    my mirror freezes!
    98 Posts 5 Posters 58.3k Views 4 Watching
      Manu85
      I have several lines that look like errors, I put you the copy of all the lines, I tried to hide the confidential data !!!
      /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
      0|MagicMir | npm ERR! code ELIFECYCLE
      0|MagicMir | npm ERR! errno 1
      0|MagicMir | npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      0|MagicMir | npm ERR! Exit status 1
      0|MagicMir | npm ERR! Failed at the magicmirror@2.11.0 start script.
      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|MagicMir |
      0|MagicMir | npm ERR! A complete log of this run can be found in:
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T07_00_02_234Z-debug.log
      0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      0|MagicMir | [2020-04-05 09:00:36.357] [ERROR]  (node:954) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|MagicMir | [2020-04-05 09:57:55.156] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIXXXXXXXXXXXXXXXE_Pic { Error: connect ETIMEDOUT 17.248.144.201:443
      0|MagicMir |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1161:14)
      0|MagicMir |   errno: 'ETIMEDOUT',
      0|MagicMir |   code: 'ETIMEDOUT',
      0|MagicMir |   syscall: 'connect',
      0|MagicMir |   address: '17.XXXXXXX',
      0|MagicMir |   port: 443 }
      0|MagicMir |
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T08_00_01_545Z-debug.log
      0|MagicMir | [2020-04-05 10:00:36.536] [ERROR]  (node:978) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|MagicMir |
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T09_00_02_026Z-debug.log
      0|MagicMir | [2020-04-05 11:00:37.769] [ERROR]  (node:1007) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|MagicMir | [2020-04-05 11:30:42.125] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENnXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX_Pic { Error: connect EHOSTUNREACH 17XXXXXXXXXXX:80
      0|MagicMir |   errno: 'EHOSTUNREACH',
      0|MagicMir |   code: 'EHOSTUNREACH',
      0|MagicMir |   address: 'XXXXXXXXXXXXX1',
      0|MagicMir |   port: 80 }
      0|MagicMir |
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T10_00_02_273Z-debug.log
      0|MagicMir | [2020-04-05 12:00:36.374] [ERROR]  (node:904) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|MagicMir | [2020-04-05 12:17:53.271] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXK6-6HzuFLzdeE_Pic { Error: connect ETIMEDOUT 17.248.144.201:80
      0|MagicMir |   address: '17.XXXXXXXXXX1',
      0|MagicMir | [2020-04-05 12:27:52.308] [ERROR]  Calendar Error. Could not fetch calendar:  http://p59-calendars.icloud.com/published/2/2uR1boEvTP2Z11yC3RAkgMluEyI6FkQslrByha_3OaasENn6SQAtTWIYmfP6XXXXXXXXXXXXXXXXXXXXXXXXXXeE_Pic { Error: connect ETIMEDOUT 17.248.144.176:80
      0|MagicMir |   address: 'XXXXXXXXXXXX6',
      0|MagicMir |
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T11_00_02_185Z-debug.log
      0|MagicMir | [2020-04-05 13:00:36.526] [ERROR]  (node:909) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      0|MagicMir |
      0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-04-05T12_00_02_475Z-debug.log
      0|MagicMir | [2020-04-05 14:00:36.327] [ERROR]  (node:953) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
        sdetweil @Manu85
        @Manu85 said in my mirror freezes!:
        i see those on my mirror systems occasionally… usually a network problem outside my house…
        and my systems recover
          Manu85
          and what to do please?
            sdetweil @Manu85
            @Manu85 open the developers window (ctrl-shift-i on keyboard), select the tab labeled console,
            and look around (scroll up), looking for any errors, red text…
            but if the mirror hangs this will not work… thus why I suggested installing MMM-Logging module and enable electron debugging to try to capture any error messages
              Manu85
              this one :
              MMM-Logging ?
                sdetweil @Manu85
                @Manu85 yes,
                make sure to do this
                Note: You can find more detailed information on debugging your MagicMirror here: Module Debugging. If you also want the Electron rederer (web browser) console logs to be printed to the standard console (or PM2 logs), change the following line to the very top of ~/MagicMirror/run-start.sh
                export ELECTRON_ENABLE_LOGGING=true
                  Manu85
                  @sdetweil thank you for your answer i will follow your advice, but it exceeds my skills, can you tell me exactly what to do please?
                    sdetweil @Manu85
                    @Manu85 install the module(note that it wants to be first in the module list in config.js), and add this to the batch file starting the mirror
                      Manu85
                      The you lost me :-), "and add this to the batch file starting the mirror
                      export ELECTRON_ENABLE_LOGGING = true "
                        sdetweil @Manu85
                        @Manu85 how does MM get started? pm2?
                        if so, it usually uses a batch file (script)
                        ~/MagicMirror/installers/mm.sh
                        make it look like this
                        DISPLAY=:0 npm start
                          Manu85
                          I have this error message:
                          pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING = true
                          -bash: export: « = » : identifiant non valable
                            Manu85
                            -bash: export: “=”: invalid identifier
                              sdetweil @Manu85
                              @Manu85 sorry, hate that…
                              no spaces
                                Manu85
                                ok perfect the line has passed,
                                pi@raspberrypi:~/MagicMirror $ export ELECTRON_ENABLE_LOGGING=true
                                i downloaded the module, now i set it in config.js?
                                  bhepler Module Developer
                                    sdetweil @Manu85
                                    @Manu85 yes, follow the modules readme
                                      Manu85
                                      ok i try …
                                        Manu85
                                        I installed it at the top of the config.js file and I have an error when starting the MM “please create a config file”
                                        language: “fr”,
                                        timeFormat: 24,
                                        units: “metric”,
                                                module: 'MMM-Logging',
                                                    // Module functions out of the box with nothing set here.
                                                    // See below for configurable options.
                                          sdetweil @Manu85
                                          @Manu85
                                                  },    // < ---- missing comma  (like behind all modules)
                                            Manu85
                                            language: “fr”,
                                            timeFormat: 24,
                                            units: “metric”,
                                            • 1 / 5
