    my mirror freezes!
    98 Posts 5 Posters 54.7k Views 4 Watching
      Manu85
      I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
      language: “fr”,
      timeFormat: 24,
      units: “metric”,
              module: 'MMM-Logging',
                  // Module functions out of the box with nothing set here.
                  // See below for configurable options.
        sdetweil @Manu85
        @Manu85
                },    // < ---- missing comma  (like behind all modules)
          Manu85
          language: “fr”,
          timeFormat: 24,
          units: “metric”,
            Manu85
            excuse me I sent the message twice because the site had crashed …, I test what you sent me
              Manu85
              I still have the same message.
              language: “fr”,
              timeFormat: 24,
              units: “metric”,
                sdetweil @Manu85
                @Manu85 sorry, copy error on my part
                    } ,    // < --- add comma here  means continued
                  Manu85
                  impeccable, you’re the best, the mirror has restarted, and now what’s next please
                    sdetweil @Manu85
                    @Manu85 wait til it hangs… look at the MMM-Logging module instructions, where does it put the log file,
                    find it and practice how to view it
                      Manu85
                      ok i just deleted my automatic hourly reboot and i’ll wait for it to hang
                        A Former User
                        Just for more information. It’s on MM v2. 11.0?
                        Because I have some freeze problem too. I have never in v2.10.x
                        I suspect electron versioning bug
                          sdetweil @Guest
                          @Bugsounet so far my 10 different mm systems have been running fine since upgrade (using my upgrade script)
                            A Former User
                            weird, thx, i will inspect more
                              Manu85
                              @sdetweil Hello, as agreed I deleted the automatic reboot and this morning the MM is blocked (as usual) I use WinScp and when I wanted to quit it he offered to create a folder "my workspace "that’s what I did, I then opened this new file which connects me directly to the MMM-Logging module and after that I don’t know what to do!
                                sdetweil @Manu85
                                @Manu85 said in my mirror freezes!:
                                sorry, what does that mean?
                                by adding the mmm-logging module
                                you get enhanced messages on the terminal window console like this with timestamps
                                [24253:0406/055023.243727:INFO:CONSOLE(107)] "clearing timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (107)
                                [24253:0406/055023.243800:INFO:CONSOLE(110)] "starting timer", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (110)
                                [24253:0406/055023.243847:INFO:CONSOLE(112)] "timer started", source: http://0.0.0.0:8080/modules/MyCovid19//MyCovid19.js (112)
                                so, you should have started your mirror like this to capture all the traces
                                npm start >somefile
                                now that the app is hung, you can open another winscp terminal window and then
                                cd ~/.MagicMirror
                                tail somefile
                                which will show the last 15 lines of somefile by default
                                tail -n number somefile
                                where number is something like 20, 40, 50 will show more lines
                                if you started with pm2, then the output is on the logs…
                                pm2 logs --lines=100 >somefile
                                will dump the last 100 lines into somefile so you can examine them
                                  Manu85
                                  I have a report which was created in MM “somfile” but I cannot send it because I have this error on the forum
                                  Error
                                  Post content was flagged as spam by Akismet.com
                                    sdetweil @Manu85
                                    @Manu85 u can send it to me by email, to my same userid as here at gmail
                                      Manu85
                                      when placing your order I have this:
                                      pi@raspberrypi:~/MagicMirror $ npm start >somefile
                                      [2020-04-06 14:36:28.593] [ERROR] 2020-04-06T14:36:28 { Error: listen EADDRINUSE 127.0.0.1:8080
                                      at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                                      at listenInCluster (net.js:1378:12)
                                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                                      errno: ‘EADDRINUSE’,
                                      code: ‘EADDRINUSE’,
                                      syscall: ‘listen’,
                                      address: ‘127.0.0.1’,
                                      port: 8080 } (/home/pi/MagicMirror/js/app.js:40 process.)
                                      code: ‘EADDRINUSE’,
                                      syscall: ‘listen’,
                                        sdetweil @Manu85
                                        @Manu85 that means the mirror is already running, probably cause of pm2… need to stop it first, can’t run two at the same time
                                          Manu85
                                          ok you can tell me how to do it?
                                            sdetweil @Manu85
                                            @Manu85 pm2 stop 0
                                            • 2 / 5
