    my mirror freezes!
    98 Posts 5 Posters 58.3k Views 4 Watching
      A Former User
      Just for more information. It’s on MM v2. 11.0?
      Because I have some freeze problem too. I have never in v2.10.x
      I suspect electron versioning bug
        sdetweil @Guest
        @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
          A Former User
          weird, thx, i will inspect more
            Manu85
            @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
              sdetweil @Manu85
              @Manu85 said in my mirror freezes!:
              sorry, what does that mean?
              by adding the mmm-logging module
              you get enhanced messages on the terminal window console like this with timestamps
              [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
              [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
              [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
              so, you should have started your mirror like this to capture all the traces
              npm start >somefile
              now that the app is hung, you can open another winscp terminal window and then
              cd ~/.MagicMirror
              tail somefile
              which will show the last 15 lines of somefile by default
              tail -n number somefile
              where number is something like 20, 40, 50 will show more lines
              if you started with pm2, then the output is on the logs…
              pm2 logs --lines=100 >somefile
              will dump the last 100 lines into somefile so you can examine them
                Manu85
                I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                Error
                Post content was flagged as spam by Akismet.com
                  sdetweil @Manu85
                  @Manu85 u can send it to me by email, to my same userid as here at gmail
                    Manu85
                    when placing your order I have this:
                    pi@raspberrypi:~/MagicMirror $ npm start >somefile
                    [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                    at listenInCluster (net.js:1378:12)
                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                    errno: ‘EADDRINUSE’,
                    code: ‘EADDRINUSE’,
                    syscall: ‘listen’,
                    address: ‘127.0.0.1’,
                    port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                    code: ‘EADDRINUSE’,
                    syscall: ‘listen’,
                      sdetweil @Manu85
                      @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                        Manu85
                        ok you can tell me how to do it?
                          sdetweil @Manu85
                          @Manu85 pm2 stop 0
                            Manu85
                            ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
                              sdetweil @Manu85
                              on boot, right?
                              if you use winscp to connect to pi, then copy the file to your pc and mail from there
                                Manu85
                                pi@raspberrypi:~/MagicMirror $ tail somefile
                                [2020-04-06 15:19:00.632] [LOG] 2020-04-06T15:19:00 Connecting socket for: newsfeed (/home/pi/MagicMirror/js/node_helper.js:97 Class.setSocketIO)
                                [2020-04-06 15:19:00.633] [LOG] 2020-04-06T15:19:00 Starting module: newsfeed (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:15 Class.start)
                                [2020-04-06 15:19:00.634] [LOG] 2020-04-06T15:19:00 Sockets connected & modules started … (/home/pi/MagicMirror/js/app.js:233 )
                                [2020-04-06 15:19:00.858] [LOG] 2020-04-06T15:19:00 Launching application. (/home/pi/MagicMirror/js/electron.js:81 App.)
                                [2020-04-06 15:19:03.615] [LOG] 2020-04-06T15:19:03 MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                [2020-04-06 15:19:03.617] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                [2020-04-06 15:19:03.619] [LOG] 2020-04-06T15:19:03 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                [2020-04-06 15:19:03.640] [LOG] 2020-04-06T15:19:03 Create new calendar fetcher for url: http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6JXqtyFFXzQwCFuV_rleNhqA2u8ZaQkK6-6HzuFLzdeE_Pic - Interval: 300000 (/home/pi/MagicMirror/modules/default/calendar/node_helper.js:49 Class.createFetcher)
                                [2020-04-06 15:19:03.667] [LOG] 2020-04-06T15:19:03 Create new news fetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000 (/home/pi/MagicMirror/modules/default/newsfeed/node_helper.js:48 Class.createFetcher)
                                [2020-04-06 15:19:04.164] [LOG] 2020-04-06T15:19:04 payload: undefined (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
                                  sdetweil @Manu85
                                  @Manu85 yes, now we need to wait for hang again
                                    Manu85
                                    I just rebooted the mirror restarted, is that what I had to do?
                                      sdetweil @Manu85
                                      @Manu85 yes, it is logging to the pm2 log, all ok
                                        Manu85
                                        I was afraid of doing something stupid! now something must be done?
                                          sdetweil @Manu85
                                          @Manu85 tomorrow when hung, do
                                          and look at somefile
                                            Manu85
                                            ok i will wait tomorrow, thanks for your help
                                            • 3 / 5
