    my mirror freezes!
    98 Posts 5 Posters 56.3k Views 4 Watching
      sdetweil @Manu85
      @Manu85
              module: 'MMM-Logging',
                  // Module functions out of the box with nothing set here.
                  // See below for configurable options.
              },    // < ---- missing comma  (like behind all modules)
        Manu85
        I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
        language: “fr”,
        timeFormat: 24,
        units: “metric”,
          Manu85
          excuse me I sent the message twice because the site had crashed …, I test what you sent me
            Manu85
            I still have the same message.
            language: “fr”,
            timeFormat: 24,
            units: “metric”,
              sdetweil @Manu85
              @Manu85 sorry, copy error on my part
                  } ,    // < --- add comma here  means continued
                Manu85
                impeccable, you’re the best, the mirror has restarted, and now what’s next please
                  sdetweil @Manu85
                  @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
                  find it and practice how to view it
                    Manu85
                    ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
                      [[global:former-user]]
                      Just for more information. It’s on MM v2. 11.0?
                      Because I have some freeze problem too. I have never in v2.10.x
                      I suspect electron versioning bug
                        sdetweil @Guest
                        @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
                          weird, thx, i will inspect more
                            Manu85
                            @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                              sdetweil @Manu85
                              @Manu85 said in my mirror freezes!:
                              sorry, what does that mean?
                              by adding the mmm-logging module
                              you get enhanced messages on the terminal window console like this with timestamps
                              [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                              [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                              [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                              so, you should have started your mirror like this to capture all the traces
                              npm start >somefile
                              now that the app is hung, you can open another winscp terminal window and then
                              cd ~/.MagicMirror
                              tail somefile
                              which will show the last 15 lines of somefile by default
                              tail -n number somefile
                              where number is something like 20, 40, 50 will show more lines
                              if you started with pm2, then the output is on the logs…
                              pm2 logs --lines=100 >somefile
                              will dump the last 100 lines into somefile so you can examine them
                                Manu85
                                I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                                Error
                                Post content was flagged as spam by Akismet.com
                                  sdetweil @Manu85
                                  @Manu85 u can send it to me by email, to my same userid as here at gmail
                                    Manu85
                                    when placing your order I have this:
                                    pi@raspberrypi:~/MagicMirror $ npm start >somefile
                                    [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                                    at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                                    at listenInCluster (net.js:1378:12)
                                    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                                    errno: ‘EADDRINUSE’,
                                    code: ‘EADDRINUSE’,
                                    syscall: ‘listen’,
                                    address: ‘127.0.0.1’,
                                    port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                                    code: ‘EADDRINUSE’,
                                    syscall: ‘listen’,
                                      sdetweil @Manu85
                                      @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                                        Manu85
                                        ok you can tell me how to do it?
                                          sdetweil @Manu85
                                          @Manu85 pm2 stop 0
                                            Manu85
                                            ok I made the order my MM goes out and it doesn’t start anymore, and I don’t know how to get you to send the file to your email, I’m really sorry to be too unable :-(
                                            • 2 / 5
