    my mirror freezes!
    98 Posts 5 Posters 48.5k Views 4 Watching
    • ? Offline
      A Former User
      of course try ;)
      • ? Offline
        A Former User
        humm, i think to other things…
        Do you use Raspotify program ?
          mr_cd
          No i dont - but i used MMM-Spotify but i disabled it because of this freezing problem. But it still freezes…
            mr_cd
            But there is one suspect thing.
            When the Mirror freeze, im not able to connect with VNC. But how affect the MM Software the VNC Connection? Maybe there is a Problem with WLAN Connection…?!
            ? S 2 Replies Last reply Reply Quote 0
            • ? Offline
              A Former User
              so continue to disable modules one by one…
              and default too … to discover the responsible module
              • ? Offline
                A Former User @mr_cd
                @mr_cd : yes but it will not freeze… just display warning
                  sdetweil @mr_cd
                  @mr_cd how much swap space do you have? and is used?
                  free -m will show info
                    mr_cd
                    if the mirror is running.
                    But lets define the word freeze : I mean the clock is still working - but the modules like wheather or calender ar not updating…
                      sdetweil @mr_cd
                      @mr_cd but u also said vnc doesn’t work.
                        sdetweil @mr_cd
                        @mr_cd clock is working from internal timer… others require internet connection to update
                          mr_cd
                          @sdetweil correct. But when i plug in the USB mouse into rasperry iam able to work. After rebooting the system it works every time without problem
                            sdetweil @mr_cd
                            @mr_cd so, not really a ‘freeze’… MM stops working… system is ok, except for networking, recovers on reboot…
                            sounds like network went to sleep. there is a powersave setting on wifi…
                              mr_cd
                              seems to be ok…
                                sdetweil @mr_cd
                                @mr_cd well, that ain’t it! thx
                                  mr_cd
                                  @sdetweil but i could be because im working with it. i need to check during the next “freeze” when i connect directly with the mouse if the power save mode is still off.
                                  • ? Offline
                                    A Former User
                                    yes because… we lack ideas. this will allow us to reflect
                                      sdetweil @mr_cd
                                      @mr_cd it shouldn’t change the config by itself…
                                      but thank you, it forced me to check one system I have that seemed/s to have netowkr connection troubles…
                                      PM was on… now off
                                        mr_cd
                                        @Bugsounet @sdetweil Okay thats good :) luckily we could fix one Problem !
                                        Lets see i will find a solution - if you having new ideas pleas inform me , if i find the problem i will keep you up to date!
                                        • 5 / 5
