    my mirror freezes!
    98 Posts 5 Posters 44.1k Views 4 Watching
      sdetweil @Manu85
      @Manu85 yes, short term, disable the MMM-SoccerLiveScore module
      add
      disabled:true,
      to its module definition on config.js
      the system should no longer crash
      then work with the module author to get a fix
        Manu85
        @sdetweil like that?
        			disabled:true,
        			module: 'MMM-SoccerLiveScore',
        			position: 'top_right',
        			header: 'Scores en direct',
        				leagues: [34, 8],
        		        showNames: true,
        		        showLogos: true,
        		        displayTime: 60 * 1000,
        		        showTables: true
          sdetweil @Manu85
          @Manu85
          yes
            Manu85
            @sdetweil ok i will try thank you again you are a genius
              sdetweil @Manu85
              @Manu85 the module author posted in 2018 that he no longer had time to maintain this module…
              I looked at the code and all the data operations do not check for errors. so there is quite a bit of work to fix the module
                mr_cd
                Hi guys,
                my name is Chris and im from Germany.
                I face the same problem with freezing mirror, i read all your files an did the same at my mirror.
                Now the mirror has created a lot of logfiles, and im not sure which one is the correct one. Also im not able to find the Errors the freezing problem could belong.
                So im asking you guys to support me with this Situation.
                I figured out, that wehen the mirror freezes the MMM-NetworkSignal has also no connection.
                Here is an overwiev of my actual configuration:
                Pi 3b+
                Magic Mirror latest Version
                Modules :
                Default :
                alert - in use
                calender-in use
                clock - in use
                currentweather - in use
                weatherforecast - in use
                newsfeed - in use
                Third Party:
                MMM-ImagesPhotos - in use
                MMM-Logging - in use
                MMM-MyWastePickup - in use
                MMM-Network Signal - in use
                MMM-DWD Warn Weather - installed but commendet out in config file
                MMM-Globe - installed but commendet out in config file
                MMM-MyCalender – installed but commendet out in config file
                MMM-MyScoreboard - installed but commendet out in config file (during corona)
                MMM-MyWheater - installed but commendet out in config file
                MMM-NowPlaying on Spotify - installed but commendet out in config file
                MMM-PIR Sensor - installed but commendet out in config file
                MMM-Remote Control - installed but commendet out in config file
                The Mirror is starting using pm 2.
                Here are some lines from the mm-error logfile located at /home/pi/.pm2/logs
                [2020-04-28 00:39:19.687] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:60:26) {
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                  syscall: 'getaddrinfo',
                  hostname: 'calendar.google.com'
                [2195:0428/003919.718891:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-28 00:39:19.720] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0428/003919.744610:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-28 00:39:19.746] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0428/003919.753595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.784061:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.860876:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.882695:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.891740:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.908750:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/003919.916802:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0428/004727.451754:INFO:CONSOLE(205)] "weatherforecast is resumed.", source: http://localhost:8080/js/module.js (205)
                [2195:0428/005514.543522:INFO:CONSOLE(205)] "currentweather is resumed.", source: http://localhost:8080/js/module.js (205)
                [2020-04-30 00:08:59.708] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2020-04-30 00:08:59.724] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/000859.736313:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000859.745465:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000859.761144:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000859.775211:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000859.792361:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000859.807923:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:09:18.623] [ERROR]  fatal: unable to access 'https://github.com/roramirez/MMM-ImagesPhotos.git/': Could not resolve host: github.com
                [2020-04-30 00:09:18.725] [ERROR]  fatal: unable to access 'https://github.com/jclarke0000/MMM-MyWastePickup.git/': Could not resolve host: github.com
                [2020-04-30 00:09:18.728] [ERROR]  fatal: unable to access 'https://github.com/PoOwAa/MMM-network-signal/': Could not resolve host: github.com
                [2020-04-30 00:09:18.771] [ERROR]  fatal: unable to access 'https://github.com/shbatm/MMM-Logging.git/': Could not resolve host: github.com
                [2020-04-30 00:09:18.844] [ERROR]  fatal: unable to access 'https://github.com/MichMich/MagicMirror/': Could not resolve host: github.com
