 5 Posters 52.4k Views 4 Watching
      Manu85
      I still have the same message.
      language: “fr”,
      timeFormat: 24,
      units: “metric”,
          module: 'MMM-Logging',
              // Module functions out of the box with nothing set here.
              // See below for configurable options.
          },    // < ---- missing comma  (like behind all modules)
        sdetweil @Manu85
        @Manu85 sorry, copy error on my part
            } ,    // < --- add comma here  means continued
          Manu85
          impeccable, you’re the best, the mirror has restarted, and now what’s next please
            sdetweil @Manu85
            @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
            find it and practice how to view it
              Manu85
              ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
                A Former User
                Just for more information. It’s on MM v2. 11.0?
                Because I have some freeze problem too. I have never in v2.10.x
                I suspect electron versioning bug
                  sdetweil @Guest
                  @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
                    A Former User
                    weird, thx, i will inspect more
                      Manu85
                      @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                        sdetweil @Manu85
                        @Manu85 said in my mirror freezes!:
                        sorry, what does that mean?
                        by adding the mmm-logging module
                        you get enhanced messages on the terminal window console like this with timestamps
                        [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                        [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                        [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                        so, you should have started your mirror like this to capture all the traces
                        npm start >somefile
                        now that the app is hung, you can open another winscp terminal window and then
                        cd ~/.MagicMirror
                        tail somefile
                        which will show the last 15 lines of somefile by default
                        tail -n number somefile
                        where number is something like 20, 40, 50 will show more lines
                        if you started with pm2, then the output is on the logs…
                        pm2 logs --lines=100 >somefile
                        will dump the last 100 lines into somefile so you can examine them
                          Manu85
                          I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                          Error
                          Post content was flagged as spam by Akismet.com
                            sdetweil @Manu85
                            @Manu85 u can send it to me by email, to my same userid as here at gmail
                              Manu85
                              when placing your order I have this:
                              pi@raspberrypi:~/MagicMirror $ npm start >somefile
                              [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                              at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                              at listenInCluster (net.js:1378:12)
                              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                              errno: ‘EADDRINUSE’,
                              code: ‘EADDRINUSE’,
                              syscall: ‘listen’,
                              address: ‘127.0.0.1’,
                              port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                              code: ‘EADDRINUSE’,
                              syscall: ‘listen’,
                                sdetweil @Manu85
                                @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                                  Manu85
                                  ok you can tell me how to do it?
                                    sdetweil @Manu85
                                    @Manu85 pm2 stop 0
                                      Manu85
                                      ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
                                        sdetweil @Manu85
                                        on boot, right?
                                        if you use winscp to connect to pi, then copy the file to your pc and mail from there
                                          Manu85
                                          pi@raspberrypi:~/MagicMirror $ tail somefile
                                          [2020-04-06 15:19:00.632] [LOG] 2020-04-06T15:19:00 Connecting socket for: newsfeed (/home/pi/MagicMirror/js/node_helper.js:97 Class.setSocketIO)
                                          [2020-04-06 15:19:00.633] [LOG] 2020-04-06T15:19:00 Starting module: newsfeed (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:15 Class.start)
                                          [2020-04-06 15:19:00.634] [LOG] 2020-04-06T15:19:00 Sockets connected & modules started … (/home/pi/MagicMirror/js/app.js:233 )
                                          [2020-04-06 15:19:00.858] [LOG] 2020-04-06T15:19:00 Launching application. (/home/pi/MagicMirror/js/electron.js:81 App.)
                                          [2020-04-06 15:19:03.615] [LOG] 2020-04-06T15:19:03 MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                          [2020-04-06 15:19:03.617] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                          [2020-04-06 15:19:03.619] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                          [2020-04-06 15:19:03.640] [LOG] 2020-04-06T15:19:03 Create new calendar fetcher for url: http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6JXqtyFFXzQwCFuV_rleNhqA2u8ZaQkK6-6HzuFLzdeE_Pic - Interval: 300000 (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:49 Class.createFetcher)
                                          [2020-04-06 15:19:03.667] [LOG] 2020-04-06T15:19:03 Create new news fetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000 (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:48 Class.createFetcher)
                                          [2020-04-06 15:19:04.164] [LOG] 2020-04-06T15:19:04 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                            sdetweil @Manu85
                                            @Manu85 yes, now we need to wait for hang again
                                            • 2 / 5
