    my mirror freezes!
    98 Posts 5 Posters 56.7k Views 4 Watching
      sdetweil @Manu85
      @Manu85 said in my mirror freezes!:
      and when I wanted to quit it he offered to create a folder
      sorry, what does that mean?
      by adding the mmm-logging module
      you get enhanced messages on the terminal window console like this with timestamps
      [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
      [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
      [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
      so, you should have started your mirror like this to capture all the traces
      npm start >somefile
      now that the app is hung, you can open another winscp terminal window and then
      cd ~/.MagicMirror
      tail somefile
      which will show the last 15 lines of somefile by default
      tail -n number somefile
      where number is something like 20, 40, 50 will show more lines
      if you started with pm2, then the output is on the logs…
      pm2 logs --lines=100 >somefile
      will dump the last 100 lines into somefile so you can examine them
        Manu85
        I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
        Error
        Post content was flagged as spam by Akismet.com
          sdetweil @Manu85
          @Manu85 u can send it to me by email, to my same userid as here at gmail
            Manu85
            when placing your order I have this:
            pi@raspberrypi:~/MagicMirror $ npm start >somefile
            [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
            at Server.setupListenHandle [as _listen2] (net.js:1330:14)
            at listenInCluster (net.js:1378:12)
            at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
            errno: ‘EADDRINUSE’,
            code: ‘EADDRINUSE’,
            syscall: ‘listen’,
            address: ‘127.0.0.1’,
            port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
            code: ‘EADDRINUSE’,
            syscall: ‘listen’,
              sdetweil @Manu85
              @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                Manu85
                ok you can tell me how to do it?
                  sdetweil @Manu85
                  @Manu85 pm2 stop 0
                    Manu85
                    ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
                      sdetweil @Manu85
                      on boot, right?
                      if you use winscp to connect to pi, then copy the file to your pc and mail from there
                        Manu85
                        pi@raspberrypi:~/MagicMirror $ tail somefile
                        [2020-04-06 15:19:00.632] [LOG] 2020-04-06T15:19:00 Connecting socket for: newsfeed (/home/pi/MagicMirror/js/node_helper.js:97 Class.setSocketIO)
                        [2020-04-06 15:19:00.633] [LOG] 2020-04-06T15:19:00 Starting module: newsfeed (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:15 Class.start)
                        [2020-04-06 15:19:00.634] [LOG] 2020-04-06T15:19:00 Sockets connected & modules started … (/home/pi/MagicMirror/js/app.js:233 )
                        [2020-04-06 15:19:00.858] [LOG] 2020-04-06T15:19:00 Launching application. (/home/pi/MagicMirror/js/electron.js:81 App.)
                        [2020-04-06 15:19:03.615] [LOG] 2020-04-06T15:19:03 MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                        [2020-04-06 15:19:03.617] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2020-04-06 15:19:03.619] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                        [2020-04-06 15:19:03.640] [LOG] 2020-04-06T15:19:03 Create new calendar fetcher for url: http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6JXqtyFFXzQwCFuV_rleNhqA2u8ZaQkK6-6HzuFLzdeE_Pic - Interval: 300000 (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:49 Class.createFetcher)
                        [2020-04-06 15:19:03.667] [LOG] 2020-04-06T15:19:03 Create new news fetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000 (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:48 Class.createFetcher)
                        [2020-04-06 15:19:04.164] [LOG] 2020-04-06T15:19:04 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                          sdetweil @Manu85
                          @Manu85 yes, now we need to wait for hang again
                            Manu85
                            I just rebooted the mirror restarted, is that what I had to do?
                              sdetweil @Manu85
                              @Manu85 yes, it is logging to the pm2 log, all ok
                                Manu85
                                I was afraid of doing something stupid! now something must be done?
                                  sdetweil @Manu85
                                  @Manu85 tomorrow when hung, do
                                  and look at somefile
                                    Manu85
                                    ok i will wait tomorrow, thanks for your help
                                      Manu85
                                      @sdetweil [0_1586246858572_somefile](Uploading 100%)
                                        Manu85
                                        @sdetweil I can’t get you to pass the “somefile” file on the forum, the file must be in jpg, tif format … I tried to convert them to jpg by splitting the files, but it doesn’t work not either, you told me that I could send it to you by email, but I don’t see how to do it, when I go to your profile it just offers me a chat conversation and the cat only accepts 1000 characters and the file does a lot more, I don’t know how to do it, thanks for your help
                                          sdetweil @Manu85
                                          @Manu85 you would copy somefile to where you have an email client and then send it like normal mail
                                          I gave u my email adress
                                            Manu85
                                            “u can send it to me by email, to my same userid as here at gmail”?
                                            • 3 / 5
