    my mirror freezes!
    98 Posts 5 Posters 56.7k Views 4 Watching
      Manu85
      ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
        A Former User
        Just for more information. It’s on MM v2. 11.0?
        Because I have some freeze problem too. I have never in v2.10.x
        I suspect electron versioning bug
          sdetweil @Guest
          @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
            A Former User
            weird, thx, i will inspect more
              Manu85
              @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                sdetweil @Manu85
                @Manu85 said in my mirror freezes!:
                sorry, what does that mean?
                by adding the mmm-logging module
                you get enhanced messages on the terminal window console like this with timestamps
                [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                so, you should have started your mirror like this to capture all the traces
                npm start >somefile
                now that the app is hung, you can open another winscp terminal window and then
                cd ~/.MagicMirror
                tail somefile
                which will show the last 15 lines of somefile by default
                tail -n number somefile
                where number is something like 20, 40, 50 will show more lines
                if you started with pm2, then the output is on the logs…
                pm2 logs --lines=100 >somefile
                will dump the last 100 lines into somefile so you can examine them
                  Manu85
                  I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                  Error
                  Post content was flagged as spam by Akismet.com
                    sdetweil @Manu85
                    @Manu85 u can send it to me by email, to my same userid as here at gmail
                      Manu85
                      when placing your order I have this:
                      pi@raspberrypi:~/MagicMirror $ npm start >somefile
                      [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                      at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                      at listenInCluster (net.js:1378:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                      errno: ‘EADDRINUSE’,
                      code: ‘EADDRINUSE’,
                      syscall: ‘listen’,
                      address: ‘127.0.0.1’,
                      port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                      code: ‘EADDRINUSE’,
                      syscall: ‘listen’,
                        sdetweil @Manu85
                        @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                          Manu85
                          ok you can tell me how to do it?
                            sdetweil @Manu85
                            @Manu85 pm2 stop 0
                              Manu85
                              ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
                                sdetweil @Manu85
                                on boot, right?
                                if you use winscp to connect to pi, then copy the file to your pc and mail from there
                                  Manu85
                                  pi@raspberrypi:~/MagicMirror $ tail somefile
                                  [2020-04-06 15:19:00.632] [LOG] 2020-04-06T15:19:00 Connecting socket for: newsfeed (/home/pi/MagicMirror/js/node_helper.js:97 Class.setSocketIO)
                                  [2020-04-06 15:19:00.633] [LOG] 2020-04-06T15:19:00 Starting module: newsfeed (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:15 Class.start)
                                  [2020-04-06 15:19:00.634] [LOG] 2020-04-06T15:19:00 Sockets connected & modules started … (/home/pi/MagicMirror/js/app.js:233 )
                                  [2020-04-06 15:19:00.858] [LOG] 2020-04-06T15:19:00 Launching application. (/home/pi/MagicMirror/js/electron.js:81 App.)
                                  [2020-04-06 15:19:03.615] [LOG] 2020-04-06T15:19:03 MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                  [2020-04-06 15:19:03.617] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  [2020-04-06 15:19:03.619] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  [2020-04-06 15:19:03.640] [LOG] 2020-04-06T15:19:03 Create new calendar fetcher for url: http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6JXqtyFFXzQwCFuV_rleNhqA2u8ZaQkK6-6HzuFLzdeE_Pic - Interval: 300000 (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:49 Class.createFetcher)
                                  [2020-04-06 15:19:03.667] [LOG] 2020-04-06T15:19:03 Create new news fetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000 (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:48 Class.createFetcher)
                                  [2020-04-06 15:19:04.164] [LOG] 2020-04-06T15:19:04 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                    sdetweil @Manu85
                                    @Manu85 yes, now we need to wait for hang again
                                      Manu85
                                      I just rebooted the mirror restarted, is that what I had to do?
                                        sdetweil @Manu85
                                        @Manu85 yes, it is logging to the pm2 log, all ok
                                          Manu85
                                          I was afraid of doing something stupid! now something must be done?
                                            sdetweil @Manu85
                                            @Manu85 tomorrow when hung, do
                                            and look at somefile
                                            • 3 / 5
