    my mirror freezes!
    98 Posts 5 Posters 58.3k Views 4 Watching
      sdetweil @Manu85
      @Manu85 sorry, hate that…
      no spaces
      export ELECTRON_ENABLE_LOGGING=true
        Manu85
        ok perfect the line has passed,
        pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING=true
        i downloaded the module, now i set it in config.js?
          bhepler Module Developer
            sdetweil @Manu85
            @Manu85 yes, follow the modules readme
              Manu85
              ok i try …
                Manu85
                I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
                language: “fr”,
                timeFormat: 24,
                units: “metric”,
                        module: 'MMM-Logging',
                            // Module functions out of the box with nothing set here.
                            // See below for configurable options.
                  sdetweil @Manu85
                  @Manu85
                          },    // < ---- missing comma  (like behind all modules)
                    Manu85
                    language: “fr”,
                    timeFormat: 24,
                    units: “metric”,
                      Manu85
                      excuse me I sent the message twice because the site had crashed …, I test what you sent me
                        Manu85
                        I still have the same message.
                        language: “fr”,
                        timeFormat: 24,
                        units: “metric”,
                          sdetweil @Manu85
                          @Manu85 sorry, copy error on my part
                              } ,    // < --- add comma here  means continued
                            Manu85
                            impeccable, you’re the best, the mirror has restarted, and now what’s next please
                              sdetweil @Manu85
                              @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
                              find it and practice how to view it
                                Manu85
                                ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
                                  A Former User
                                  Just for more information. It’s on MM v2. 11.0?
                                  Because I have some freeze problem too. I have never in v2.10.x
                                  I suspect electron versioning bug
                                    sdetweil @Guest
                                    @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
                                      A Former User
                                      weird, thx, i will inspect more
                                        Manu85
                                        @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                                          sdetweil @Manu85
                                          @Manu85 said in my mirror freezes!:
                                          sorry, what does that mean?
                                          by adding the mmm-logging module
                                          you get enhanced messages on the terminal window console like this with timestamps
                                          [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                                          [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                                          [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                                          so, you should have started your mirror like this to capture all the traces
                                          npm start >somefile
                                          now that the app is hung, you can open another winscp terminal window and then
                                          cd ~/.MagicMirror
                                          tail somefile
                                          which will show the last 15 lines of somefile by default
                                          tail -n number somefile
                                          where number is something like 20, 40, 50 will show more lines
                                          if you started with pm2, then the output is on the logs…
                                          pm2 logs --lines=100 >somefile
                                          will dump the last 100 lines into somefile so you can examine them
                                            Manu85
                                            I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                                            Error
                                            Post content was flagged as spam by Akismet.com
                                            • 2 / 5