                [2195:0430/000920.383795:INFO:CONSOLE(271)] "weatherforecast: Could not load weather.", source: http://localhost:8080/modules/default/weatherforecast//weatherforecast.js (271)
                [2020-04-30 00:09:39.751] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/000939.791582:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000939.804267:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/000939.824935:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:10:19.793] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2020-04-30 00:10:19.809] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001019.833930:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001019.840701:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001019.857296:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001019.885040:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001019.905215:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001019.919681:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:10:59.835] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001059.840348:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:10:59.847] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001059.858241:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001059.865001:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001059.872447:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001059.881979:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001059.890498:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:11:39.882] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001139.901071:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:11:39.901] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001139.908785:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001139.916964:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001139.929157:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001139.935884:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001139.943338:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:12:19.927] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2020-04-30 00:12:19.936] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001219.953136:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001219.973069:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001219.978405:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001219.989848:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001219.997470:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001220.005115:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar:Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:12:59.964] [ERROR]  Calendar Error. Could not fetch calendar:  Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001259.973595:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:12:59.974] [ERROR]  Calendar Error. Could not fetch calendar:  Another Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                [2195:0430/001300.000064:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001300.008861:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001300.023657:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001300.036013:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2195:0430/001300.051823:INFO:CONSOLE(137)] "Calendar Error. Could not fetch calendar: Another Path to my private google calendar.ics", source: http://localhost:8080/modules/default/calendar//calendar.js (137)
                [2020-04-30 00:13:40.001] [ERROR]  Calendar Error. Could not fetch calendar: Path to my private google calendar.ics Error: getaddrinfo EAI_AGAIN calendar.google.com
                  errno: 'EAI_AGAIN',
                  code: 'EAI_AGAIN',
                And here are some lines from the logfile pm2.log
                2020-04-21T21:02:02: PM2 log: Stopping app:mm id:0
                2020-04-21T21:02:02: PM2 log: pid=1523 msg=failed to kill - retrying in 100ms
                2020-04-21T21:02:02: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                2020-04-21T21:02:02: PM2 log: pid=1523 msg=process killed
                2020-04-21T21:13:08: PM2 log: App [mm:0] starting in -fork mode-
                2020-04-21T21:13:08: PM2 log: App [mm:0] online
                2020-04-22T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-22T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
                2020-04-23T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-23T20:59:11: PM2 log: [PM2] Upgrade to version 4.3.1
                2020-04-24T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-24T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-25T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-25T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-26T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-26T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-27T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-27T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-28T20:59:11: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-28T20:59:11: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-29T20:59:12: PM2 log: [PM2] This PM2 is not UP TO DATE
                2020-04-29T20:59:12: PM2 log: [PM2] Upgrade to version 4.4.0
                2020-04-30T07:24:43: PM2 log: Stopping app:mm id:0
                2020-04-30T07:24:43: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                2020-04-30T07:24:44: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                2020-04-30T07:24:45: PM2 log: pid=2175 msg=failed to kill - retrying in 100ms
                2020-04-30T07:24:45: PM2 log: Process with pid 2175 still alive after 1600ms, sending it SIGKILL now...
                2020-04-30T07:24:45: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
                2020-04-30T07:24:45: PM2 log: pid=2175 msg=process killed
                2020-04-30T07:24:45: PM2 log: PM2 successfully stopped
                2020-04-30T07:25:51: PM2 log: ===============================================================================
                2020-04-30T07:25:51: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                2020-04-30T07:25:51: PM2 log: Time                 : Thu Apr 30 2020 07:25:51 GMT+0200 (GMT+02:00)
                2020-04-30T07:25:51: PM2 log: PM2 version          : 4.2.3
                2020-04-30T07:25:51: PM2 log: Node.js version      : 10.18.0
                2020-04-30T07:25:51: PM2 log: Current arch         : arm
                2020-04-30T07:25:51: PM2 log: PM2 home             : /home/pi/.pm2
                2020-04-30T07:25:51: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                2020-04-30T07:25:51: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                2020-04-30T07:25:51: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                2020-04-30T07:25:51: PM2 log: Application log path : /home/pi/.pm2/logs
                2020-04-30T07:25:51: PM2 log: Worker Interval      : 30000
                2020-04-30T07:25:51: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                2020-04-30T07:25:51: PM2 log: Concurrent actions   : 2
                2020-04-30T07:25:51: PM2 log: SIGTERM timeout      : 1600
                2020-04-30T07:25:51: PM2 log: App [mm:0] starting in -fork mode-
                2020-04-30T07:25:51: PM2 log: App [mm:0] online
                2020-04-30T20:06:26: PM2 log: Stopping app:mm id:0
                2020-04-30T20:06:26: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
                2020-04-30T20:06:27: PM2 log: pid=823 msg=failed to kill - retrying in 100ms
                2020-04-30T20:06:28: PM2 log: Process with pid 823 still alive after 1600ms, sending it SIGKILL now...
                2020-04-30T20:06:28: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
                2020-04-30T20:06:28: PM2 log: pid=823 msg=process killed
                2020-04-30T20:06:28: PM2 log: PM2 successfully stopped
                2020-04-30T20:07:36: PM2 log: ===============================================================================
                2020-04-30T20:07:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
                2020-04-30T20:07:36: PM2 log: Time                 : Thu Apr 30 2020 20:07:36 GMT+0200 (GMT+02:00)
                2020-04-30T20:07:36: PM2 log: PM2 version          : 4.2.3
                2020-04-30T20:07:36: PM2 log: Node.js version      : 10.18.0
                2020-04-30T20:07:36: PM2 log: Current arch         : arm
                2020-04-30T20:07:36: PM2 log: PM2 home             : /home/pi/.pm2
                2020-04-30T20:07:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
                2020-04-30T20:07:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
                2020-04-30T20:07:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
                2020-04-30T20:07:36: PM2 log: Application log path : /home/pi/.pm2/logs
                2020-04-30T20:07:36: PM2 log: Worker Interval      : 30000
                2020-04-30T20:07:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
                2020-04-30T20:07:36: PM2 log: Concurrent actions   : 2
                2020-04-30T20:07:36: PM2 log: SIGTERM timeout      : 1600
                2020-04-30T20:07:36: PM2 log: App [mm:0] starting in -fork mode-
                2020-04-30T20:07:36: PM2 log: App [mm:0] online
                2020-04-30T20:09:14: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
                2020-04-30T20:09:14: PM2 log: App [mm:0] starting in -fork mode-
                2020-04-30T20:09:14: PM2 log: App [mm:0] online
                2020-04-30T20:09:36: PM2 log: Stopping app:mm id:0
                Sorry for posting so much code …
                Thank you in advance for the support,
                Chris
                  sdetweil @mr_cd
                  @mr_cd said in my mirror freezes!:
                  [2020-04-30 00:09:18.623] [ERROR] fatal: unable to access ‘https://github.com/roramirez/MMM-ImagesPhotos.git/’: Could not resolve host: github.com
                  looks like it is the updatenotification module
                  add
                  like this
                  			module: "updatenotification",
                  			disabled: true,     /// < --- add this line
                  			position: "top_bar"
                    mr_cd
                    Hi Sam,
                    thanks for that quick reply.
                    I added the line in the config file.
                    Could you please give me an short explaination how this line is affecting the freezing problem?
                    Thanks and best regards
                    Chris
                      sdetweil @mr_cd
                      @mr_cd it reports a fatal error and this will cause the mirror to stop working…
                        mr_cd
                        @sdetweil that means the error will not be shown - but still exists?
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 7 / 10
